社区导航
搜索
查看: 2211|回复: 2
[求助] WinDriver Error 0x2000000b - Kernel PlugIn failure?谁知道怎么回事啊
TA的帖子
Rank: 1
发表于 2017-2-5 17:14 | 显示全部楼层 |阅读模式
WinDriver Debug Monitor v10.00.
Running WinDriver v10.00 Jungo (c) 1997 - 2008 Build Date: Jan 20 2009 X86 32bit SYS 11:48:08
OS: Windows NT 5.1 Build 0.0.2600 Service Pack 3
Time: DÇÆúèÕ ¶tÔÂ 5 16:39:09 2017
WDC_DriverOpen: user mode version - WinDriver v10.00 Jungo (c) 1997 - 2008 Build Date: Jan 20 2009 X86 32bit
New license options 0x0_0x40000000
WDC_PciScanDevices entered
Do_pci_scan: entered, search VID 2011, search DID 8534, options 0
Unmap_physical_mem_krnl: entered, linear addr 0xb9eee000, length 0x1000, context 00000000
Unmap_physical_mem_krnl - leaving
Map_physical_mem_krnl: entered, physical addr 0xf8018000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf8018000, bus type 0, bus num 0
Cpu_memory_address: success. physical addr 0xf8018000, translated 0xf8018000
Map_physical_mem_krnl: success, linear addr 0xb9f82000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f82000, length 0x1000, context 00000000
Map_physical_mem_krnl: entered, physical addr 0xf80d8000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf80d8000, bus type 0, bus num 0
Cpu_memory_address: success. physical addr 0xf80d8000, translated 0xf80d8000
Map_physical_mem_krnl: success, linear addr 0xb9ed3000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ed3000, length 0x1000, context 00000000
Map_physical_mem_krnl: entered, physical addr 0xf80e0000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf80e0000, bus type 0, bus num 0
Cpu_memory_address: success. physical addr 0xf80e0000, translated 0xf80e0000
Map_physical_mem_krnl: success, linear addr 0xb9f0e000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f0e000, length 0x1000, context 00000000
Map_physical_mem_krnl: entered, physical addr 0xf80e2000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf80e2000, bus type 0, bus num 0
Cpu_memory_address: success. physical addr 0xf80e2000, translated 0xf80e2000
Map_physical_mem_krnl: success, linear addr 0xb9ecd000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ecd000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ef8000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ef8000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ed5000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ed5000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9f77000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f77000, length 0x1000, context 00000000
Map_physical_mem_krnl: entered, physical addr 0xf80e4000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf80e4000, bus type 0, bus num 0
Cpu_memory_address: success. physical addr 0xf80e4000, translated 0xf80e4000
Map_physical_mem_krnl: success, linear addr 0xb9f6b000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f6b000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ef2000, kernel_con
text 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ef2000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ed1000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ed1000, length 0x1000, context 00000000
Map_physical_mem_krnl: entered, physical addr 0xf8300000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf8300000, bus type 0, bus num 0
Cpu_memory_address: success. physical addr 0xf8300000, translated 0xf8300000
Map_physical_mem_krnl: success, linear addr 0xb9f6f000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f6f000, length 0x1000, context 00000000
Map_physical_mem_krnl: entered, physical addr 0xf8400000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf8400000, bus type 0, bus num 0
Cpu_memory_address: success. physical addr 0xf8400000, translated 0xf8400000
Map_physical_mem_krnl: success, linear addr 0xb9f81000, kernel_context 00000000
Do_pci_scan: found 1 cards
PciScanDevices: PCI bus scanned successfully.
