回复: C语言笔试大全
//快速排序
#i nclude<iostream>
usingnamespacestd;
intPartition (int*L,intlow,int high)
inttemp = L[low];
intpt = L[low];
while (low < high)
while (low < high && L[high] >= pt)
--high;
L[low] = L[high];
while (low < high && L[low] <= pt)
++low;
L[low] = temp;
L[low] = temp;
returnlow;
voidQSort (int*L,intlow,int high)
if (low < high)
intpl = Partition (L,low,high);
QSort (L,low,pl - 1);
QSort (L,pl + 1,high);
intmain ()
intnarry[100],addr[100];
intsum = 1,t;
cout << "Input number:" << endl;
cin >> t;
while (t != -1)
narry[sum] = t;
addr[sum - 1] = t;
sum++;
cin >> t;
sum -= 1;
QSort (narry,1,sum);
for (int i = 1; i <= sum;i++)
cout << narry << '\t';
cout << endl;
intk;
cout << "Please input place you want:" << endl;
cin >> k;
intaa = 1;
intkk = 0;
for (;;)
if (aa == k)
break;
if (narry[kk] != narry[kk + 1])
aa += 1;
kk++;
cout << "The NO." << k << "number is:" << narry[sum - kk] << endl;
cout << "And it's place is:" ;
for (i = 0;i < sum;i++)
if (addr == narry[sum - kk])
cout << i << '\t';
return0;
1、找错
Void test1()
char string[10];
char* str1="0123456789";
strcpy(string, str1);// 溢出,应该包括一个存放'\0'的字符string[11]
Void test2()
char string[10], str1[10];
for(I=0; I<10;I++)
str1 ='a';
strcpy(string, str1);// I,i没有声明。
Void test3(char* str1)
char string[10];
if(strlen(str1)<=10)// 改成<10,字符溢出,将strlen改为sizeof也可以
2.
void g(int**);
int main()
int line[10],i;
int *p=line; //p是地址的地址
for (i=0;i<10;i++)
*p=i;
g(&p);//数组对应的值加1
for(i=0;i<10;i++)
printf("%d\n",line);
return 0;
void g(int**p)
(**p)++;
(*p)++;// 无效
输出:
3. 写出程序运行结果
int sum(int a)
auto int c=0;
static int b=3;
c+=1;
b+=2;
return(a+b+c);
void main()
int I;
int a=2;
for(I=0;I<5;I++)
printf("%d,", sum(a));
// static会保存上次结果,记住这一点,剩下的自己写
输出:8,10,12,14,16,
4.
int func(int a)
int b;
switch(a)
case 1: 30;
case 2: 20;
case 3: 16;
default: 0
return b;
则func(1)=?
// b定义后就没有赋值。
5:
int a[3];
a[0]=0; a[1]=1; a[2]=2;
int *p, *q;
p=a;
q=&a[2];
则a[q-p]=a[2]
解释:指针一次移动一个int但计数为1
今天早上的面试题9道,比较难,向牛人请教,国内的一牛公司,坐落在北京北四环某大厦:
1、线形表a、b为两个有序升序的线形表,编写一程序,使两个有序线形表合并成一个有序升序线形表h;
答案在 请化大学 严锐敏《数据结构第二版》第二章例题,数据结构当中,这个叫做:两路归并排序
Linklist *unio(Linklist *p,Linklist *q){
linklist *R,*pa,*qa,*ra;
pa=p;
qa=q;
R=ra=p;
while(pa->next!=NULL&&qa->next!=NULL){
if(pa->data>qa->data){
ra->next=qa;
qa=qa->next;
else{
ra->next=pa;
pa=pa->next;
if(pa->next!=NULL)
ra->next=pa;
if(qa->next!=NULL)
ra->next==qa;
return R;
2、运用四色定理,为N个局域举行配色,颜色为1、2、3、4四种,另有数组adj[][N],如adj[j]=1则表示i区域与j区域相邻,数组color[N],如color=1,表示i区域的颜色为1号颜色。
四色填充
3、用递归算法判断数组a[N]是否为一个递增数组。
递归的方法,记录当前最大的,并且判断当前的是否比这个还大,大则继续,否则返回false结束:
bool fun( int a[], int n )
if( n= =1 )
return true;
if( n= =2 )
return a[n-1] >= a[n-2];
return fun( a,n-1) && ( a[n-1] >= a[n-2] );
4、编写算法,从10亿个浮点数当中,选出其中最大的10000个。
用外部排序,在《数据结构》书上有
《计算方法导论》在找到第n大的数的算法上加工
5、编写一unix程序,防止僵尸进程的出现.
