社区导航
搜索
查看: 1403|回复: 1
[设计过程分享] 体感手套 #4 简单蓝牙连接手机程序测试通过
238
TA的帖子
Rank: 2
发表于 2017-9-21 13:37 | 显示全部楼层 |阅读模式
1. 在这个连接的过程,需要使用控制手机VR的连接方式,所以需要连接手机。这里采用cordova plugin的方式编程,测试简单串口连接OK。
具体硬件是和上贴一样,计算机USB-ttl连接HC-06模块。
2. 其中要先定义mac的数值,并通过扫描获得MAC地址,这样在后面可以选择正确的模块连接,如果模块多,就先扫描,然后把获得的MAC赋值后连接
var app = {
    macAddress: "98:D3:32:30:8F:C4",  // get your mac address from bluetoothSerial.list
    chars: "",
连接成功的截图如下:
Screenshot_2017-09-21-12-23-45.png 3. 事实上,这样的连接其实并不可靠,不是每次都可以顺利连接,需要多测试几次才能够。不过这个是蓝牙模块的性能问题,连接测试功能是通过了
4. 软件如下,
  1. var app = {
  2.     macAddress: "98:D3:32:30:8F:C4",  // get your mac address from bluetoothSerial.list
  3.     chars: "",                //macAddress: "98:D3:32:10:97:2C",macAddress: "98:D3:32:30:8F:C4",
  4. /*
  5.     Application constructor
  6. */
  7.     initialize: function() {
  8.         this.bindEvents();
  9.         console.log("Starting SimpleSerial app");
  10.     },
  11. /*
  12.     bind any events that are required on startup to listeners:
  13. */
  14.     bindEvents: function() {
  15.         document.addEventListener('deviceready', this.onDeviceReady, false);
  16.         connectButton.addEventListener('touchend', app.manageConnection, false);
  17.     },
  18. /*
  19.     this runs when the device is ready for user interaction:
  20. */
  21.     onDeviceReady: function() {
  22.         // check to see if Bluetooth is turned on.
  23.         // this function is called only
  24.         //if isEnabled(), below, returns success:
  25.         var listPorts = function() {
  26.             // list the available BT ports:
  27.             bluetoothSerial.list(
  28.                 function(results) {
  29.                     app.display(JSON.stringify(results));
  30.                 },
  31.                 function(error) {
  32.                     app.display(JSON.stringify(error));
  33.                 }
  34.             );
  35.         }
  36.         // if isEnabled returns failure, this function is called:
  37.         var notEnabled = function() {
  38.             app.display("Bluetooth is not enabled.")
  39.         }
  40.          // check if Bluetooth is on:
  41.         bluetoothSerial.isEnabled(
  42.             listPorts,
  43.             notEnabled
  44.         );
  45.     },
  46. /*
  47.     Connects if not connected, and disconnects if connected:
  48. */
  49.     manageConnection: function() {
  50.         // connect() will get called only if isConnected() (below)
  51.         // returns failure. In other words, if not connected, then connect:
  52.         var connect = function () {
  53.             // if not connected, do this:
  54.             // clear the screen and display an attempt to connect
  55.             app.clear();
  56.             app.display("Attempting to connect. " +
  57.                 "Make sure the serial port is open on the target device.");
  58.             // attempt to connect:
  59.             bluetoothSerial.connect(
  60.                 app.macAddress,  // device to connect to
  61.                 app.openPort,    // start listening if you succeed
  62.                 app.showError    // show the error if you fail
  63.             );
  64.         };
  65.         // disconnect() will get called only if isConnected() (below)
  66.         // returns success  In other words, if  connected, then disconnect:
  67.         var disconnect = function () {
  68.             app.display("attempting to disconnect");
  69.             // if connected, do this:
  70.             bluetoothSerial.disconnect(
  71.                 app.closePort,     // stop listening to the port
  72.                 app.showError      // show the error if you fail
  73.             );
  74.         };
  75.         // here's the real action of the manageConnection function:
  76.         bluetoothSerial.isConnected(disconnect, connect);
  77.     },
  78. /*
  79.     subscribes to a Bluetooth serial listener for newline
  80.     and changes the button:
  81. */
  82.     openPort: function() {
  83.         // if you get a good Bluetooth serial connection:
  84.         app.display("Connected to: " + app.macAddress);
  85.         // change the button's name:
  86.         connectButton.innerHTML = "Disconnect";
  87.         // set up a listener to listen for newlines
  88.         // and display any new data that's come in since
  89.         // the last newline:
  90.         bluetoothSerial.subscribe('\n', function (data) {
  91.             app.clear();
  92.             app.display(data);
  93.         });
  94.     },
  95. /*
  96.     unsubscribes from any Bluetooth serial listener and changes the button:
  97. */
  98.     closePort: function() {
  99.         // if you get a good Bluetooth serial connection:
  100.         app.display("Disconnected from: " + app.macAddress);
  101.         // change the button's name:
  102.         connectButton.innerHTML = "Connect";
  103.         // unsubscribe from listening:
  104.         bluetoothSerial.unsubscribe(
  105.                 function (data) {
  106.                     app.display(data);
  107.                 },
  108.                 app.showError
  109.         );
  110.     },
  111. /*
  112.     appends [url=home.php?mod=space&uid=40873]@error[/url] to the message div:
  113. */
  114.     showError: function(error) {
  115.         app.display(error);
  116.     },
  117. /*
  118.     appends [url=home.php?mod=space&uid=146195]@message[/url] to the message div:
  119. */
  120.     display: function(message) {
  121.         var display = document.getElementById("message"), // the message div
  122.             lineBreak = document.createElement("br"),     // a line break
  123.             label = document.createTextNode(message);     // create the label
  124.         display.appendChild(lineBreak);          // add a line break
  125.         display.appendChild(label);              // add the message node
  126.     },
  127. /*
  128.     clears the message div:
  129. */
  130.     clear: function() {
  131.         var display = document.getElementById("message");
  132.         display.innerHTML = "";
  133.     }
  134. };      // end of app
复制代码
来源:EEWorld MAX32630FTHR设计大赛专区板块,转载请附上链接
使用道具 举报
9424
TA的帖子
133
管理员
Rank: 13Rank: 13Rank: 13Rank: 13
发表于 2017-9-21 15:51 | 显示全部楼层
汇总贴在此:
体感手套—by 北方
http://bbs.eeworld.com.cn/thread-564975-1-1.html
玩板看这里:
http://bbs.eeworld.com.cn/elecplay.html
使用道具 举报
站长推荐上一条 /5 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-9-22 22:15 , Processed in 0.111180 second(s), 18 queries , Gzip On, MemCache On.
