MAX32630FTHR设计笔记(10):MAX32630本身存在问题:AD通道切换引起的干扰
MAX32630的10位AD有多个通道,每个通道共用一个寄存器,如图
我在调试的时候使用1个通道AIN0的时候,用示波器查看波形并没有问题,但是在使用AIN0和AIN1时就出现问题,代码程序如下:
- void TMR0_IRQHandler(void)
- static uint8_t ADC_GET_Time=0;
- ADC_GET_Time++;
- if(ADC_GET_Time % 10==0)
- adc_Channel=2;
- //ADC0_StartConvert(ADC_CH_0, 0, 1,4); //¿aê¼ADC0×a»»
- //ADC_StartConvert(ADC_CH_0_DIV_5, 0, 0);
- ADC_StartConvert(ADC_CH_0, 0, 0);
- ADC_GET_Time = 1;
- else if((ADC_GET_Time % 2==0)&&(adc_Channel==0))
- adc_Channel=1;
- //ADC0_StartConvert(ADC_CH_1, 0, 1,5); //¿aê¼ADC0×a»»
- ADC_StartConvert(ADC_CH_1, 0, 0);
- //ADC_StartConvert(ADC_CH_1_DIV_5, 0, 0);
- TMR32_ClearFlag(MXC_TMR0);
复制代码
程序的功能是用定时器计时切换AD通道,切换周期为10ms,其他程序如下:
- #define USE_INTERRUPTS 1
- //#undef USE_INTERRUPTS
- /***** Globals *****/
- //#ifdef USE_INTERRUPTS
- volatile unsigned int adc_Channel = 0;
- //#endif
- /***** Functions *****/
- #ifdef USE_INTERRUPTS
- void AFE_IRQHandler(void)
- uint16_t ADC_Value_Temp=0;
- ADC_GetData(&ADC_Value_Temp);
- /* Signal bottom half that data is ready */
- if(adc_Channel == 1)
- //LED1_OFF;
- Get_ADC1_Data(ADC_Value_Temp);
- else if(adc_Channel == 2)
- Get_ADC2_Data(ADC_Value_Temp);
- adc_Channel = 0;
- // LED0_TURN;
- ADC_ClearFlags(MXC_F_ADC_INTR_ADC_DONE_IF);
- return;
- #endif
- void ADC0_Init()
- /* Initialize ADC */
- ADC_Init();
- // NVIC_EnableIRQ(AFE_IRQn);
- NVIC_ClearPendingIRQ(AFE_IRQn);
- NVIC_DisableIRQ(AFE_IRQn);
- NVIC_SetPriority(AFE_IRQn, 1);
- NVIC_EnableIRQ(AFE_IRQn);
- #endif
- void ADC0_StartConvert(mxc_adc_chsel_t channel, unsigned int adc_scale, unsigned int bypass, uint32_t mode)
- uint32_t ctrl_tmp;
- /* Clear the ADC done flag */
- /* Enable done interrupt */
- MXC_ADC->intr = MXC_F_ADC_INTR_ADC_DONE_IE;
- /* Insert channel selection */
- ctrl_tmp = MXC_ADC->ctrl;
- ctrl_tmp &= ~(MXC_F_ADC_CTRL_ADC_CHSEL);
- ctrl_tmp |= ((channel << MXC_F_ADC_CTRL_ADC_CHSEL_POS) | (mode<<MXC_F_ADC_CTRL_ADC_CHSEL_POS));
- //ctrl_tmp |= ((channel << MXC_F_ADC_CTRL_ADC_CHSEL_POS) & MXC_F_ADC_CTRL_ADC_CHSEL);
- /* Clear channel configuration */
- ctrl_tmp &= ~(MXC_F_ADC_CTRL_ADC_REFSCL | MXC_F_ADC_CTRL_ADC_SCALE | MXC_F_ADC_CTRL_BUF_BYPASS);
- /* ADC reference scaling must be set for all channels but two*/
- if ((channel != ADC_CH_VDD18) && (channel != ADC_CH_VDD12)) {
- ctrl_tmp |= MXC_F_ADC_CTRL_ADC_REFSCL;
- /* Finalize user-requested channel configuration */
- if (adc_scale || channel > ADC_CH_3) {
- ctrl_tmp |= MXC_F_ADC_CTRL_ADC_SCALE;
- if (bypass) {
- ctrl_tmp |= MXC_F_ADC_CTRL_BUF_BYPASS;
- /* Write this configuration */
- MXC_ADC->ctrl = ctrl_tmp;
- /* Start conversion */
- MXC_ADC->ctrl |= MXC_F_ADC_CTRL_CPU_ADC_START;
复制代码
这个问题美信技术支持也没有解决,这个问题无法避免,但是还是可以解决的,先来看现象
图1
图2
图3
从图2和图3可以看出,杂波出现的周期刚好是10ms一次,所以我们可以这样处理,(1)降采样;(2)延时10ms以上采样(具体看你切换的时间周期)
