社区导航
查看: 2319|回复: 14
[讨论] TI新出了个带以太网的芯片SimpleLink™ MSP432E4系列
2755
TA的帖子
Rank: 6Rank: 6
测评达人
发表于 2017-12-6 11:32:36 | 显示全部楼层 |阅读模式
TI新出了个带以太网的芯片SimpleLink™ MSP432E4 Ethernet microcontrollers  MSP432E401Y
The SimpleLink MSP432E401Y Arm® Cortex®-M4F microcontrollers provide top performance and advanced integration. The product family is positioned for cost-effective applications requiring significant control processing and connectivity capabilities.
The MSP432E401Y microcontrollers integrate a large variety of rich communication features to enable a new class of highly connected designs with the ability to allow critical real-time control between performance and power. The microcontrollers feature integrated communication peripherals along with other high-performance analog and
digital functions to offer a strong foundation for many different target uses, spanning from human-machine interface (HMI) to networked system management controllers.
In addition, the MSP432E401Y microcontrollers offer the advantages of widely available development tools, system-on-chip (SoC) infrastructure, and a large user community for Arm-based microcontrollers. Additionally, these microcontrollers use the Arm Thumb®-compatible Thumb-2® instruction set to reduce memory requirements and, thereby, cost. When using the SimpleLink MSP432™ SDK, the MSP432E401Y microcontroller is code compatible with all members of the extensive SimpleLink family, providing flexibility to fit precise needs.
The MSP432E401Y device is part of the SimpleLink microcontroller (MCU) platform, which consists of Wi-Fi®, Bluetooth® low energy, Sub-1 GHz, Ethernet, Zigbee, Thread, and host MCUs, which all share a common, easy-to-use development environment with a single core software development kit (SDK) and rich tool set. A one-time integration of the SimpleLink platform enables you to add any combination of the portfolio’s devices into your design, allowing 100 percent code reuse when your design requirements change. For more information, visit www.ti.com/simplelink.
特性
  • Core
    • 120-MHz Arm[size=0.7em]® Cortex[size=0.7em]®-M4F Processor Core With Floating-Point Unit (FPU)
  • Connectivity
    • Ethernet MAC: 10/100 Ethernet MAC With Integrated Ethernet PHY
    • Ethernet PHY: PHY With IEEE 1588 PTP Hardware Support
    • Universal Serial Bus (USB): USB 2.0 OTG, Host, or Device With ULPI Interface Option and Link Power Management (LPM)
    • Eight Universal Asynchronous Receivers/Transmitters (UARTs), Each With Independently Clocked Transmitter and Receiver
    • Four Quad Synchronous Serial Interface (QSSI): With Bi-, Quad-, and Advanced-SSI Support
    • Ten Inter-Integrated Circuit (I[size=0.7em]2C) Modules With High-Speed Mode Support
    • Two CAN 2.0 A and B Controllers: Multicast Shared Serial-Bus Standard
  • Memories
    • 1024KB of Flash Memory With 4-Bank Configuration Supports an Independent Code Protection for Each Bank
    • 256KB of SRAM With Single-Cycle Access, Provides Nearly 2-GB/s Memory Bandwidth at 120-MHz Clock Frequency
    • 6KB EEPROM: 500-kwrite per 2 Page Block, Leveling, Lock Protection
    • Internal ROM: Loaded With SimpleLink™ SDK Software
      • Peripheral Driver Library
      • Bootloader
    • External Peripheral Interface (EPI): 8-, 16-, or 32-Bit Dedicated Parallel Interface to Access External Devices and Memory (SDRAM, Flash, or SRAM)
  • Security
    • Advanced Encryption Standard (AES): Hardware Accelerated Data Encryption and Decryption Based on 128-, 192-, and 256-Bit Keys
    • Data Encryption Standard (DES): Hardware Accelerated Data Encryption and Decryption Supported by Block Cipher Implementation With 168-Bit Effective Key Length
    • Secure Hash Algorithm/Message Digest Algorithm (SHA/MD5): Advanced Hash Engine That Supports SHA-1, SHA-2, and MD5 Hash Computation
    • Cyclical Redundancy Check (CRC) Hardware
    • Tamper: Support for Four Tamper Inputs and Configurable Tamper Event Response
  • Analog
    • Two 12-Bit SAR-Based ADC Modules, Each Supports Up to 2 Million Samples per Second (2 Msps)
    • Three Independent Analog Comparator Controllers
    • 16 Digital Comparators
  • System Management
    • JTAG and Serial Wire Debug (SWD): One JTAG Module With Integrated Arm SWD Provides a Means of Accessing and Controlling Design-for-Test Features Such as I/O Pin Observation and Control, Scan Testing, and Debugging.
  • Development Kits and Software (See Tools and Software)
    • SimpleLink™ MSP-EXP432E401Y LaunchPad™ Development Kit
    • SimpleLink MSP432E4 Software Development Kit (SDK)
  • Package Information
    • Package: 128-Pin TQFP (PDT)
    • Extended Operating Temperature (Ambient) Range: –40°C to 105°C
All trademarks are the property of their respective owners.
