2639|7
stm32 +tm1638 只能显示,不能读键 为何?
stm32 +tm1638 只能显示,不能读键 为何?那地方出了问题 求大神指点。相关代码如下:
void TM1638_Write(unsigned char        DATA)                        //D′êy¾Yoˉêy
        unsigned char i;
        for(i=0;i<8;i++)
                CLK=0;
                if(DATA&0X01)
                        DIO=1;
                else
                        DIO=0;
                DATA>>=1;
                CLK=1;
unsigned char TM1638_Read(void)                                        //¶áêy¾Yoˉêy
        unsigned char i;
        unsigned char temp=0;
        DIO=1;        //éèÖÃÎaêäèë
        for(i=0;i<8;i++)
        delay_us(5)        ;
                temp>>=1;
                CLK=0;
                if(DIO)
                        temp|=0x80;
                CLK=1;
        return temp;
void Write_COM(unsigned char cmd)                //·¢ËíÃüáî×Ö
        STB=0;
        TM1638_Write(cmd);
        STB=1;
unsigned char Read_key(void)
        unsigned char c[4],i,key_value=0;
        STB=0;
                delay_ms(100);
        TM1638_Write(0x42);
        delay_ms(100);
        for(i=0;i<4;i++)
                        c=TM1638_Read();
        STB=1;                                        //4¸ö×Ö½úêy¾YoÏ3éò»¸ö×Ö½ú
        if(c[0]==0x04) key_value=1;
        if(c[0]==0x40) key_value=2;
        if(c[1]==0x04) key_value=3;
        if(c[1]==0x40) key_value=4;
        if(c[2]==0x04) key_value=5;
        if(c[2]==0x40) key_value=6;
        if(c[3]==0x04) key_value=7;
        if(c[3]==0x40) key_value=8;
        if(c[0]==0x02) key_value=9;
        if(c[0]==0x20) key_value=10;
        if(c[1]==0x02) key_value=11;
        if(c[1]==0x20) key_value=12;
        if(c[2]==0x02) key_value=13;
        if(c[2]==0x20) key_value=14;
        if(c[3]==0x02) key_value=15;
        if(c[3]==0x20) key_value=16;
        return (key_value);
网上的代码,显示没问题。
while (1)
        LedDisplay(1,3,7,0,2,1,0,2);
        delay_ms(1000);
                key_value=Read_key();
        switch (key_value)
                case 1:
                LedDisplay(1,0,0,0,0,0,0,0);
                break;
                case 2 :
                LedDisplay(2,0,0,0,0,0,0,0);
                break;
                case 3 :
                LedDisplay(3,0,0,0,0,0,0,0);
                break;
                case 4 :
                LedDisplay(4,0,0,0,0,0,0,0);
                break;
                case 5 :
                LedDisplay(5,0,0,0,0,0,0,0);
                break;
                case 6 :
                LedDisplay(6,0,0,0,0,0,0,0);
                break;
                case 7 :
                LedDisplay(7,0,0,0,0,0,0,0);
                break;
                case 8 :
                LedDisplay(8,0,0,0,0,0,0,0);
                break;
                case 9:
                LedDisplay(9,0,0,0,0,0,0,0);
                break;
                case 10 :
                LedDisplay(0,1,0,0,0,0,0,0);
                break;
                case 11 :
                LedDisplay(1,1,0,0,0,0,0,0);
                break;
                case 12 :
                LedDisplay(2,1,0,0,0,0,0,0);
                break;
                case 13 :
                LedDisplay(3,1,0,0,0,0,0,0);
                break;
                case 14 :
                LedDisplay(4,1,0,0,0,0,0,0);
                break;
                case 15:
                LedDisplay(5,1,0,0,0,0,0,0);
                break;
                case 16 :
                LedDisplay(6,1,0,0,0,0,0,0);
                break;
                default :
                break;//LedDisplay(0,0,0,0,0,0,0,0);
此帖出自stm32/stm8论坛
676
数码管显示的吗?  显示正常的话,写函数应该没问题,仿真看下读函数啊,还有读键的函数
显示正常,就是不读键盘。就是读不出来,读键的函数是骑飞驱动带的。网上有说读键应当输出转上拉输入,也转了 就是不行。我都想不通了,但一定是那个地方有问题。
1731
为嘛不找我们;读按键时候DIO必须接上拉电阻,注意DIO输出和输入的设置关系
tm1638 是块成品板子。DIO和CLK、STB都已经接了上拉电阻,有说 要把DIO设成开漏模式,也已经设了。还是不行。 RCC->APB2ENR|=1<<2;      //使能PORTA时钟
    GPIOA->CRL&=0XFFFF000F;
    GPIOA->CRL|=0X00007770;
  GPIOA->ODR|=1<<1;
如何找你们啊?
天微官网去看例程,很简单的,N年前玩过这个片子
已解决封贴。unsigned char TM1638_Read(void)                                        //¶áêy¾Yoˉêy
        unsigned char i;
        DIO=1;        //éèÖÃÎaêäèë
        for(i=0;i<8;i++)
        delay_us(5)        ;
                temp>>=1;
                CLK=0;
                if(DIO)这个改成if(GPIOA->IDR&0x0002= 0x0002)即可
                        temp|=0x80;
                CLK=1;
        return temp;
