社区导航
搜索
查看: 828|回复: 0
周立功汽车入门级仪表板应用方案
TA的帖子
Rank: 1
发表于 2017-1-6 16:50 | 显示全部楼层 |阅读模式
概述
随着汽车新兴市场的不断发展,对于简单、低成本仪表板解决方案的需求也与日俱增。
恩智浦提供多种高性价比的解决方案。这些解决方案基于我们种类齐全的仪表板处理器,范围从8位的S08系列直到行业领先的16位S12架构,并集成了所需的接口功能,包括优化组合的片上功能、封装和存储器选项。
为了进一步帮助您的仪表板设计,恩智浦提供了广泛的硬件和软件开发工具套件。(文章转自周立功官网,如需了解更多请访问周立功官网)
框图
推荐产品
类别
产品
特性
微控制器(MCU)
8-bit Segment LCD S08LG32 and S08LG16  MCUs
8MCU32K闪存,296段,LCD支持
S12HY Scalable Value Line Cluster  Solutions Microcontrollers (MCUs) with CAN
16MCU,高达256K闪存,面向步进电机的25 MHzLCD支持
S12XHY Scalable Cluster  Microcontrollers (MCUs) with CAN
16MCU,高达256K片上闪存(ECC)8K数据闪存(ECC)LCD支持
S12XHZ Scalable Instrument Clusters  Microcontrollers (MCUs) with CAN
16MCU,高达512K闪存,面向步进电机的40 MHzLCD支持,XGATE
S12ZVH Mixed-Signal MCU for  Entry-Level Automotive & Industrial Clusters
增强型S12Z内核,32 MHz总线速度
系统基础芯片SBC
System Basis Chip Gen2 with High Speed  CAN
SBC,高速CAN IF
信号调适
MSDI with Suppressed Wakeup
多开关检测接口
LED背光驱动器
16-Output Switch with SPI Control
SPI控制的16路输出开关
Discretes
Discrete and Logic for Automotive
Automotive MOSFETs, Bipolar  Transistors, Diodes, High Side Switches, Low Side Switches, Logic, Squib  Drivers and Transient Voltage Suppressors
I/O Protection
CAN Transceivers
A comprehensive portfolio comprising automotive-grade  transceivers for all CAN physical layer options
LIN Transceivers
An extensive range of LIN solutions based on the industry  standard for low-cost communications in automotive applications
CAN/LIN System Basis Chips
System basis chips, including our UJA107xA, UJA106x and  TJA1028, offer a compact and scalable solution for today's automotive control  units
Power Supply
Automotive MOSFETs
AEC-Q101 compliant, repetitive avalanche rated, suitable  for thermally demanding environments due to 175°C rating
Glue Logic
Automotive Flip-Flops
Meets the requirements of AEC-Q100 and recommended for  automotive applications
Automotive Analog Switches
A range of analog switches and multiplexer/demultiplexer  circuits that meet AEC-Q100 requirements.
Sensors
Sensors
Sensor designed with the right  combination of intelligent integration, logic and customizable software
Software Services and Support
Professional Support and Service  Resources
Different levels of professional services and support based  on your individual needs.
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-4-24 23:48 , Processed in 0.082569 second(s), 19 queries , Gzip On, MemCache On.
