2667|12
7524
说说SensorTile例程里传感器配置的文件结构
STSW-STLKT01例程里的LSM6DSM加速度传感器的初始化为例分析一下各种函数是怎么调用的
main.c文件中有一个initializeAllSensors函数,用来初始化所有传感器
通过调用BSP_ACCELERO_Init( LSM6DSM_X_0, &LSM6DSM_X_0_handle ) 实现LSM6DSM加速度传感器的初始化
  if (BSP_ACCELERO_Init( LSM6DSM_X_0, &LSM6DSM_X_0_handle ) != COMPONENT_OK)
    while(1);
BSP_ACCELERO_Init函数在SensorTile_accelero.c
现在的文件关系是main.c ->SensorTile_accelero.c
SensorTile_accelero.c里的DrvStatusTypeDef BSP_ACCELERO_Init( ACCELERO_ID_t id, void **handle )函数通过id来判断初始化哪个加速度传感器
因为SensorTile上有2IC都有加速度功能
idACCELERO_SENSORS_AUTO时先初始化LSM6DSM里的加速度传感器,如果LSM6DSM初始化失败再初始化LSM303AGR
idLSM6DSM_X_0时初始化LSM6DSM
idLSM303AGR_X_0时初始化LSM303AGR
见下边代码
  *handle = NULL;
  switch(id)
    case ACCELERO_SENSORS_AUTO:
    default:
      /* Try to init the LSM6DSM before */
      if(BSP_LSM6DSM_ACCELERO_Init(handle) == COMPONENT_ERROR )
        /* Normally it must not happen */
        /* Try to init the LSM303AGR accelerometer */
        if( BSP_LSM303AGR_ACCELERO_Init(handle) == COMPONENT_ERROR )
          return COMPONENT_ERROR;
      break;
    case LSM6DSM_X_0:
      if( BSP_LSM6DSM_ACCELERO_Init(handle) == COMPONENT_ERROR )
      break;
    case LSM303AGR_X_0:
      break;
  return COMPONENT_OK;
idLSM6DSM_X_0 时执行了static DrvStatusTypeDef BSP_LSM6DSM_ACCELERO_Init( void **handle )函数
  ACCELERO_Drv_t *driver = NULL;
  uint8_t data = 0x0C;
  if(ACCELERO_SensorHandle[ LSM6DSM_X_0 ].isInitialized == 1)
    /* We have reached the max num of instance for this component */
  if ( Sensor_IO_SPI_Init() == COMPONENT_ERROR )
  /* Setup sensor handle. */
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].who_am_i      = LSM6DSM_ACC_GYRO_WHO_AM_I;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].ifType        = 1; // SPI interface
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].address       = LSM6DSM_ACC_GYRO_I2C_ADDRESS;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].spiDevice     = LSM6DSM;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].instance      = LSM6DSM_X_0;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].isInitialized = 0;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].isEnabled     = 0;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].isCombo       = 1;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].pData         = ( void * )&ACCELERO_Data[ LSM6DSM_X_0 ];
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].pVTable       = ( void * )&LSM6DSM_X_Drv;
  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].pExtVTable    = ( void * )&LSM6DSM_X_ExtDrv;
  LSM6DSM_X_0_Data.comboData = &LSM6DSM_Combo_Data[0];
  ACCELERO_Data[ LSM6DSM_X_0 ].pComponentData = ( void * )&LSM6DSM_X_0_Data;
  ACCELERO_Data[ LSM6DSM_X_0 ].pExtData       = 0;