同学的4道面试题,应聘的职位是搜索引擎工程师,后两道超级难,(希望大家多给一些算发)
1.给两个数组和他们的大小,还有一动态开辟的内存,求交集,把交集放到动态内存dongtai,并且返回交集个数
long jiaoji(long* a[],long b[],long* alength,long blength,long* dongtai[])
2.单连表的建立,把'a'--'z'26个字母插入到连表中,并且倒叙,还要打印!
方法1:
typedef struct val
{ int date_1;
struct val *next;
}*p;
void main(void)
{ char c;
for(c=122;c>=97;c--)
{ p.date=c;
p=p->next;
p.next=NULL;
方法2:
node *p = NULL;
node *q = NULL;
node *head = (node*)malloc(sizeof(node));
head->data = ' ';head->next=NULL;
node *first = (node*)malloc(sizeof(node));
first->data = 'a';first->next=NULL;head->next = first;
p = first;
int longth = 'z' - 'b';
int i=0;
while ( i<=longth )
node *temp = (node*)malloc(sizeof(node));
temp->data = 'b'+i;temp->next=NULL;q=temp;
head->next = temp; temp->next=p;p=q;
i++;
print(head);
1.这样的初始化有什么问题?char *p = malloc(10); 编译器提示“非法初始式” 云云。
答:这个声明是静态或非局部变量吗?函数调用只能出现在自动变量(即局部非静态变量) 的初始式中。
因为静态变量的地址必须在编译的过程中就确定下来而malloc()申请的内存地址是在运行时确定的。
2. *p++ 自增p 还是p 所指向的变量?
答:后缀++ 和-- 操作符本质上比前缀一目操作的优先级高, 因此*p++ 和*(p++) 等价, 它自增p 并返回p 自增之前所指向的值。
要自增p 指向的值, 使用(*p)++, 如果副作用的顺序无关紧要也可以使用++*p。
3 我有一个char * 型指针正巧指向一些int 型变量, 我想跳过它们。为什么如下的代码((int *)p)++; 不行?
答:在C 语言中, 类型转换意味着“把这些二进制位看作另一种类型, 并作相应的对待”; 这是一个转换操作符,
根据定义它只能生成一个右值(rvalue)。而右值既不能赋值, 也不能用++ 自增。(如果编译器支持这样的扩展,
那要么是一个错误, 要么是有意作出的非标准扩展。) 要达到你的目的可以用:p = (char *)((int *)p + 1);
或者,因为p 是char * 型, 直接用p += sizeof(int);
4.空指针和未初始化的指针是一回事吗?
答:空指针在概念上不同于未初始化的指针:空指针可以确保不指向任何对象或函数;
而未初始化指针则可能指向任何地方。
5.我可以用0来表示空指针吗?
答:根据语言定义, 在指针上下文中的常数0 会在编译时转换为空指针。也就是说, 在初始化、赋值或比较的时候,
如果一边是指针类型的值或表达式, 编译器可以确定另一边的常数0 为空指针并生成正确的空指针值。因此下边的代码段完全合法:
char *p = 0;
if(p != 0)
然而, 传入函数的参数不一定被当作指针环境, 因而编译器可能不能识别未加修饰的0 “表示” 指针。
在函数调用的上下文中生成空指针需要明确的类型转换,强制把0 看作指针。
例如, Unix 系统调用execl 接受变长的以空指针结束的字符指针参数。它应该如下正确调用:
execl("/bin/sh", "sh", "-c", "date", (char *)0);
如果省略最后一个参数的(char *) 转换, 则编译器无从知道这是一个空指针,从而当作一个0 传入。(注意很多Unix 手册在这个例子上都弄错了。)
摘要:
|| 可以使用未加修饰的0 | 需要显示的类型转换 ||
|| *初始化 | *函数调用, 作用域内无原型 ||
|| *赋值 | *变参函数调用中的可变参数 ||
|| *比较 | ||
|| *固定参数的函数调用 | ||
|| 且在作用域内有原型 | ||
有两条简单规则你必须遵循:
1) 当你在源码中需要空指针常数时, 用“0” 或“NULL”。
2) 如果在函数调用中“0” 或“NULL” 用作参数, 把它转换成被调函数需要的指针类型 |
