社区导航
搜索
查看: 15035|回复: 6
[讨论] (已解决)SensorTile下载出现Can not attach to CPU. Trying connect under reset.
7361
TA的帖子
Rank: 6Rank: 6
发表于 2017-2-14 17:10 | 显示全部楼层 |阅读模式
下午在用SensorTile调试Beacon程序使用STM32CubeExpansion_BLE1_V2.8.0\Projects\Multi\Applications\Beacon例程
很顺利,已经能通过BLE发送广播数据
ANDROID也可以正常接收
于是小睡一觉
醒来后简单修改了几段程序
再用IAR下载时就提示错误
试了很多次,重启了电脑也不行
又用MDK的设置看一下能不能找到芯片
结果选择SWD的时候就卡一会,然后MDK就会退出
几次都是这样
这些操作曾经都是好用的
于是又使用SEGGER文件夹里的J-Flash Lite试试
原来也是好用的
现在J-Flash Lite提示
Device "STM32L476RG" selected.
Found SWD-DP with ID 0x2BA01477
STM32 (connect): Can not attach to CPU. Trying connect under reset.
STM32: Connecting to CPU via connect under reset failed.
能找到单片机,可就是下载不了
最后看到“under reset”这段
在点下载前先按住开发板上的RESET键
点击下载
然后松开RESET键看到错误信息不一样了
Downloading D:\10.stsensor\2.code\STSW-STLKT01\Utilities\BootLoader\STM32L476RG\BootLoaderL4.bin to STM32L476RG via SWD-Interface@1000kHz
Programming Thread started.
AP-IDR: 0x24770011, Type: AHB-AP
Found Cortex-M4 r0p1, Little endian.
FPUnit: 6 code (BP) slots and 2 literal slots
CoreSight components:
ROMTbl 0 @ E00FF000
ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM
STM32 (connect): Timeout while waiting for CPU to halt after reset. Manually halting CPU.
Debugger initialized successfully.
J-Link: Flash download: Flash programming performed for 1 range (6144 bytes)
J-Link: Flash download: Total time needed: 0.345s (Prepare: 0.120s, Compare: 0.007s, Erase: 0.068s, Program: 0.136s, Verify: 0.001s, Restore: 0.010s)
Programming Thread exited
Programming failed.
再点下载提示成功
ROMTbl 0 @ E00FF000
J-Link: Flash download: Flash download skipped. Flash contents already match
Programming done
再用IAR和MDK就都可以正常下载了
又下载了Beacon例程
然后又出现这个问题
顿时天空漂过5个字儿“低功耗"
虾扯蛋
使用道具 举报
913
TA的帖子
Rank: 3Rank: 3
发表于 2017-2-14 17:53 | 显示全部楼层
是不是程序把swd接口的引脚给禁掉了?
例程里设置了STOP模式 单片机进入低功耗了  详情 回复 发表于 2017-2-14 20:46
作为一个菜逼,干货并没有多少。唯一会的就是水,所以回帖水分大。望见谅!
使用道具 举报
2938
TA的帖子
Rank: 4
发表于 2017-2-14 18:31 | 显示全部楼层
复位,重新上电后下载
低功耗模式只能这样下载 一般是在上电没进入低功耗前加些延时  详情 回复 发表于 2017-2-14 20:49
使用道具 举报
7361
TA的帖子
Rank: 6Rank: 6
 楼主| 发表于 2017-2-14 20:46 来自手机 | 显示全部楼层
使用道具 举报
7361
TA的帖子
Rank: 6Rank: 6
 楼主| 发表于 2017-2-14 20:49 来自手机 | 显示全部楼层
低功耗模式只能这样下载
一般是在上电没进入低功耗前加些延时
使用道具 举报
TA的帖子
Rank: 1
发表于 2017-2-15 10:38 | 显示全部楼层
应该是上电后进了低功耗
使用道具 举报
TA的帖子
Rank: 2
发表于 2017-2-15 10:43 | 显示全部楼层
低功耗的话可以这样来做:
1、上电后把Reset拉低
2、等到SDK软件提示下载进度框,马上把Reset电平拉高,就可以正常下载了。
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
词云| Archiver|手机版|小黑屋|电子工程世界 ( 京ICP证 060456 )
GMT+8, 2020-7-13 10:04 , Processed in 0.233182 second(s), 28 queries , Gzip On, MemCache On.