  *handle = (void *)&ACCELERO_SensorHandle[ LSM6DSM_X_0 ];
  Sensor_IO_SPI_CS_Init(*handle);
  if(LSM6DSM_Combo_Data[0].isGyroInitialized == 0)
    // SPI Serial Interface Mode selection --> 3Wires
    if( Sensor_IO_Write(*handle, LSM6DSM_ACC_GYRO_CTRL3_C, &data, 1) )
  driver = ( ACCELERO_Drv_t * )((DrvContextTypeDef *)(*handle))->pVTable;
  if ( driver->Init == NULL )
    memset((*handle), 0, sizeof(DrvContextTypeDef));
    *handle = NULL;
  if ( driver->Init( (DrvContextTypeDef *)(*handle) ) == COMPONENT_ERROR )
    *handle = NULL;
  /* Configure interrupt lines for LSM6DSM */
  LSM6DSM_Sensor_IO_ITConfig();
红字部分  ACCELERO_SensorHandle[ LSM6DSM_X_0 ].pVTable  = ( void * )&LSM6DSM_X_Drv;中的LSM6DSM_X_Drv类型为ACCELERO_Drv_t结构体,结构体中定义了一些基本函数
LSM6DSM_X_ExtDrv定义了一些额外的扩展函数
typedef struct
  DrvStatusTypeDef ( *Init            ) ( DrvContextTypeDef* );
  DrvStatusTypeDef ( *DeInit          ) ( DrvContextTypeDef* );
  DrvStatusTypeDef ( *Sensor_Enable   ) ( DrvContextTypeDef* );
  DrvStatusTypeDef ( *Sensor_Disable  ) ( DrvContextTypeDef* );
  DrvStatusTypeDef ( *Get_WhoAmI      ) ( DrvContextTypeDef*, uint8_t* );
  DrvStatusTypeDef ( *Check_WhoAmI    ) ( DrvContextTypeDef* );
  DrvStatusTypeDef ( *Get_Axes        ) ( DrvContextTypeDef*, SensorAxes_t* );
  DrvStatusTypeDef ( *Get_AxesRaw     ) ( DrvContextTypeDef*, SensorAxesRaw_t* );
  DrvStatusTypeDef ( *Get_Sensitivity ) ( DrvContextTypeDef*, float* );
  DrvStatusTypeDef ( *Get_ODR         ) ( DrvContextTypeDef*, float* );
  DrvStatusTypeDef ( *Set_ODR         ) ( DrvContextTypeDef*, SensorOdr_t );
  DrvStatusTypeDef ( *Set_ODR_Value   ) ( DrvContextTypeDef*, float );
  DrvStatusTypeDef ( *Get_FS          ) ( DrvContextTypeDef*, float* );
  DrvStatusTypeDef ( *Set_FS          ) ( DrvContextTypeDef*, SensorFs_t );
  DrvStatusTypeDef ( *Set_FS_Value    ) ( DrvContextTypeDef*, float );
  DrvStatusTypeDef ( *Get_Axes_Status ) ( DrvContextTypeDef*, uint8_t* );
  DrvStatusTypeDef ( *Set_Axes_Status ) ( DrvContextTypeDef*, uint8_t* );
} ACCELERO_Drv_t;
typedef struct
  /* Identity */
  uint8_t who_am_i;
  /* Configuration */
  uint8_t ifType;        /* 0 means I2C, 1 means SPI, etc. */
  uint8_t address;       /* Sensor I2C address (NOTE: Not a unique sensor ID). */
  uint8_t spiDevice;     /* Sensor Chip Select for SPI Bus */
  uint8_t instance;      /* Sensor instance (NOTE: Sensor ID unique only within its class). */
  uint8_t isInitialized; /* Sensor setup done. */
  uint8_t isEnabled;     /* Sensor ON. */
  uint8_t isCombo;       /* Combo sensor (component consists of more sensors). */
  /* Pointer to the Data */
  void *pData;
  /* Pointer to the Virtual Table */
  void *pVTable;
  /* Pointer to the Extended Virtual Table */
  void *pExtVTable;
} DrvContextTypeDef;
