社区导航
搜索
查看: 1341|回复: 7
[讨论] 我想用串口显示出G2553内部温度的值,但在编译的时候出现了莫名的错误,对这个错误...
TA的帖子
Rank: 2
发表于 2015-8-16 15:15 | 显示全部楼层 |阅读模式
我想用串口显示出G2553内部温度的值,但在编译的时候出现了莫名的错误,请问一下哪错了啊?
#68 expected a "}"        msp430g2xx3_usci_uart_9600.c(这是编译的错误)
#include
#include
#include
#include  "msp430g2553.h"
* ======== Grace related declaration ========
extern void CSL_init(void);
char mystring[50] = "300 my test program!\r\n";
void ADC10_init(void);
void myputs(char * string);
*  ======== delay ========
void delay(unsigned int time_delay)
    unsigned int i,j,k,a;
    for(i = 0; i < time_delay; i++)
            for(j = 0; j < 20; j++)
                            for(k = 0; k < 20; k++)
                                            for(a = 0; a < 20; a++)
                                                    __delay_cycles(8);
*  ======== main ========
int main(void)
        int result;
        int temp;
        int IntDeg;
        CSL_init();
        ADC10_init();
    myputs(mystring);
    myputs("msp430 startup!erererer\r\n");
    __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
    while(1)
          ADC10CTL0 |= ENC + ADC10SC;            // Sampling and conversion start
     //     _bis_SR_register(CPUOFF + GIE);                // LPM0 with interrupts enabled
          __delay_cycles(1000);
          //-----ADC转换完成中断唤醒CPU后才执行以下代码-----
          temp = ADC10MEM;                                                        //读取AD采样值
          IntDeg= temp*4225/1024 - 2777;                //转换为摄氏度,并10倍处理
while(1)
            ADC10CTL0 |= ENC+ADC10SC;
            while((ADC10CTL0&ADC10IFG)==0);
            //result = ADC10MEM;
            IntDeg=(unsigned int)((result-746)/(0.24069)+286);//P64 in the book
            mystring[0] = (IntDeg/1000) + '0';
            mystring[1] = ((IntDeg%1000)/100) + '0';
            mystring[2] = ((IntDeg%100)/10) +'0';
            mystring[3] = (IntDeg%10) + '0';
            myputs(mystring);
            delay(50);
*  ======== string output ========
        unsigned char num;
        for( num = 0; num < strlen(string); num++ )
                        while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
                        UCA0TXBUF = string[num];                    // TX -> RXed character
void USCI0RX_ISR(void)
    UCA0TXBUF = UCA0RXBUF;                    // TX -> RXed character
        ADC10CTL0 &= ~ENC;
        ADC10CTL0 = ADC10IE + ADC10ON + REFON + ADC10SHT_3 + SREF_1;
    ADC10CTL1 = CONSEQ_0 + ADC10SSEL_0 + ADC10DIV_3 + SHS_0 + INCH_10;
      __delay_cycles(30000);
    ADC10CTL0 |= ENC;
* 名       称:ADC10_ISR_HOOK
* 功       能:ADC转换完成后唤醒CPU
* 入口参数:无
* 出口参数:无
* 说       明:直接从CCS的Example中移植过来
* 范       例:无
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR_HOOK(void)
        _bic_SR_register_on_exit(LPM4_bits);
使用道具 举报
1777
TA的帖子
Rank: 7Rank: 7Rank: 7
发表于 2015-8-16 16:59 | 显示全部楼层
语法错误,和}这个大括号有关,你再查一下代码
恩,已经解决了  详情 回复 发表于 2015-8-16 17:37
使用道具 举报
2243
TA的帖子
Rank: 6Rank: 6
发表于 2015-8-16 17:22 | 显示全部楼层
提示这么明显啊,程序少分号啊,看了下,在while(1)那
眼花  详情 回复 发表于 2015-8-16 17:38
使用道具 举报
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-16 17:37 | 显示全部楼层
恩,已经解决了
使用道具 举报
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-16 17:38 | 显示全部楼层
眼花
使用道具 举报
1366
TA的帖子
Rank: 5Rank: 5
发表于 2015-8-17 23:29 | 显示全部楼层
很明显,第一个while(1)下面少了这个 “}”符号
谢谢回答,已经解决了  详情 回复 发表于 2015-8-18 09:27
使用道具 举报
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-18 09:27 | 显示全部楼层
谢谢回答,已经解决了
不要在犯这些低级错误了  详情 回复 发表于 2015-8-18 22:43
使用道具 举报
1366
TA的帖子
Rank: 5Rank: 5
发表于 2015-8-18 22:43 | 显示全部楼层
易爆炸弹 发表于 2015-8-18 09:27
谢谢回答,已经解决了
不要在犯这些低级错误了
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-5-30 03:24 , Processed in 0.254062 second(s), 29 queries , Gzip On, MemCache On.
