社区导航
搜索
查看: 2051|回复: 3
兼容bbb的evb-335x-2,debian跑起来了
37
TA的帖子
Rank: 2
发表于 2015-8-7 15:01 | 显示全部楼层 |阅读模式
U-Boot 2014.04-rc2 (Aug 04 2015 - 15:32:20)
I2C:   ready
DRAM:  512 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net:   cpsw
Hit any key to stop autoboot:  0
1152054 bytes read in 75 ms (14.6 MiB/s)
mmc1(part 0) is current device
SD/MMC found on device 1
reading uEnv.txt
105 bytes read in 4 ms (25.4 KiB/s)
Loaded environment from uEnv.txt
Importing environment from mmc ...
reading uImage
4156576 bytes read in 257 ms (15.4 MiB/s)
reading com335x-emmc.dtb
32925 bytes read in 8 ms (3.9 MiB/s)
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-3.14.43-g875c69b
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4156512 Bytes = 4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Loading Kernel Image ... OK
   Loading Device Tree to 9fb4a000, end 9fb5509c ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.14.43-g875c69b (Vic@EAC) (gcc version 4.7.3 20130
226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2
013.03) ) #25 Mon Aug 3 15:50:42 CST 2015
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio
n cache
[    0.000000] Machine model: TI AM335x com335x
[    0.000000] cma: CMA: reserved 24 MiB at 9e000000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag
es: 129792
[    0.000000] Kernel command line: console=ttyO0,115200n8 tty0 noinitrd root=/d
ev/mmcblk0p2 rw rootfstype=ext4 rootwait lcdtype=AUO_AT070TN94 consoleblank=0
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 485448K/523264K available (5507K kernel code, 271K rwdata
, 2260K rodata, 252K init, 227K bss, 37816K reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc079e0c4   (7769 kB)
[    0.000000]       .init : 0xc079f000 - 0xc07de3b4   ( 253 kB)
[    0.000000]       .data : 0xc07e0000 - 0xc0823ce0   ( 272 kB)
[    0.000000]        .bss : 0xc0823ce0 - 0xc085cb80   ( 228 kB)
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup
ts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895
6969942ns
[    0.000036] OMAP clocksource: timer1 at 24000000 Hz
[    0.000308] Console: colour dummy device 80x30
[    0.000336] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[    0.089424] pid_max: default: 32768 minimum: 301
[    0.089527] Security Framework initialized
[    0.089585] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.089595] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.096549] CPU: Testing write buffer coherency: ok
[    0.096958] Setting up static identity map for 0x80566360 - 0x805663b8
[    0.097947] devtmpfs: initialized
[    0.099995] VFP support v0.3: implementor 41 architecture 3 part 30 variant c
rev 3
[    0.106979] omap_hwmod: tptc0 using broken dt data from edma
[    0.107061] omap_hwmod: tptc1 using broken dt data from edma
[    0.107133] omap_hwmod: tptc2 using broken dt data from edma
[    0.111304] omap_hwmod: debugss: _wait_target_disable failed
[    0.166683] pinctrl core: initialized pinctrl subsystem
[    0.167754] regulator-dummy: no parameters
[    0.170299] NET: Registered protocol family 16
[    0.172368] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.174980] cpuidle: using governor ladder
[    0.174996] cpuidle: using governor menu
[    0.181466] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb
] registered
[    0.182925] platform 49000000.edma: alias fck already exists
[    0.182948] platform 49000000.edma: alias fck already exists
[    0.182963] platform 49000000.edma: alias fck already exists
[    0.184109] OMAP GPIO hardware version 0.1
[    0.199319] No ATAGs?
[    0.199340] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.224863] bio: create slab at 0
[    0.241055] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.242096] vmmcsd_fixed: 3300 mV
[    0.245251] vgaarb: loaded
[    0.245790] i2c-core: driver [palmas] using legacy suspend method
[    0.245800] i2c-core: driver [palmas] using legacy resume method
[    0.246531] SCSI subsystem initialized
[    0.248036] usbcore: registered new interface driver usbfs
[    0.248224] usbcore: registered new interface driver hub
[    0.248419] usbcore: registered new device driver usb
[    0.249457] omap_i2c 44e0b000.i2c: could not find pctldev for node [url=]/pinmux@44[/url]
e10800/pinmux_i2c0_pins, deferring probe
[    0.249486] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[    0.249897] pps_core: LinuxPPS API ver. 1 registered
[    0.249909] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti <giometti@linux.it>
[    0.250045] PTP clock support registered
[    0.252050] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.252969] Advanced Linux Sound Architecture Driver Initialized.