The SimpleLink™ Ethernet MSP432E401Y microcontroller LaunchPad™ Development Kit is an intuitive evaluation platform for SimpleLink™ Arm® Cortex®-M4F-based Ethernet MCUs. The Ethernet LaunchPad development kit highlights the MSP432E401Y MCU with integrated Ethernet MAC and PHY and a wide variety of wired communication interfaces including USB-OTG, CAN, Quad-SPI (QSSI), I2C, SPI,  UART and other serial protocols. Featuring a 120MHz Arm Cortex-M4F CPU, 1MB of flash, 256kB of SRAM, and advanced cryptographic accelerators, MSP432E4 MCUs offer an ample amount of processing resources for developers to implement wired and wireless connectivity stacks and processing algorithms to develop robust Ethernet solutions. Developers can leverage a number of SimpleLink wireless MCU BoosterPack™ plug-in modules and SimpleLink software SDK plug-ins to seamlessly add wireless connectivity and cloud integration to the application to build IoT-ready, interoperable, and intelligent industrial gateway applications.
  • SimpleLink Ethernet MSP432E401Y 32-bit Arm Cortex-M4F MCU
  • 80 pin LaunchPad standard leveraging the BoosterPack ecosystem
  • On-board XDS-110 debug probe
  • Ethernet and USB-OTG
  • 2 user buttons and 4 LEDs for user interaction
What's Included
  • 1x MSP-EXP432E401Y LaunchPad Development Kit
  • 1x Micro USB Cable
  • 1x Quick Start Guide
  • SIMPLELINK-MSP432-SDK,SimpleLink MSP432 Software Development Kit (SDK)
slau748.pdf (1.15 MB, 下载次数: 8)
使用道具 举报
5460
TA的帖子
186
Rank: 6Rank: 6
发表于 2017-12-6 11:48:31 | 显示全部楼层
不错不错,团购搞起来!
EEWORLD开发板置换群:309018200,——电工们免费装β的天堂,虽然在群里买不到板子,但是可以学会开车;虽然学不到技术,但是可以学会开车;商家勿入!加群暗号:喵
使用道具 举报
1054
TA的帖子
Rank: 6Rank: 6
发表于 2017-12-6 12:26:43 | 显示全部楼层
不错不错,来一波团购!
使用道具 举报
362
TA的帖子
Rank: 2
发表于 2017-12-6 13:06:34 | 显示全部楼层
USB 和 以太网,团购加一
君应有语,渺万里层云,千山暮雪,知向谁边?
使用道具 举报
5480
TA的帖子
454
Rank: 9Rank: 9Rank: 9
发表于 2017-12-6 13:33:10 | 显示全部楼层
样片申请不了
好像是 样品申请 好像是出错了。  详情 回复 发表于 2017-12-6 13:47
使用道具 举报
2755
TA的帖子
Rank: 6Rank: 6
测评达人
 楼主| 发表于 2017-12-6 13:47:13 | 显示全部楼层
好像是  样品申请 好像是出错了。Internal Server Error - Read 后面应该会改过来吧。
好象选择CHINA就不能申请了,不过现在应该还是XPS吧! 主要这个板子的PCB可以自己编辑,修改下就可以了!  详情 回复 发表于 2017-12-6 13:58
使用道具 举报
5480
TA的帖子
454
发表于 2017-12-6 13:58:54 | 显示全部楼层
使用道具 举报
255
TA的帖子
Rank: 2
发表于 2017-12-7 09:31:39 | 显示全部楼层
性能还不错
学习永无止境
使用道具 举报
3308
TA的帖子
Rank: 6Rank: 6
发表于 2017-12-7 10:45:25 | 显示全部楼层
搞个SDRAM,解析下json
可以玩玩
撸片还是撸板?
撸片还是撸板?  详情 回复 发表于 2017-12-7 10:49
So what......
使用道具 举报
2755
TA的帖子
Rank: 6Rank: 6
测评达人
 楼主| 发表于 2017-12-7 10:49:35 | 显示全部楼层
ljj3166 发表于 2017-12-7 10:45
搞个SDRAM,解析下json
可以玩玩
撸片还是撸板?
撸片还是撸板?  估计还是撸板 吧
求大腿  详情 回复 发表于 2017-12-7 10:56
使用道具 举报
3308
TA的帖子
Rank: 6Rank: 6
发表于 2017-12-7 10:56:39 | 显示全部楼层
damiaa 发表于 2017-12-7 10:49
撸片还是撸板?  估计还是撸板 吧
求大腿
So what......
使用道具 举报
5480
TA的帖子
454
发表于 2017-12-8 10:01:31 | 显示全部楼层
MSP432E411YTZADR
可以申请!
使用道具 举报
1567
TA的帖子
Rank: 8Rank: 8
发表于 2017-12-8 10:33:45 | 显示全部楼层
被之前的测试版432launchpad搞怕了...便宜倒是真便宜......
使用道具 举报
1026
TA的帖子
Rank: 8Rank: 8
荣誉会员勋章
发表于 2017-12-10 00:47:13 | 显示全部楼层
好处是把phy做进去了,
坏处是把phy做进去了~
想想当初的8962~~~
好处坏处都是他  详情 回复 发表于 2018-3-15 15:06
使用道具 举报
2755
TA的帖子
Rank: 6Rank: 6
测评达人
 楼主| 发表于 2018-3-15 15:06:47 | 显示全部楼层
sblpp 发表于 2017-12-10 00:47
好处是把phy做进去了,
坏处是把phy做进去了~
想想当初的8962~~~
好处坏处都是他
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2018-12-19 11:02 , Processed in 0.403698 second(s), 17 queries , Gzip On, MemCache On.
