3523|28
7548
MSP430FR5969驱动LIS3DSH三轴加速度传感器
LIS3DSH最小评估板焊好很长时间了
前几天一直在调试AD9102
今天抽空用MSP430FR5969测试了一下LIS3DSH
很容易调通
为了方便实时查看波形
改了一个上位机程序
结果上位机出了点问题花了很长时间
最后总算把数据显示出来了
效果还可以
LIS3DSHMSP430FR5969代码
只做了简单配置
使用轮询读取
 * Copyright (C), 2017, XiaCheDan Tech. Co., Ltd.
 * FileName: main.c
 * Author: littleshrimp
 * Version : 1.0
 * Date:  2017-1-22 11:13
 * Description:
 * Function List: //
 * 1. -------
 * History:
 * <author>   <time>                <version >  <desc>
 * littleshrimp      2017-1-22 11:13  1.0         build this moudle
                              MSP430FR5969
                           |     P2.0/UCA0TXD|----> PC
                           |     P2.1/UCA0RXD|<---- PC
               SCL --o--|P3.5                |
               SDA --o--|P3.6                |
 *  * INCLUDES
#include "msp430.h"
#include <stdio.h>
#include <stdint.h>
#include "uart.h"
#include "soft_i2c.h"
#include "timer.h"
 *  * MACROS
 *  * CONSTANTS
#define BASE64        0
#define STRING        0
 *  * TYPEDEFS
 *  * GLOBAL VARIABLES
 *  * EXTERNAL VARIABLES
 *  * EXTERNAL FUNCTIONS
 *  * LOCAL VARIABLES
uint8_t data[3];
uint16_t temp_code;
float temperature;
uint8_t crc;
 *  * PROFILE CALLBACKS
 *  * LOCAL FUNCTIONS
 *  * PUBLIC FUNCTIONS
#define LIS3DSH_SLAVE_ADDR     (0x1E << 1)//7bit
#define LIS3DSH_WHO_I_AM       0x0F
#define LIS3DSH_OUT_T          0x0C
#define LIS3DSH_STATUS         0x27
#define LIS3DSH_CTRL_REG4      0x20
#define LIS3DSH_CTRL_REG3      0x23
#define LIS3DSH_CTRL_REG5      0x24
#define LIS3DSH_CTRL_REG6      0x25
uint8_t buf[10];
void lis3dsh_init(void)
    uint8_t data;
    i2c_init();//初始化I2C
    i2c_read_n_byte(LIS3DSH_SLAVE_ADDR,LIS3DSH_WHO_I_AM,&buf[0],1);
//    data = 0x17;//0001:3.125Hz 0:continuous update 111:x,y,z enable
    data = 0x97;//1001:1600Hz 0:continuous update 111:x,y,z enable
    i2c_write_n_byte(LIS3DSH_SLAVE_ADDR,LIS3DSH_CTRL_REG4,&data,1);
    i2c_read_n_byte(LIS3DSH_SLAVE_ADDR,LIS3DSH_OUT_T,&buf[1],1);
    i2c_read_n_byte(LIS3DSH_SLAVE_ADDR,LIS3DSH_STATUS,&buf[2],7);
void dco_init(void)
  // Configure one FRAM waitstate as required by the device datasheet for MCLK
  // operation beyond 8MHz _before_ configuring the clock system.
