社区导航
搜索
查看: 2051|回复: 3
[求助] 关于cc2650 lanchpad pwmled的疑问
TA的帖子
Rank: 1
发表于 2017-1-3 17:32 | 显示全部楼层 |阅读模式
run 了一下TI cc2650的PWMLED例程,红色LED闪动了起来。想小改一下换颗LED试试。看到了GPIO_write(Board_LED0, Board_LED_ON); 这句,语言改为Board_LED1,结果还是红色的LED在动,后来又把这句屏蔽掉,照样是LED0 在动。吓得我以为板子坏掉。
后来发现直接PWMLed线程中的PWM_open(Board_PWM1, &params);就行了。
看来确实是PWM输出,既然如此,为何TI 还有些GPIO呢?
此帖出自无线连接论坛
使用道具 举报
915
TA的帖子
Rank: 3Rank: 3
发表于 2017-1-3 19:08 | 显示全部楼层
跟踪一下这个函数你就懂了
PWM_Handle PWMTimerCC26XX_open(PWM_Handle handle, PWM_Params *params)
    PWMTimerCC26XX_HwAttrs *hwAttrs = handle->hwAttrs;
    PWMTimerCC26XX_Object  *object  = handle->object;
    /* Check if PWM already open  */
    uint32_t key = Hwi_disable();
    if (object->isOpen)
        Hwi_restore(key);
        Log_error1("PWM_open(%x):  Unit already in use.", (UArg) handle);
        return NULL;
    object->isOpen = 1;
    Hwi_restore(key);
    /* Open timer resource */
    GPTimerCC26XX_Params timerParams;
    GPTimerCC26XX_Params_init(&timerParams);
    timerParams.width          = GPT_CONFIG_16BIT;
    timerParams.mode           = GPT_MODE_PWM;
    timerParams.debugStallMode = GPTimerCC26XX_DEBUG_STALL_OFF;
    GPTimerCC26XX_Handle hTimer = GPTimerCC26XX_open(hwAttrs->gpTimerUnit, &timerParams);
    /* Fail if cannot open timer */
    if (hTimer == NULL)
        Log_error2("PWM_open(%x): Timer unit (%d) already in use.", (UArg) handle, hwAttrs->gpTimerUnit);
        object->isOpen = false;
        return NULL;
    /* Open pin resource */
    PIN_Config pinConfig;
    /* Initial open of pin handle with no pins in it. Should never fail. */
    if (hPins == NULL)
        pinConfig = PIN_TERMINATE;
        hPins     = PIN_open(&pinState, &pinConfig);
    /* Invert PWM idle level since pin output is inverted */
    uint32_t idleLevel = PIN_GPIO_HIGH;
    if (params->idleLevel == PWM_IDLE_HIGH)
        idleLevel = PIN_GPIO_LOW;
    /* Generate pin config for PWM pin.
     *  Output is inverted to make PWM duty calculations independent of period
    pinConfig = hwAttrs->pwmPin | PIN_INPUT_DIS | PIN_GPIO_OUTPUT_EN | idleLevel |
                PIN_INV_INOUT | PIN_PUSHPULL | PIN_DRVSTR_MAX;
    /* Fail if cannot add pin */
    if (PIN_add(hPins, pinConfig) != PIN_SUCCESS)
        Log_error2("PWM_open(%x): PIN (%d) already in use.", (UArg) handle, hwAttrs->pwmPin);
        GPTimerCC26XX_close(hTimer);
        return NULL;
    /* Store configuration to object */
    object->periodUnit  = params->periodUnits;
    object->periodValue = params->periodValue;
    object->dutyUnit    = params->dutyUnits;
    object->dutyValue   = params->dutyValue;
    object->idleLevel   = params->idleLevel;
    object->hTimer      = hTimer;
    /* Configure PWM period*/
    uint32_t period = object->periodValue;
    if (PWMTimerCC26XX_setPeriod(handle, period) != PWM_STATUS_SUCCESS)
        Log_error1("PWM_open(%x): Failed setting period", (UArg) handle);
        PIN_remove(hPins, hwAttrs->pwmPin);
        return NULL;
    /* Corner case: If using duty unit PWM_DUTY_FRACTION or PWM_DUTY_US with
       value 0, then duty is already set by setPeriod. Skip if so. */
    PWM_Duty_Units unit  = object->dutyUnit;
    uint32_t      value = object->dutyValue;
    if (!(unit == PWM_DUTY_FRACTION || (value == 0 && unit == PWM_DUTY_US)))
        if (PWMTimerCC26XX_setDuty(handle, value) != PWM_STATUS_SUCCESS)
            Log_error1("PWM_open(%x): Failed setting duty cycle", (UArg) handle);
            return NULL;
    Log_info1("PWM_open(%x): Opened with great success!", (UArg) handle);
    return handle;
作为一个菜逼,干货并没有多少。唯一会的就是水,所以回帖水分大。望见谅!
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2017-1-4 09:34 | 显示全部楼层
人民币的幻想 发表于 2017-1-3 19:08
跟踪一下这个函数你就懂了
感谢你的回复,我刚开始用这片板子和CCS 工具,我只有在github上才看到你贴的这个程序 https://github.com/energia/emt/b ... LE/PWMTimerCC26xx.c
而我在TI上只有看到一些headfiles.具体在http://software-dl.ti.com/dsps/d ... gen/html/index.html
我想知道我应该从哪里打开你提到的源文件。因为后面的学习还将用到。
另外我在追踪代码的时候发现我前面提到过的GPIO_write(n,m)只是个定义。具体见图片。。整个学习资源怎么使用还望指点
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2017-1-4 10:03 | 显示全部楼层
matthew_wang 发表于 2017-1-4 09:34
感谢你的回复,我刚开始用这片板子和CCS 工具,我只有在github上才看到你贴的这个程序 https://github.co ...
关于上面问题,自己回答一下,供其他小伙伴查找:
PWM的源文件在 C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\tidrivers_cc13xx_cc26xx_2_20_01_10\packages\ti\drivers\pwm
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-4-24 06:02 , Processed in 0.149055 second(s), 17 queries , Gzip On, MemCache On.