Found 1 matching cards (vendor ID 0x2011, device ID 0x8534)
Do_pci_card: entered 4.0.0
pci_get_supported_interrupt_types: MSI capability found
pci_get_supported_interrupt_types: Line based interrupts found
pci_read_resources: hdr type 0
Do_pci_card: found 3 items
Do_pci_scan: entered, search VID 0, search DID 0, options 0
Unmap_physical_mem_krnl: entered, linear addr 0xb9f81000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9f92000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f92000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ece000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ece000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9fad000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9fad000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ec7000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ec7000, length 0x1000, context 00000000
num 0
Map_physical_mem_krnl: success, linear addr 0xb9f96000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f96000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ef5000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ef5000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9f9b000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f9b000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9f9c000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f9c000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9ee5000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9ee5000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9f01000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9f01000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9fb1000, kernel_context 00000000
Unmap_physical_mem_krnl: entered, linear addr 0xb9fb1000, length 0x1000, context 00000000
Map_physical_mem_krnl: success, linear addr 0xb9fa8000, kernel_context 00000000
Do_pci_scan: found 19 cards
Do_card_lock: entered
Do_card_lock: target bus [5] specified
Table_add (card): new handle 1
pci_register_card: registering PCI on 4.0.0
Do_card_lock: item 1, interrupt 16
Do_install_irq: entered, hCard=1
Table_add (irq): new handle 1
Do_install_irq: level 0x10, vector 0x0, affinity 0x0
Do_install_irq: success, hInterrupt 1
Do_card_lock: item 2, bar 0, memory range 0xf0001000-0xf0001fff, options 0x0
Map_physical_mem_krnl: entered, physical addr 0xf0001000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf0001000, bus type 5, bus num 4
Cpu_memory_address: success. physical addr 0xf0001000, translated 0xf0001000
Map_physical_mem_krnl: success, linear addr 0xb9eef000, kernel_context 00000000
Map_physical_mem_user: entered, physical addr 0xf0001000, length 0x1000
Map_physical_mem_user: ZwOpenSection() returned handle 0x17c0
Map_physical_mem_user: ObReferenceObjectByHandle() returned handle 0xe1000c70
Map_physical_mem_user: success, user addr 0x9a1000
Do_card_lock: item 3, bar 2, memor
y range 0xf0000000-0xf0000fff, options 0x0
Map_physical_mem_krnl: entered, physical addr 0xf0000000, length 0x1000
Cpu_memory_address: entered, physical addr 0xf0000000, bus type 5, bus num 4
Cpu_memory_address: success. physical addr 0xf0000000, translated 0xf0000000
Map_physical_mem_krnl: success, linear addr 0xb9f97000, kernel_context 00000000
Map_physical_mem_user: entered, physical addr 0xf0000000, length 0x1000
Map_physical_mem_user: success, user addr 0x9b0000
Do_card_lock: success, hCard=1
KP_Open: entered
Table_add (kerplug): new handle 1
KP_OpenDriver: entered, name KP_PCIE8
KP_OpenDriver: cannot get device handle, status 0xc0000034
KP_Open: failed opening kernel plugin driver
Table_remove_general (kerplug): removed handle 1
Do_card_unlock: entered, hCard 1, last 1
Card_close_handle: hCard 1
Card_close_handle: un-registering item 1 interrupt 16
Irq_close_handle: entered, hInterrupt 1
Irq_disable: received 0 interrupts called 0 dpc Lost count 0
Table_remove_general (irq): removed handle 1
Card_close_handle: un-registering item 2 memory 0xf0001000-0xf0001fff
Unmap_physical_mem_user: entered, base addr 009A1000, mem section E1000C70
Unmap_physical_mem_krnl: entered, linear addr 0xb9eef000, length 0x1000, context 00000000
Card_close_handle: un-registering item 3 memory 0xf0000000-0xf0000fff
Unmap_physical_mem_user: entered, base addr 009B0000, mem section E1000C70
Unmap_physical_mem_krnl: entered, linear addr 0xb9f97000, length 0x1000, context 00000000
Card_close_handle: success
Table_remove_general (card): removed handle 1
WDC_PciDeviceOpen failed: Failed opening a Kernel PlugIn handle. Error 0x2000000b - Kernel PlugIn failure
使用道具 举报
615
TA的帖子
103
Rank: 5Rank: 5
发表于 2017-2-8 00:41 | 显示全部楼层
你用的什么系统呀,WinDriver支持的系统要求是Windows NT 5.1 Build 0.0.2600 Service Pack 3。即Windows XP SP3
使用道具 举报
TA的帖子
Rank: 1
发表于 2017-7-24 20:29 | 显示全部楼层
请问楼主这个问题解决了吗?我也是和你遇到了同样的问题?
使用道具 举报
站长推荐上一条 /7 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-2-27 03:39 , Processed in 0.125340 second(s), 17 queries , Gzip On, MemCache On.
