1116|0
周立功混合3D显示仪表板应用方案
混合3D显示仪表板
概述
由于OEM需要更全面的用户体验,混合仪表盘空间采用3D图形技术已逐渐成为主流。 恩智浦®提供一个全面的产品组合,以满足混合仪表盘需求,在高分辨率显示器上支持模拟仪表和3D图形。
从车辆连接和系统MCU到带可扩展的3D图形性能的汽车应用处理器 ,恩智浦可以提供完整的系统解决方案,以满足下一代混合3D仪表盘的需要。
我们的汽车应用处理器提供如OpenGL ES 2.0和Open GL ES3.0等常用3D图形API,打造丰富的用户体验,是汽车仪表板应用中实现逼真视觉呈现的理想解决方案。这些处理器还有一个广泛的开发工具生态合作体系作支持,优化您的解决方案,满足OEM的要求。(文章来源周立功官网,如需了解更多请访问周立功官网)
框图
推荐产品
类别
产品
特性
Automotive Applications Processors
i.MX 6DualLite Processors – Dual-Core,  3D Graphics, HD Video, ARM Cortex-A9 Core
i.MX 6Dual Processors - Dual-Core, 3D  Graphics, HD Video, Multimedia, ARM Cortex-A9 Core
ARM® Cortex™-A9 dual-core CPU, video and Triple-Play  graphics acceleration
i.MX 6Solo Processors – Single-Core,  Multimedia, 3D Graphics, ARM Cortex-A9 Core
ARM® Cortex™-A9 single-core CPU, video  and Triple-Play graphics acceleration
Signal Conditioning
MSDI with Suppressed Wakeup
Multiple switch detection interface
Discretes
Discrete and Logic for Automotive
Automotive MOSFETs, Bipolar  Transistors, Diodes, High Side Switches, Low Side Switches, Logic, Squib  Drivers and Transient Voltage Suppressors
I/O Protection
Automotive MOSFETs
AEC-Q101 compliant, repetitive  avalanche rated, suitable for thermally demanding environments due to 175°C  rating
ESD Protection
Designed to protect FlexRay bus, CAN  and LIN transceivers as well as other ESD sensitive automotive electronic  components
车载网络
CAN Transceivers
一个全面的产品组合,包括适合所有CAN物理层特性的汽车级收发器
LIN Transceivers
基于汽车应用中低成本通信行业标准的广泛LIN解决方案
CAN/LIN System Basis Chips
系统基础芯片,包括我们的UJA107xAUJA106x TJA1028, 为当今的汽车控制单元提供紧凑、可扩展的解决方案
Power Supply
Power Management for i.MX Application  Processors
PMICs are designed for use with the  various families of i.MX applications processors and integrate both switching  and linear regulators required for the total system solution
Automotive MOSFETs
System basis chips, including our UJA107xA,  UJA106x and TJA1028, offer a compact and scalable solution for today's  automotive control units
胶合逻辑
Automotive Flip-Flops
一系列模拟开关和多路复用器/多路分离器电路符合AEC-Q100的要求
Automotive Analog Switches
Sensor designed with the right  combination of intelligent integration, logic and customizable software
Sensors
Sensors
Software Services and Support
Professional Support and Service  Resources
Different levels of professional  services and support based on your individual needs.
站长推荐上一条 1/5 下一条
