933|0
FDB光纤终端盒
FDB-FTB016 Type Optical Termination Box
FDB-FTB016 Type Optical Termination Box is designed to connect feeder/distribution cable to subscriber's
drop cable using PLC splitter in FTTx networks. NT- FTB011 has 2 input ports and 16 output ports on the bottom
and it is easy to install on the wall or pole. The rear tray is for splicing a fiber of feeder cable with PLC splitter and
the front tray is for connecting subscriber's drop cable through adaptor plate on the tray.
1) User familiar industry interface, using high impact plastic 2) Can accommodate 1x8 PLC splitter and 1x16 PLC splitter 3) Ultra violet resistant and rainfall resistant 4) Up to 16 FTTH drops 5) Wall and pole mountable 6) 2 inlet ports, 16 outlet ports
Specifications
ITEM Values Dimensions L : 225 ㎜, W : 302 ㎜, H : 71 ㎜ Weight 1.3 ㎏ Cable input port Max. 2 ports (Max. dia. : 12 ㎜) Cable output capacity Max. 16 ports (Max. dia. : 3 ㎜) Max. capacity 12 core Operation Temperature -40 ~ +85℃ Tensile Strength ≥ 450 ㎏/㎠, @10 ㎜/min OTB Resin Impact Strength 35 ㎏㎝/㎠ (normal temp.), 10 ㎏㎝/㎠ (-30℃) Flexural Strength ≥ 450 ㎏/㎠, @10 ㎜/min
FDB盒.pdf
249.28 KB, 下载次数: 0
