2449|5
PID算法 [复制链接]
求PID算法,PID控制PWM的调速或是电机的C语言代码,请留言    非常感谢
一看就知道是卡掉了。。。。。  详情 回复 发表于 2015-8-11 17:37
#include
#include
    PID Function
    The PID (比例、积分、微分) function is used in mainly
    control applications. PIDCalc performs one iteration of the PID
    algorithm.
    While the PID function works, main is just a dummy program showing
    a typical usage.
typedef struct PID {
        double  SetPoint;           //  设定目标 Desired Value
        double  Proportion;         //  比例常数 Proportional Const
        double  Integral;           //  积分常数 Integral Const
        double  Derivative;         //  微分常数 Derivative Const
        double  LastError;          //  Error[-1]
        double  PrevError;          //  Error[-2]
        double  SumError;           //  Sums of Errors
} PID;
   PID计算部分
double PIDCalc( PID *pp, double NextPoint )
    double  dError,
            Error;
        Error = pp->SetPoint -  NextPoint;          // 偏差
        pp->SumError += Error;                      // 积分
        dError = pp->LastError - pp->PrevError;     // 当前微分
        pp->PrevError = pp->LastError;
        pp->LastError = Error;
        return (pp->Proportion * Error              // 比例项
            +   pp->Integral * pp->SumError         // 积分项
            +   pp->Derivative * dError             // 微分项
   Initialize PID Structure
void PIDInit (PID *pp)
    memset ( pp,0,sizeof(PID));
    Main Program
double sensor (void)                    //  Dummy Sensor Function
    return 100.0;
void actuator(double rDelta)            //  Dummy Actuator Function
void main(void)
    PID         sPID;                   //  PID Control Structure
    double      rOut;                   //  PID Response (Output)
    double      rIn;                    //  PID Feedback (Input)
    PIDInit ( &sPID );                  //  Initialize Structure
    sPID.Proportion = 0.5;              //  Set PID Coefficients
    sPID.Integral   = 0.5;
    sPID.Derivative = 0.0;
    sPID.SetPoint   = 100.0;            //  Set PID Setpoint
    for (;;) {                          //  Mock Up of PID Processing
        rIn = sensor ();                //  Read Input
        rOut = PIDCalc ( &sPID,rIn );   //  Perform PID Interation
        actuator ( rOut );              //  Effect Needed Changes
7815
57
裸片初长成(中级)
你求救也不用发两个啊,要不是看到是求救我还以为是恶意广告贴呢?
423
一看就知道是卡掉了。。。。。
谢谢啊
谢谢!!!!!!!!!!!!!
