社区导航
搜索
查看: 2060|回复: 7
[求助] 关于MSP430FR4133写FRAM的怪问题?
86
TA的帖子
Rank: 2
发表于 2017-1-4 17:28 | 显示全部楼层 |阅读模式
当执行FRAMWrite_uint64((uint64_t *)FRAM_RECORD_ADDRESS,0); 时,后20*4会被修改为0
原来0xffffffff,0xffffffff,被改为0x0000ffff,0x00000000
当执行FRAMWrite_Long((uint32_t *)FRAM_RECORD_ADDRESS, 0);时,后10*4=40会被修改为0
原来0xffffffff,被改为0x0000ffff,
void FRAMWrite_uint64(uint64_t *pFRAM_write_ptr, uint64_t ui64data)
        SYSCFG0 &= ~DFWP;
        *pFRAM_write_ptr = ui64data;
        SYSCFG0 |= DFWP;
void FRAMWrite_Long(uint32_t *pFRAM_write_ptr, uint32_t ui32data)
        SYSCFG0 &= ~DFWP;
        *pFRAM_write_ptr = ui32data;
        SYSCFG0 |= DFWP;
#define FRAM_RECORD_ADDRESS  0x1812
使用道具 举报
528
TA的帖子
Rank: 4
发表于 2017-1-4 21:24 | 显示全部楼层
FRAM好像可以提供8位16位写入,64位有问题
FRAM
The FRAM can be programmed via the JTAG port, Spy-Bi-Wire (SBW), the BSL, or in-system by the CPU.
Features of the FRAM include:
• Ultra-low-power ultra-fast-write nonvolatile memory
• Byte and word access capability
• Programmable and automated wait-state generation
• Error correction coding (ECC)
这里没说可以按64位来,所以,你要手动把他拆分成两个word来写就对了
使用道具 举报
1089
TA的帖子
Rank: 6Rank: 6
发表于 2017-1-4 23:05 | 显示全部楼层
你得操作不对,参考官方代码MSP430Ware中例子
//   MSP430FR413x Demo - Long word writes to FRAM
//   Description: Use long word write to write to 512 byte blocks of FRAM.
//   Toggle LED after every 100 writes.
//   NOTE: Running this example for extended periods will impact the FRAM
//   endurance.
//   ACLK = REFO, MCLK = SMCLK = default DCODIV = ~1MHz
//           MSP430FR4133
//      --|RST            |
//        |          P1.0 |---> LED
//   Cen Fang
//   Texas Instruments Inc.
//   August 2013
//   Built with IAR Embedded Workbench v5.60 & Code Composer Studio v5.5
#include <msp430.h>
void FRAMWrite(void);
unsigned char count = 0;
unsigned long *FRAM_write_ptr;
unsigned long data;
#define FRAM_TEST_START 0x1800
int main(void)
    WDTCTL = WDTPW | WDTHOLD;               // Stop watchdog timer
    P1OUT &= ~BIT0;                         // Clear P1.0 output latch for a defined power-on state
    P1DIR |= BIT0;                          // Set P1.0 to output directionOUT
    PM5CTL0 &= ~LOCKLPM5;                   // Disable the GPIO power-on default high-impedance mode
                                            // to activate previously configured port settings
    data = 0x11111111;                      // Initialize dummy data
    while(1)
        data += 0x00010001;
        FRAM_write_ptr = (unsigned long *)FRAM_TEST_START;
        FRAMWrite();
        count++;
        if (count > 100)
            P1OUT ^= 0x01;                  // Toggle LED to show 512K bytes
            count = 0;                      // ..have been written
            data = 0x11111111;
void FRAMWrite (void)
    unsigned int i=0;
    SYSCFG0 &= ~DFWP;
    for (i = 0; i < 128; i++)
        *FRAM_write_ptr++ = data;
    SYSCFG0 |= DFWP;
使用道具 举报
86
TA的帖子
Rank: 2
 楼主| 发表于 2017-1-5 09:23 | 显示全部楼层
由于开发进度很紧,我直接用TI 《MSP430FR4xx 实现的水表》中的程序
其中FRAM读写,只是他用的是程序区FRAM
        SYSCFG0 &= ~PFWP;
        SYSCFG0 |= PFWP;
void FRAMWrite_Char(uint8_t *pFRAM_write_ptr, uint8_t ui8data)
        SYSCFG0 &= ~PFWP;
        *pFRAM_write_ptr = ui8data;
        SYSCFG0 |= PFWP;
pAddress = (uint8_t *)(FRAM_RECORD_BASE + (tRTCData.ui8Year - 13)*120 + (tRTCData.ui8Month - 1)*10);
FRAMWrite_Char(pAddress++,tRTCData.ui8Year);
FRAMWrite_Long((uint32_t *)FRAM_RECORD_ADDRESS,ui32Sum);
ui32Sum = *((uint32_t *)FRAM_RECORD_ADDRESS);
// Fram record address
#define FRAM_RECORD_ADDRESS 0xFF00         // Refresh every 1 second
#define FRAM_RECORD_CHECK 0xFF40         // First record check address
#define FRAM_RECORD_BASE 0xFA00             // Monthly record in stand-alone address
使用道具 举报
86
TA的帖子
Rank: 2
 楼主| 发表于 2017-1-5 09:28 | 显示全部楼层
我读写8 16 32 64都根据他改的
使用道具 举报
86
TA的帖子
Rank: 2
 楼主| 发表于 2017-1-5 10:38 | 显示全部楼层
uint8_t  i;
uint32_t *pAddress;
                for(i=0;i<Freq_cn;i++)
                        pAddress = (uint32_t *)(FRAM_RECORD_Freq + i*4);
                  FRAMWrite_Long((uint32_t *)(pAddress),flow_Freq_k[i]);
                        pAddress = (uint32_t *)(FRAM_RECORD_rate + i*4);
                  FRAMWrite_Long((uint32_t *)(pAddress),flow_rate_k[i]);
uint8_t  i;
uint32_t *pAddress;
                  flow_Freq_k[i] = *((uint32_t *)pAddress);
                  flow_rate_k[i] = *((uint32_t *)pAddress);
FRAMWrite_uint64((uint64_t *)FRAM_RECORD_ADDRESS,0); //写FRAM (刷新)
//FRAMWrite_Long((uint32_t *)FRAM_RECORD_ADDRESS, 0);
//FRAMWrite_uint16((uint16_t *)FRAM_RECORD_ADDRESS, 0);
一样的啊!
使用道具 举报
86
TA的帖子
Rank: 2
 楼主| 发表于 2017-1-9 14:34 | 显示全部楼层
结贴,是常量地址定义有错,FRAM读写没有问题!
楼主,想请问一下,你的常量地址定义有错是什么个情况? 我的是写入的时候,地址内容没有改变,全是FFFFFFFF  详情 回复 发表于 2017-1-22 17:10
使用道具 举报
407
TA的帖子
Rank: 3Rank: 3
发表于 2017-1-22 17:10 | 显示全部楼层
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-4-20 14:31 , Processed in 0.230529 second(s), 17 queries , Gzip On, MemCache On.