初始化的时候把LSM6DSM_ACC_GYRO_driver_HL.c里的基本函数填了进去
ACCELERO_Drv_t LSM6DSM_X_Drv =
  LSM6DSM_X_Init,
  LSM6DSM_X_DeInit,
  LSM6DSM_X_Sensor_Enable,
  LSM6DSM_X_Sensor_Disable,
  LSM6DSM_X_Get_WhoAmI,
  LSM6DSM_X_Check_WhoAmI,
  LSM6DSM_X_Get_Axes,
  LSM6DSM_X_Get_AxesRaw,
  LSM6DSM_X_Get_Sensitivity,
  LSM6DSM_X_Get_ODR,
  LSM6DSM_X_Set_ODR,
  LSM6DSM_X_Set_ODR_Value,
  LSM6DSM_X_Get_FS,
  LSM6DSM_X_Set_FS,
  LSM6DSM_X_Set_FS_Value,
  0,
现在的文件关系是main.c ->SensorTile_accelero.c –> LSM6DSM_ACC_GYRO_driver_HL.c
BSP_LSM6DSM_ACCELERO_Init函数后来通过
pVTable赋值给driver
接下来判断driver->Init是否为空
然后通过driver->Init调用LSM6DSM_ACC_GYRO_driver_HL.c 中的LSM6DSM_X_Init函数
初始化函数LSM6DSM_X_Init如下
static DrvStatusTypeDef LSM6DSM_X_Init( DrvContextTypeDef *handle )
  ACCELERO_Data_t *pData = ( ACCELERO_Data_t * )handle->pData;
  LSM6DSM_X_Data_t *pComponentData = ( LSM6DSM_X_Data_t * )pData->pComponentData;
  LSM6DSM_Combo_Data_t *comboData = pComponentData->comboData;
  if ( LSM6DSM_Check_WhoAmI( handle ) == COMPONENT_ERROR )
  /* Enable register address automatically incremented during a multiple byte
     access with a serial interface. */
  if ( LSM6DSM_ACC_GYRO_W_IF_Addr_Incr( (void *)handle, LSM6DSM_ACC_GYRO_IF_INC_ENABLED ) == MEMS_ERROR )
  /* Enable BDU */
  if ( LSM6DSM_ACC_GYRO_W_BDU( (void *)handle, LSM6DSM_ACC_GYRO_BDU_BLOCK_UPDATE ) == MEMS_ERROR )
  /* FIFO mode selection */
  if ( LSM6DSM_ACC_GYRO_W_FIFO_MODE( (void *)handle, LSM6DSM_ACC_GYRO_FIFO_MODE_BYPASS ) == MEMS_ERROR )
  /* Select default output data rate. */
  pComponentData->Previous_ODR = 104.0f;
  /* Output data rate selection - power down. */
  if ( LSM6DSM_ACC_GYRO_W_ODR_XL( (void *)handle, LSM6DSM_ACC_GYRO_ODR_XL_POWER_DOWN ) == MEMS_ERROR )
  /* Full scale selection. */
  if ( LSM6DSM_X_Set_FS( handle, FS_LOW ) == COMPONENT_ERROR )
  comboData->isAccInitialized = 1;
  handle->isInitialized = 1;
LSM6DSM_X_Init函数第一步先判断WhoAmI是否正确
LSM6DSM_ACC_GYRO_driver_HL.c 中的LSM6DSM_Check_WhoAmI函数
static DrvStatusTypeDef LSM6DSM_Check_WhoAmI( DrvContextTypeDef *handle )
  uint8_t who_am_i = 0x00;
  if ( LSM6DSM_Get_WhoAmI( handle, &who_am_i ) == COMPONENT_ERROR )
  if ( who_am_i != handle->who_am_i )
LSM6DSM_Check_WhoAmI函数通过LSM6DSM_Get_WhoAmI函数来读取WhoAmI
static DrvStatusTypeDef LSM6DSM_Get_WhoAmI( DrvContextTypeDef *handle, uint8_t *who_am_i )
  /* Read WHO AM I register */
  if ( LSM6DSM_ACC_GYRO_R_WHO_AM_I( (void *)handle, ( uint8_t* )who_am_i ) == MEMS_ERROR )
LSM6DSM_Get_WhoAmI函数调用了LSM6DSM_ACC_GYRO_driver.c文件中的LSM6DSM_ACC_GYRO_R_WHO_AM_I函数
现在的文件关系是main.c ->SensorTile_accelero.c –> LSM6DSM_ACC_GYRO_driver_HL.c -> LSM6DSM_ACC_GYRO_driver.c
LSM6DSM_ACC_GYRO_R_WHO_AM_I函数通过LSM6DSM_ACC_GYRO_ReadReg函数来读对应的LSM6DSM_ACC_GYRO_WHO_AM_I_REG寄存器