[    0.254692] Switched to clocksource timer1
[    0.274119] NET: Registered protocol family 2
[    0.275154] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.275209] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.275255] TCP: Hash tables configured (established 4096 bind 4096)
[    0.275331] TCP: reno registered
[    0.275343] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.275361] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.275545] NET: Registered protocol family 1
[    0.275938] RPC: Registered named UNIX socket transport module.
[    0.275951] RPC: Registered udp transport module.
[    0.275957] RPC: Registered tcp transport module.
[    0.275964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.277144] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counter
s available
[    0.279942] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.443192] VFS: Disk quotas dquot_6.5.2
[    0.443261] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.443787] NFS: Registering the id_resolver key type
[    0.443868] Key type id_resolver registered
[    0.443878] Key type id_legacy registered
[    0.443933] msgmni has been set to 996
[    0.445486] NET: Registered protocol family 38
[    0.445532] io scheduler noop registered
[    0.445540] io scheduler deadline registered
[    0.445562] io scheduler cfq registered (default)
[    0.447325] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.453794] omap_uart 44e09000.serial: no wakeirq for uart0
[    0.453949] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud =
3000000) is a OMAP UART0
[    1.080853] console [ttyO0] enabled
[    1.085219] omap_uart 48022000.serial: no wakeirq for uart0
[    1.091168] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89, base_baud =
3000000) is a OMAP UART1
[    1.101492] omap_uart 48024000.serial: no wakeirq for uart0
[    1.107509] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90, base_baud =
3000000) is a OMAP UART2
[    1.117733] omap_uart 481a6000.serial: no wakeirq for uart0
[    1.123669] 481a6000.serial: ttyO3 at MMIO 0x481a6000 (irq = 60, base_baud =
3000000) is a OMAP UART3
[    1.133950] omap_uart 481a8000.serial: no wakeirq for uart0
[    1.139965] 481a8000.serial: ttyO4 at MMIO 0x481a8000 (irq = 61, base_baud =
3000000) is a OMAP UART4
[    1.151052] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[    1.158428] [drm] Initialized drm 1.1.0 20060810
[    1.174183] brd: module loaded
[    1.182990] loop: module loaded
[    1.186950] (hci_tty): inside hci_tty_init
[    1.191683] (hci_tty): allocated 249, 0
[    1.201460] CAN device driver interface
[    1.206986] c_can_platform 481cc000.can: c_can_platform device registered (re
gs=fa1cc000, irq=68)
[    1.218275] usbcore: registered new interface driver asix
[    1.224156] usbcore: registered new interface driver ax88179_178a
[    1.230733] usbcore: registered new interface driver cdc_ether
[    1.237050] usbcore: registered new interface driver smsc95xx
[    1.243242] usbcore: registered new interface driver net1080
[    1.249324] usbcore: registered new interface driver cdc_subset
[    1.255695] usbcore: registered new interface driver zaurus
[    1.261781] usbcore: registered new interface driver cdc_ncm
[    1.268295] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.275160] ehci-pci: EHCI PCI platform driver
[    1.280015] ehci-omap: OMAP-EHCI Host Controller driver
[    1.286018] usbcore: registered new interface driver cdc_wdm
[    1.292157] usbcore: registered new interface driver usb-storage
[    1.300839] 47401300.usb-phy supply vcc not found, using dummy regulator
[    1.310618] musb-hdrc musb-hdrc.0.auto: Failed to request rx1.
[    1.316918] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with stat
us -517
[    1.325105] platform musb-hdrc.0.auto: Driver musb-hdrc requests probe deferr
al
[    1.333544] 47401b00.usb-phy supply vcc not found, using dummy regulator
[    1.343174] musb-hdrc musb-hdrc.1.auto: Failed to request rx1.
[    1.349449] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with stat
us -517
[    1.357626] platform musb-hdrc.1.auto: Driver musb-hdrc requests probe deferr
al
[    1.379963] mousedev: PS/2 mouse device common for all mice
[    1.387554] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified
[    1.394955] input: ti-tsc as /devices/ocp/44e0d000.tscadc/TI-am335x-tsc/input
/input0
[    1.404924] i2c-core: driver [rtc-ds1307] using legacy suspend method
[    1.411669] i2c-core: driver [rtc-ds1307] using legacy resume method
[    1.419221] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    1.427589] i2c /dev entries driver
[    1.431398] Driver for 1-wire Dallas network protocol.
