8286|2
STM32单脉冲模式 [复制链接]
  1. /*************************************************************
  2.   Function   : OnePulse_TIM4_Init
  3.   Description: 定时器4配置
  4.   Input      : none
  5.   return     : none
  6. *************************************************************/
  7. void OnePulse_TIM4_Init(u16 arr,u16 psc)
  8. {
  9.
  10.          GPIO_InitTypeDef  GPIO_InitStructure;
  11.
  12.         //GPIO D12,D13初始化设置
  13.           GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
  14.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//普通复用模式
  15.           GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  16.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  17.           GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  18.           GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化GPIO
  19.
  20.           GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_TIM4); //PA0复用位定时器4
  21.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //GPIOA0
  22.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//复用功能
  23.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;        //速度100MHz
  24.           GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //下拉
  25.           GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PD13
  26.
  27.
  28.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  29.         TIM_ICInitTypeDef  TIM_ICInitStructure;
  30.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  31.
  32.
  33.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);  ///使能TIM4时钟
  34.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOD时钟
  35. /*---------------------------------------------------------
  36.         TIM4的定时时钟 84M
  37.     IM4的CH1配置成PWM2输出模式,TIM4的CH2配置成输入捕获模式,
  38.         PWM2模式增计数下,计数值小于比较值为无效电平即低电平,
  39.         TIM2 CH2检测到一个上升沿后,经过一定的延时时间,输出一个脉冲,
  40.         ---------------------------------------------------------*/
  41.
  42.
  43.         TIM_TimeBaseStructure.TIM_Period = arr;//定时器周期值
  44.         TIM_TimeBaseStructure.TIM_Prescaler =psc;//预分频
  45.         TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  46.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//增计数模式
  47.
  48.         TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);//初始化定时器时基
  49.
  50.
  51.
  52.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;//TIM4 CH1配置成PWM2输出模式
  53.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//输出使能
  54.         TIM_OCInitStructure.TIM_Pulse =3000;//设置跳变值
  55.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//有效电平为高电平
  56.
  57.         TIM_OC1Init(TIM4, &TIM_OCInitStructure);
  58.
  59.         //TIM_OC1PreloadConfig(TIM4,TIM_OCPreload_Enable);  //使能TIM4在CCR1上的预装载寄存器
  60.
  61.
  62.         TIM_ICStructInit(&TIM_ICInitStructure);//初始化输入捕获结构体
  63.
  64.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;//TIM4 CH2 配置为输入捕获模式
  65.         TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;//上升沿捕获
  66.         TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;//管教与寄存器直接对应
  67.         TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;//不与分频
  68.         TIM_ICInitStructure.TIM_ICFilter = 0;//不滤波
  69.
  70.         TIM_ICInit(TIM4, &TIM_ICInitStructure);//初始化TIM4 CH2
  71.
  72.
  73.         TIM_SelectOnePulseMode(TIM4, TIM_OPMode_Single);//选择定时器为单脉冲模式
  74.
  75.         TIM_SelectInputTrigger(TIM4, TIM_TS_TI2FP2);//选择触发源为IC2
  76.
  77.         TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Trigger);//选择定时器从模式为上升沿触发
  78.
  79.         //TIM_Cmd(TIM4, ENABLE);        //开启时钟
  80. }
  81. //TIM14 PWM部分初始化
  82. //PWM输出初始化
  83. //arr:自动重装值
  84. //psc:时钟预分频数
  85. void TIM3_PWM_Init(u32 arr,u32 psc)
  86. {
  87.         //此部分需手动修改IO口设置
  88.
  89.         GPIO_InitTypeDef GPIO_InitStructure;
  90.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  91.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  92.
  93.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);          //TIM14时钟使能
  94.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);         //使能PORTC时钟
  95.
  96.         GPIO_PinAFConfig(GPIOC,GPIO_PinSource6,GPIO_AF_TIM3); //GPIOF9复用为定时器14
  97.
  98.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;           //GPIOF9
  99.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;        //复用功能
  100.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  101. //速度100MHz
  102.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;      //推挽复用输出
  103.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;        //上拉
  104.         GPIO_Init(GPIOC,&GPIO_InitStructure);              //初始化PF9
  105.
  106.         TIM_TimeBaseStructure.TIM_Prescaler=psc;  //定时器分频
  107.         TIM_TimeBaseStructure.TIM_Period=arr;   //自动重装载值
  108.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式
  109.         TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  110.
  111.         TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);//初始化定时器14
  112.
  113.
  114.         //初始化TIM14 Channel1 PWM模式
  115.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2
  116.          TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
  117.         //TIM_OCInitStructure.TIM_Pulse =500;//设置跳变值
  118.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性低
  119.         TIM_OC1Init(TIM3, &TIM_OCInitStructure);  //根据T指定的参数初始化外设TIM1 4OC1
  120.         TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);  //使能TIM14在CCR1上的预装载寄存器
  121.         TIM_ARRPreloadConfig(TIM3,ENABLE);//ARPE使能
  122.
  123.         TIM_Cmd(TIM3, ENABLE);  //使能TIM14
  124. }
复制代码
打算用STM32F4做一个单脉冲实验,用TIM3输出PWM波作为触发源,TIM4的PB7设置为输入引脚,PB6设置为单脉冲输出引脚,我是PB6接灯或蜂鸣器直接观察效果,但是一直没有实现单脉冲的效果,不知道是不是配置错误,检查了很久也没发现问题所在,故前来请教大神们~
此帖出自stm32/stm8论坛
1、有示波器吗?用示波器测试一下PB6有没有脉冲输出。
2、建议你程序备注修改一下。
3、TIM_OCInitStructure.TIM_Pulse =3000;//设置跳变值是否大于你的频率值
4、看过去没发现程序有什么问题。
此帖出自stm32/stm8论坛
2、建议你程序备注修改一下。
3、TIM_OCInitStruct ...
嗯嗯,多谢!现在已经改好了,想用单脉冲方式实现,捕获一个上升延后延时一段时间输出一个脉宽可控的脉冲,示波器测出来延时不精确不太明白为什么
此帖出自stm32/stm8论坛