  FRCTL0 = FRCTLPW | NWAITS_1;
  // Clock System Setup
  CSCTL0_H = CSKEY >> 8;                    // Unlock CS registers
  CSCTL1 = DCORSEL | DCOFSEL_4;             // Set DCO to 16MHz
  CSCTL2 = SELA__VLOCLK | SELS__DCOCLK | SELM__DCOCLK; // Set SMCLK = MCLK = DCO,
                                            // ACLK = VLOCLK
  CSCTL3 = DIVA__1 | DIVS__1 | DIVM__1;     // Set all dividers
  CSCTL0_H = 0;                             // Lock CS registers
int main( void )
  int16_t x = 0,y = 0,z = 0;
  uint8_t status;
  char inBuf[64];//base64缓存
  char outBuf[64];//base64缓存
  WDTCTL = WDTPW + WDTHOLD;//停止看门狗
  PM5CTL0 &= ~LOCKLPM5;//这个是一定要加的,不然GPIO不能使用
  dco_init();
  lis3dsh_init();
  uart_init();
  while(1)
#if (BASE64 == 1)    //base 64输出
    base64_encode((const uint8_t *)(&buf[2]),outBuf,7); //BASE64转换
    uart_tx_string(outBuf);//输出到PC
    uart_tx_string("\r\n");//换行
#elif (STRING == 1)       //字符串输出    status = buf[2];//status
    x = buf[3] + (buf[4] << 8);
    y = buf[5] + (buf[6] << 8);
    z = buf[7] + (buf[8] << 8);
    sprintf(outBuf,"lis3dsh data out x=%d,y=%d,z=%d\r\n",x,y,z);
    sleep(650);
#else                      //二进制输出
    outBuf[0] = 0x55;
    outBuf[1] = buf[4];
    outBuf[2] = buf[3];
    outBuf[3] = buf[6];
    outBuf[4] = buf[5];
    outBuf[5] = buf[8];
    outBuf[6] = buf[7];
//    if(x++ > 1000) x = 0;
//    if(y++ > 10000) y = 0;
//    if(z++ > 30000) y = 0;
//    outBuf[0] = 0x55;
//    outBuf[1] =x>>8;
//    outBuf[2] =x;
//    outBuf[3] = y>>8;
//    outBuf[4] = y;
//    outBuf[5] = z>>8;
//    outBuf[6] = z;
    uart_tx_bytes(outBuf,7);//输出到PC
#endif
    //SPCI2C_Readpt(SPC1000AddrR,0x07,mPress,1);      //获取气压数据高字节:3
个人签名虾扯蛋
501
版主好强大啊。精度咋样这个模块
手里没有相关的实验环境不好验证啊  详情 回复 发表于 2017-1-24 18:44
7548
手里没有相关的实验环境不好验证啊
看着不错。灵敏度很高  详情 回复 发表于 2017-1-25 09:47
501
littleshrimp 发表于 2017-1-24 18:44
手里没有相关的实验环境不好验证啊
看着不错。灵敏度很高
可以看下数据手册 感觉还不错  详情 回复 发表于 2017-1-25 21:20
972
谢谢分享和sensortile上的传感器一样不?
和sensortile的不一样 sensortile上使用的都是6轴 G+A A+M,这个是单纯的3轴加速度  详情 回复 发表于 2017-1-25 21:21
7548
可以看下数据手册 感觉还不错
7548
972
蓝牙板子的传感器是spi工作模式。
你好,最近我也在用LIS3DSH,由于老师没讲过,到现在还没搭起通信的程序,可以参考一下你的程序吗?谢谢
7548
单片机和上位机的代码:
3.csharp demo.rar (157.01 KB, 下载次数: 0)
大侠好厉害,下载看看学习  详情 回复 发表于 2019-6-5 11:16
个人签名虾扯蛋
楼主大大 能加个QQ吗 我QQ1518532502 我在做这个毕设 有些问题想请教
有问题在这里发贴就可以,我会及时回复的  详情 回复 发表于 2019-5-7 11:22
楼主大大能加个好友吗 有偿
7548
有问题在这里发贴就可以,我会及时回复的
个人签名虾扯蛋
单片机程序写入你用的什么软件?
IAR for MSP430  详情 回复 发表于 2019-5-7 13:30
如果用labview显示波形  你那个单片机程序需不需要改
按照相应的格式解析就可以了  详情 回复 发表于 2019-5-7 13:29
7548
按照相应的格式解析就可以了
个人签名虾扯蛋
7548
1518532502 发表于 2019-5-7 11:34
单片机程序写入你用的什么软件?
IAR for MSP430
个人签名虾扯蛋
楼主大大 你之前给的附件无法提取  怎么下载啊
用新版的rar试试,我之前也遇到过类似问题  详情 回复 发表于 2019-5-7 14:44
7548
个人签名虾扯蛋
楼主爸爸 用了新版的rar还是不行  能不能加个好友   呜呜呜
这个是把加速度转换成倾角的  详情 回复 发表于 2019-5-7 20:07
试试ISO文件  详情 回复 发表于 2019-5-7 15:35
站长推荐上一条 1/5 下一条