status_t LSM6DSM_ACC_GYRO_R_WHO_AM_I(void *handle, u8_t *value)
 if( !LSM6DSM_ACC_GYRO_ReadReg(handle, LSM6DSM_ACC_GYRO_WHO_AM_I_REG, (u8_t *)value) )
    return MEMS_ERROR;
  *value &= LSM6DSM_ACC_GYRO_WHO_AM_I_BIT_MASK; //coerce
  *value = *value >> LSM6DSM_ACC_GYRO_WHO_AM_I_BIT_POSITION; //mask
  return MEMS_SUCCESS;
LSM6DSM_ACC_GYRO_ReadReg函数调用SensorTile.c文件中的Sensor_IO_Read函数来读取寄存器数据
status_t LSM6DSM_ACC_GYRO_ReadReg(void *handle, u8_t Reg, u8_t* Data)
  if (Sensor_IO_Read(handle, Reg, Data, 1))
    return MEMS_ERROR;
  else
现在的文件关系是main.c ->SensorTile_accelero.c –> LSM6DSM_ACC_GYRO_driver_HL.c -> LSM6DSM_ACC_GYRO_driver.c -> SensorTile.c
Sensor_IO_Read函数通过ifType来决定使用I2C总线还是SPI总线
BSP_LSM6DSM_ACCELERO_Init 函数里有一句话ACCELERO_SensorHandle[ LSM6DSM_X_0 ].ifType        = 1; // SPI interface
确定为使用SPI总线
通过调用Sensor_IO_SPI_Read函数通过SPI读取寄存器数据
uint8_t Sensor_IO_Read( void *handle, uint8_t ReadAddr, uint8_t *pBuffer, uint16_t nBytesToRead )
  DrvContextTypeDef *ctx = (DrvContextTypeDef *)handle;
  if(ctx->ifType == 0)
    return Sensor_IO_I2C_Read( handle, ReadAddr, pBuffer, nBytesToRead );
  if(ctx->ifType == 1)
    return Sensor_IO_SPI_Read( handle, ReadAddr, pBuffer, nBytesToRead );
Sensor_IO_SPI_Read函数通过Sensor_IO_SPI_CS_Enable函数来控制CS线的输出
Sensor_IO_SPI_CS_Enable函数通过调用stm32l4xx_hal_gpio.c里的对应函数来控制CS线的电平
现在的文件关系是main.c ->SensorTile_accelero.c –> LSM6DSM_ACC_GYRO_driver_HL.c -> LSM6DSM_ACC_GYRO_driver.c -> SensorTile.c -> stm32l4xx_hal_gpio.c
uint8_t Sensor_IO_SPI_CS_Enable(void *handle)
  switch(ctx->spiDevice)
  case LSM6DSM:
    HAL_GPIO_WritePin(SENSORTILE_LSM6DSM_SPI_CS_Port, SENSORTILE_LSM6DSM_SPI_CS_Pin, GPIO_PIN_RESET);
    break;
  case LSM303AGR_X:
    HAL_GPIO_WritePin(SENSORTILE_LSM303AGR_X_SPI_CS_Port, SENSORTILE_LSM303AGR_X_SPI_CS_Pin, GPIO_PIN_RESET);
    break;
  case LSM303AGR_M:
    HAL_GPIO_WritePin(SENSORTILE_LSM303AGR_M_SPI_CS_Port, SENSORTILE_LSM303AGR_M_SPI_CS_Pin, GPIO_PIN_RESET);
    break;
  case LPS22HB:
    HAL_GPIO_WritePin(SENSORTILE_LPS22HB_SPI_CS_Port, SENSORTILE_LPS22HB_SPI_CS_Pin, GPIO_PIN_RESET);
    break;
同时Sensor_IO_SPI_Read函数通过调用SPI_WriteSPI_Read函数来读到数据
uint8_t Sensor_IO_SPI_Read( void *handle, uint8_t ReadAddr, uint8_t *pBuffer, uint16_t nBytesToRead )
  uint8_t i;
// Select the correct device
  Sensor_IO_SPI_CS_Enable(handle);
  SPI_Write(&SPI_Sensor_Handle, ReadAddr | 0x80);
//  SYNCHRO_WAIT(SYNCHRO_SPI_DELAY);
  __HAL_SPI_DISABLE(&SPI_Sensor_Handle);
  SPI_1LINE_RX(&SPI_Sensor_Handle);
  for(i=0;i<nBytesToRead;i++)
    SPI_Read(&SPI_Sensor_Handle, pBuffer++);
  SPI_1LINE_TX(&SPI_Sensor_Handle);
  __HAL_SPI_ENABLE(&SPI_Sensor_Handle);
  // Deselect the device
  Sensor_IO_SPI_CS_Disable(handle);
SPI_WriteSPI_Read直接操作SPI寄存器
 * @brief  This function send a command through SPI bus.