[    1.438385] ISL88013 of_get_gpio:111
[    1.485247] 481d8000.mmc supply vmmc not found, using dummy regulator
[    1.495623] omap_hsmmc 481d8000.mmc: could not set regulator OCR (-22)
[    1.536394] ledtrig-cpu: registered to indicate activity on CPUs
[    1.543026] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    1.550611] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    1.558187] usbcore: registered new interface driver usbhid
[    1.564019] usbhid: USB HID core driver
[    1.568398] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
[    1.580239] davinci_evm sound: ASoC: CODEC (null) not registered
[    1.586707] davinci_evm sound: snd_soc_register_card failed (-517)
[    1.593192] platform sound: Driver davinci_evm requests probe deferral
[    1.601620] oprofile: using arm/armv7
[    1.605878] TCP: cubic registered
[    1.609345] Initializing XFRM netlink socket
[    1.613827] NET: Registered protocol family 17
[    1.618575] NET: Registered protocol family 15
[    1.623233] can: controller area network core (rev 20120528 abi 9)
[    1.629786] NET: Registered protocol family 29
[    1.634468] can: raw protocol (rev 20120528)
[    1.639008] can: broadcast manager protocol (rev 20120528 t)
[    1.644969] can: netlink gateway (rev 20130117) max_hops=1
[    1.650871] Key type dns_resolver registered
[    1.656195] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regu
lator/voltdm: -517
[    1.665353] cpu cpu0: cpu0 clock notifier not ready, retry
[    1.671184] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe defer
ral
[    1.679707] PM: bootloader does not support rtc-only!
[    1.685103] ThumbEE CPU extension supported.
[    1.689599] Registering SWP/SWPB emulation handler
[    1.695829] regulator-dummy: disabling
[    1.700537] Error: Driver 'tfp410' is already registered, aborting...
[    1.709855] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.716816] [drm] No driver support for vblank timestamp query.
[    1.768110] Console: switching to colour frame buffer device 100x30
[    1.777919] tilcdc 4830e000.lcdc: fb0:  frame buffer device
[    1.783749] tilcdc 4830e000.lcdc: registered panic notifier
[    1.789622] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[    1.799931] DCDC1: at 1500 mV
[    1.804408] vdd_mpu: 925 <--> 1325 mV at 1275 mV
[    1.809402] mmc0: host does not support reading read-only switch. assuming wr
ite-enable.
[    1.819019] vdd_core: 925 <--> 1150 mV at 1125 mV
[    1.824134] mmc0: new high speed SDHC card at address 59b4
[    1.831097] mmcblk0: mmc0:59b4 00000 7.34 GiB
[    1.835957] LDO1: at 1800 mV
[    1.840709]  mmcblk0: p1 p2
[    1.844060] LDO2: at 3300 mV
[    1.848913] LDO3: at 1800 mV
[    1.856284] LDO4: at 3300 mV
[    1.860476] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    1.867298] rtc-ds1307 0-0068: SET TIME!
[    1.872516] rtc-ds1307 0-0068: rtc core: registered ds1339 as rtc1
[    1.879047] omap_hsmmc 481d8000.mmc: exceeding card's volts
[    1.888792] 0-001b supply IOVDD not found, using dummy regulator
[    1.895234] 0-001b supply DVDD not found, using dummy regulator
[    1.901473] 0-001b supply AVDD not found, using dummy regulator
[    1.907758] 0-001b supply DRVDD not found, using dummy regulator
[    1.914762] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    1.922083] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.931981] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[    1.938579] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus
number 1
[    1.947194] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.954324] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
[    1.961908] usb usb1: Product: MUSB HDRC host driver
[    1.967116] usb usb1: Manufacturer: Linux 3.14.43-g875c69b musb-hcd
[    1.973674] usb usb1: SerialNumber: musb-hdrc.0.auto
[    1.979992] hub 1-0:1.0: USB hub found
[    1.984011] hub 1-0:1.0: 1 port detected
[    1.992536] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.999172] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus
number 2
[    2.007658] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.014809] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
[    2.022367] usb usb2: Product: MUSB HDRC host driver
[    2.027574] usb usb2: Manufacturer: Linux 3.14.43-g875c69b musb-hcd
[    2.034130] usb usb2: SerialNumber: musb-hdrc.1.auto
[    2.040345] hub 2-0:1.0: USB hub found
专业AM335X主板
artcor.taobao.com
QQ:3247613929
使用道具 举报
37
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 15:02 | 显示全部楼层
专业AM335X主板
artcor.taobao.com
QQ:3247613929
使用道具 举报
37
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 15:03 | 显示全部楼层
专业AM335X主板
artcor.taobao.com
QQ:3247613929
使用道具 举报
37
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-12 16:41 | 显示全部楼层
兼容bbb的evb-335x-2,debian已上市了,
网址:https://item.taobao.com/item.htm ... eCi9&id=44233615132
专业AM335X主板
artcor.taobao.com
QQ:3247613929
使用道具 举报
站长推荐上一条 1/4 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-6-3 23:42 , Processed in 0.169204 second(s), 25 queries , Gzip On, MemCache On.
