2564|0
2721
MICROSTICK II上电 [复制链接]
Microstick II是microchip推出的支持3.3V 16位和32位PIC® 单片机及28引脚SPDIP封装16位dsPIC® 数字信号控制器(DSC)的成本最低开发工具,开发板包括一个集成的调试器和编程器、用户LED、复位按钮,以及便于器件更换的DUT插座。Microstick II工具(部件编号DM330013-2)附带USB电缆、两个供原型板使用的1x14排针、MCU样片和DSC样片,
开发板开箱
反面照
上电,绿色D2亮,红色D6闪烁,驱动安装成功后红色D6长亮
特性
  • Low Cost
  • Integrated USB programmer / debugger – No external debugger required
  • USB Powered – Ease of use, No external power required
  • MPLAB support.
  • DUT Socket – Flexible, Easy device replacement
  • 0.025” Pin headers – Enables plug-in to Breadboard with room for jumper wires
  • Easy access to all device signals for probing
  • Small size - Smaller than a stick of gum at 20 x76mm – Easily Portable
  • On board User LED and Reset Switch
  • Free demo code
包装单
  • Microstick II Board
  • USB Cable
  • 2 - 1x14 header pins for proto board use
  • 1 - PIC24FJ64GB002
  • 1 - PIC24HJ128GP502
  • 1 - DsPIC33FJ128MC802
  • 1 - PIC32MX250F128B
  • Info Sheet with installation instructions and board schematic
介绍
Product Category:Development Boards & Kits - PIC / DSPIC
Product:Evaluation Boards
Tool Is For Evaluation Of:PIC24FJ PIC24E PIC24H dsPIC33 PIC32
Core:dsPIC PIC
Description/Function:Microstick II for dsPIC33F and PIC24H devices
Dimensions:76 mm x 20 mm
Interface Type:USB
Operating Supply Voltage:5 V
Packaging:Bulk
