883|0
3741
分享MSP430F149的ADC12模块实例 [复制链接]
single采样,参考电源为系统电源
1.设置ADC12CTL0,使ADC12通道0采样保持时间为16 ADC12CLK(SHT0_2),开启ADC12模块(ADC12ON);
2.设置ADC12CTL1,选择采样保持脉冲模式即SAMPCON为采样定时器(SHP)
3.设置ADC12IE,是通道0中断使能(0x01);
4.设置ADC12CTL0,使能AD转换(ENC)
5.设置模拟信号输入IO口P60
7.设置ADC12CTL0,开启AD转换(ADC12SC),等待中断
8.中断中读取通道0转换值ADC12MEM0
  ADC12CTL0 = SHT0_2 + ADC12ON;             // Set sampling time, turn on ADC12
  ADC12CTL1 = SHP;                          // Use sampling timer
  ADC12IE = 0x01;                           // Enable interrupt
  ADC12CTL0 |= ENC;                         // Conversion enabled
  P6SEL |= 0x01;                            // P6.0 ADC option select
  P2DIR |= 0x01;
ADC12CTL0 |= ADC12SC;
#pragma vector=ADC12_VECTOR
__interrupt void ADC12_ISR (void)
    if (ADC12MEM0 < 0x7FF)
      P2OUT = 0;                       // Clear P1.0 LED off
    else
      P2OUT = 0XFF;                        // Set P1.0 LED on
    __low_power_mode_off_on_exit();
    // 与上面等价_BIC_SR_IRQ(CPUOFF);                    // Clear CPUOFF bit from 0(SR)
4.2 single采样参考源为2.5V
在ADC12CTL0中设置参考源
在ADC12MCTL0中为通道0选择参考源
  ADC12CTL0 = ADC12ON+SHT0_2+REFON+REF2_5V; // Turn on and set up ADC12
  ADC12MCTL0 = SREF_1;                      // Vr+=Vref+
  for ( i=0; i<0x3600; i++);                  // Delay for reference start-up
  ADC12CTL0 |= ENC;
  while (1)
    ADC12CTL0 |= ADC12SC;                   // Start conversion
    while ((ADC12IFG & BIT0)==0);
    _NOP();                                 // SET BREAKPOINT HERE
4.3 Repeat-single采样,模拟输入为内部Temperature sensor
设置ADC12CTL1,采样保持源为定时器A,脉冲保持模式,Repeat-single模式
  ADC12CTL1 = SHS_1 + SHP + CONSEQ_2;       // TA trig., rpt conv.
设置ADC12MCTL0,通道0参考源为内部REF,模拟输入通道0选择为Temperature sensor
  ADC12MCTL0 = SREF_1 + INCH_10;            // Channel A10, Vref+
  ADC12IE = 0x01;                           // Enable ADC12IFG.0
  ADC12CTL0 = SHT0_8 + REF2_5V + REFON + ADC12ON + ENC; // Config ADC12
  TACCTL1 = OUTMOD_4;                       // Toggle on EQU1 (TAR = 0)
  TACTL = TASSEL_2 + MC_2;                  // SMCLK, cont-mode
  while (!(0x01 & ADC12IFG));               // First conversion?
  FirstADCVal = ADC12MEM0;                  // Read out 1st ADC value
  _BIS_SR(LPM0_bits + GIE);                 // Enter LPM0 w/ interrupt
__interrupt void ADC12ISR (void)
  if (ADC12MEM0 <= FirstADCVal + ADCDeltaOn)
      P1OUT &= ~0x01;                       // LED off
  else P1OUT |= 0x01;                       // LED on
摄氏温度和温度传感器电压转换关系:0摄氏度对应986mv,1摄氏度温差对应1.97mv温差
//  oF = ((x/4096)*1500mV)-923mV)*1/1.97mV = x*761/4096 - 468
//  IntDegF = (ADC12MEM0 - 2519)* 761/4096
    IntDegF = (temp - 2519) * 761;
    IntDegF = IntDegF / 4096;
//  oC = ((x/4096)*1500mV)-986mV)*1/3.55mV = x*423/4096 - 278
//  IntDegC = (ADC12MEM0 - 2692)* 423/4096
    IntDegC = (temp - 2692) * 423;
    IntDegC = IntDegC / 4096;
4.4 Repeat-sequence mode
Sequence模式时可以设置多个采样通道。在最后一个通道加上EOS就表明的采样通道结束位置。中断允许只需要设置最后一个通道。
为了采样速率尽可能快,可设置MSC,此时当SHI上升沿触发第一次采样后,后面的采样在上一次采样结束后自动进行。
  ADC12CTL0 = ADC12ON+MSC+SHT0_8;           // Turn on ADC12, extend sampling time
                                            // to avoid overflow of results
  ADC12CTL1 = SHP+CONSEQ_3;                 // Use sampling timer, repeated sequence
  ADC12MCTL0 = INCH_0;                      // ref+=AVcc, channel = A0
  ADC12MCTL1 = INCH_1;                      // ref+=AVcc, channel = A1
  ADC12MCTL2 = INCH_2;                      // ref+=AVcc, channel = A2
  ADC12MCTL3 = INCH_3+EOS;                  // ref+=AVcc, channel = A3, end seq.
  ADC12IE = 0x08;                           // Enable ADC12IFG.3
  ADC12CTL0 |= ENC;                         // Enable conversions
  _BIS_SR(LPM0_bits + GIE);                 // Enter LPM0, Enable interrupts
  static unsigned int index = 0;
  A0results[index] = ADC12MEM0;             // Move A0 results, IFG is cleared
  A1results[index] = ADC12MEM1;             // Move A1 results, IFG is cleared
  A2results[index] = ADC12MEM2;             // Move A2 results, IFG is cleared
  A3results[index] = ADC12MEM3;             // Move A3 results, IFG is cleared
  index = (index+1)%Num_of_Results;         // Increment results index, modulo; Set Breakpoint here