 * @param  command : command id.
 * @param  val : value.
 * @retval None
void SPI_Read(SPI_HandleTypeDef* xSpiHandle, uint8_t *val)
  /* In master RX mode the clock is automaticaly generated on the SPI enable.
  So to guarantee the clock generation for only one data, the clock must be
  disabled after the first bit and before the latest bit */
  /* Interrupts should be disabled during this operation */
  __disable_irq();
  __HAL_SPI_ENABLE(xSpiHandle);
  __asm("dsb\n");
  __asm("dsb\n");
  __HAL_SPI_DISABLE(xSpiHandle);
  __enable_irq();
  while ((xSpiHandle->Instance->SR & SPI_FLAG_RXNE) != SPI_FLAG_RXNE);
  /* read the received data */
  *val = *(__IO uint8_t *) &xSpiHandle->Instance->DR;
  while ((xSpiHandle->Instance->SR & SPI_FLAG_BSY) == SPI_FLAG_BSY);
 * @retval None
void SPI_Write(SPI_HandleTypeDef* xSpiHandle, uint8_t val)
  /* check TXE flag */
  while ((xSpiHandle->Instance->SR & SPI_FLAG_TXE) != SPI_FLAG_TXE);
  /* Write the data */
  *((__IO uint8_t*) &xSpiHandle->Instance->DR) = val;
  /* Wait BSY flag */
  while ((xSpiHandle->Instance->SR & SPI_FLAG_FTLVL) != SPI_FTLVL_EMPTY);
同时Sensor_IO_SPI_Read函数还调用了stm32l4xx_hal_spi.h文件中的SPI_1LINE_RXSPI_1LINE_TX函数(宏定义)
/** @brief  Set the SPI transmit-only mode.
  * @param  __HANDLE__: specifies the SPI Handle.
  *         This parameter can be SPI where x: 1, 2, or 3 to select the SPI peripheral.
  * @retval None
#define SPI_1LINE_TX(__HANDLE__) ((__HANDLE__)->Instance->CR1 |= SPI_CR1_BIDIOE)
/** @brief  Set the SPI receive-only mode.
  * @retval None
#define SPI_1LINE_RX(__HANDLE__) ((__HANDLE__)->Instance->CR1 &= (~SPI_CR1_BIDIOE))
最后的文件关系是
main.c ->SensorTile_accelero.c –> LSM6DSM_ACC_GYRO_driver_HL.c -> LSM6DSM_ACC_GYRO_driver.c -> SensorTile.c ->stm32l4xx_hal_spi.h
个人签名虾扯蛋
管理员
支持一下
不管是哪年,都要加油!继续为中国电子行业做出小小的贡献吧! 扣扣 1206973913
1443
为啥手机上看到的都是html代码?看的眼睛花了
nmg
已经好了  详情 回复 发表于 2017-1-22 10:08
nmg
稍等,处理一下  详情 回复 发表于 2017-1-22 09:55
4206
233
管理员
稍等,正在处理
4206
233
管理员
已经好了
96
这波 可以! 这才是需要的技术贴
109
非常有帮助谢谢
你好!
