1410|0
3741
TI官方代码中的任务状态机 [复制链接]
TI官方代码中的任务状态机
TI官方例程代码中的任务状态机用于处理各种不同的非环路控制任务,这种状态机编程对于多任务管理比较有用
  • // Timing sync for background loops
  • // Timer period definitions found in PeripheralHeaderIncludes.h
  •     CpuTimer0Regs.PRD.all =  mSec1;     // A tasks,200000,1ms,CPU frequency=200MHz
  •     CpuTimer1Regs.PRD.all =  mSec10;    // B tasks,2000000,10ms
  •     CpuTimer2Regs.PRD.all =  mSec100;   // C tasks,20000000,100ms
  • // Tasks State-machine init
  •     Alpha_State_Ptr = &A0;
然后在main函数里的while循环中写下如下代码:
  • //--------------------------------- FRAMEWORK -------------------------------------
  •     for(;;)  //infinite loop
  •         // State machine entry & exit point
  •         (*Alpha_State_Ptr)();   // jump to an Alpha state (A0,B0,...)
在main函数之外有:
  • void A0(void)
  •     // loop rate synchronizer for A-tasks
  •     if(CpuTimer0Regs.TCR.bit.TIF == 1)
  •         CpuTimer0Regs.TCR.bit.TIF = 1;  // clear flag
  •         (*A_Task_Ptr)();        // jump to an A Task (A1,A2,A3,...)
  •     Alpha_State_Ptr = &B0;      // Comment out to allow only A tasks
  • void B0(void)
  •     // loop rate synchronizer for B-tasks
  •     if(CpuTimer1Regs.TCR.bit.TIF == 1)
  •         CpuTimer1Regs.TCR.bit.TIF = 1;  // clear flag
  •         (*B_Task_Ptr)();        // jump to a B Task (B1,B2,B3,...)
  •     Alpha_State_Ptr = &C0;      // Allow C state tasks
  • void C0(void)
  •     // loop rate synchronizer for C-tasks
  •     if(CpuTimer2Regs.TCR.bit.TIF == 1)
  •         CpuTimer2Regs.TCR.bit.TIF = 1;  // clear flag
  •         (*C_Task_Ptr)();        // jump to a C Task (C1,C2,C3,...)
  •     Alpha_State_Ptr = &A0;      // Back to State A0
任务A:
  • void A1(void)
  •         do something
  •     //the next time CpuTimer0 'counter' reaches Period value go to A2
  •     A_Task_Ptr = &A2;
  • void A2(void)
  •         do something
  •     //the next time CpuTimer0 'counter' reaches Period value go to A3
  •     A_Task_Ptr = &A3;
  • void A3(void)
  •         do something
  •     //the next time CpuTimer0 'counter' reaches Period value go to A4
  •     A_Task_Ptr = &A4;
  • void A4(void)
  •         do nothing
  •     //the next time CpuTimer0 'counter' reaches Period value go to A1
  •     A_Task_Ptr = &A1;
任务B和C的细分也类似于A,同上