我这边配置了lsm6dsl相关寄存器(0x10 = 0x96;0x15 = 0x80 ;0x12 = 0x44 ;0x13 = 0x02; 0x0a = 0x00)共五个寄存器,即设置采样率为3.33KHz,16g的加速度计。
在读取z轴加速度计时读回相应的值(按照3.33khz的频率读取)。
但是在加上读取状态寄存器0x1e的最后一位时,其读取的值一直是0。
不知道是什么问题。
把你的配置代码发出来看一下  详情 回复 发表于 2017-5-17 15:41
7524
wuhen123 发表于 2017-5-17 15:35
你好!
我这边配置了lsm6dsl相关寄存器(0x10 = 0x96;0x15 = 0x80 ;0x12 = 0x44 ;0x13 = 0x02; 0x0a =  ...
把你的配置代码发出来看一下
case(cnt_config_reg) 0:begin imu_addr  详情 回复 发表于 2017-5-17 15:48
个人签名虾扯蛋
littleshrimp 发表于 2017-5-17 15:41
把你的配置代码发出来看一下
                                        0:begin
                                                imu_addr                 <= 7'h10;//
                                                imu_config_Data <= 8'h90;
                                        end
                                        1:begin
                                                imu_addr                 <= 7'h15;//
                                                imu_config_Data <= 8'h80;
                                        end
                                        2:begin
                                                imu_addr                 <= 7'h12;//
                                                imu_config_Data <= 8'h44;
                                        end
                                        3:begin
                                                imu_addr                 <= 7'h13;//
                                                imu_config_Data <= 8'h02;
                                        end
                                        4:begin
                                                imu_addr                 <= 7'h0a;//
                                                imu_config_Data <= 8'h00;
                                        end
                                        5:begin
                                                imu_config_Data <= 8'h96;
                                        end
                                         6:begin
                                                 imu_addr                 <= 7'h16;
                                                 imu_config_Data <= 8'h00;//8'h18
                                         end
                                        default :;
                                endcase.
这是FPGA 先关配置寄存器的代码一部分。并且在其他部分中读取who am i寄存器时读回正确的 0x6a值。
state_imu_data_status:begin
                                                begin
                                                        spi_config_addr[6:0] <= 7'h1e;
                                                        spi_config_addr[7] <= 1'b1;
                                                        spi_config_data <= 0;
                                                        spi_load <= 1;
                                                        spi_rd_byre <= 1;
                                                        state_reg <= state_imu_stats_end;
                                                end
                                end
                        state_imu_stats_end:begin
                                        spi_load <= 0;
                                        state_reg <= state_imu_data_rd;
                                end
                        state_imu_data_rd:begin
                                if (spi_int)
                                        begin
                                                spi_rd_data = spi_shift_Data;
                                                //spi_data_en <= 1;
                                                state_reg <= state_imu_stats_check;
                                        end
                                else
                        end
                        state_imu_stats_check:begin
                                        spi_data_en <= 0;
                                        if (spi_rd_data[0] == 1)
                                                begin
                                                        cnt_read_reg <= 0;
                                                        imu_data_ready <= 1;
                                                        state_reg <= state_config_rd_addr;
                                                end
                                        else
                                                state_reg <= state_imu_data_status_delay;
                        end
这块是加上读取0x1e寄存器的状态机
FPGA代码看不懂啊 在你的那个贴子里回复了,通过正常就应该是配置的问题了 你可以参照一些官方提供的代码试试  详情 回复 发表于 2017-5-17 18:03
7524
wuhen123 发表于 2017-5-17 15:48
case(cnt_config_reg)                                        0:begin                               ...
FPGA代码看不懂啊
你可以参照一些官方提供的代码试试
个人签名虾扯蛋
205
写的太详细了真是
ST的例程结构比较复杂 自己是熟悉的过程顺便记录下来方便以后查看  详情 回复 发表于 2017-5-29 09:49
7524
WZH70246 发表于 2017-5-29 08:36
写的太详细了真是
ST的例程结构比较复杂
个人签名虾扯蛋
站长推荐上一条 1/5 下一条
