社区导航
搜索
查看: 2412|回复: 8
[求助] 为什么陀螺仪数据不变?
41
TA的帖子
Rank: 2
发表于 2015-8-7 11:47 | 显示全部楼层 |阅读模式
时钟我用的是HSI(36mhz),使用SPI读取L3GA20的值,在调试时,全速运行时感觉会卡,单步运行没问题,陀螺仪的数据不会变?
void Gyro_ReadAngRate (float* pfData)
  uint8_t tmpbuffer[6] ={0};
  int16_t RawData[3] = {0};
  uint8_t tmpreg = 0;
  float sensitivity = 0;
  int i =0;
  L3GD20_Read(&tmpreg,L3GD20_CTRL_REG4_ADDR,1);
  L3GD20_Read(tmpbuffer,L3GD20_OUT_X_L_ADDR,6);
  if(!(tmpreg & 0x40))
  for(i=0; i<3; i++)
      RawData=(int16_t)(((uint16_t)tmpbuffer[2*i+1] << 8) + tmpbuffer[2*i]);//ÏȶÁµÍλ
  else
    for(i=0; i<3; i++)
      RawData=(int16_t)(((uint16_t)tmpbuffer[2*i] << 8) + tmpbuffer[2*i+1]);//ÏȶÁ¸ßλ
  switch(tmpreg & 0x30)
  case 0x00:
    sensitivity=L3G_Sensitivity_250dps;  //L3G_Sensitivity_500dps=360/pi
    break;
  case 0x10:
  sensitivity=L3G_Sensitivity_500dps;  //L3G_Sensitivity_500dps=180/pi=57.1429
    break;
  case 0x20:
    sensitivity=L3G_Sensitivity_2000dps;//L3G_Sensitivity_500dps=1/4*180/pi
    break;
for(i=0; i<3; i++)
    pfData=(float)RawData/sensitivity; //¶Á³öÊý¾Ý³ýÒÔÁ¿³Ì
各位大神看看是哪有问题,不甚感激!
此帖出自stm32/stm8论坛
使用道具 举报
41
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 11:53 | 显示全部楼层
void gyro_Config(void)
        L3GD20_InitTypeDef   L3GD20_InitStructure;
        L3GD20_FilterConfigTypeDef   L3GD20_FilterConfigStructure;
        L3GD20_InitStructure.Power_Mode=L3GD20_MODE_ACTIVE;//L3GD20_MODE_POWERDOWN;
        L3GD20_InitStructure.Output_DataRate=L3GD20_OUTPUT_DATARATE_1;
        L3GD20_InitStructure.Axes_Enable=L3GD20_AXES_ENABLE;
        L3GD20_InitStructure.Band_Width=L3GD20_BANDWIDTH_4;
        L3GD20_InitStructure.BlockData_Update=L3GD20_BlockDataUpdate_Continous;//L3GD20_BlockDataUpdate_Single;
        L3GD20_InitStructure.Endianness=L3GD20_BLE_MSB;//ÏÈ´Ó¸ßλ·¢ËÍ
        L3GD20_InitStructure.Full_Scale=L3GD20_FULLSCALE_500;
        L3GD20_Init(&L3GD20_InitStructure);
        L3GD20_FilterConfigStructure.HighPassFilter_Mode_Selection=L3GD20_HPM_AUTORESET_INT;// L3GD20_HPM_NORMAL_MODE;
  L3GD20_FilterConfigStructure.HighPassFilter_CutOff_Frequency=L3GD20_HPFCF_0;
        L3GD20_FilterConfig(&L3GD20_FilterConfigStructure);
        //L3GD20_InterruptConfigStructure.Latch_Request=
        //L3GD20_InterruptConfigStructure.Interrupt_Axes=
        //L3GD20_InterruptConfigStructure.Interrupt_ActiveEdge=L3GD20_INT1INTERRUPT_HIGH_EDGE;
使用道具 举报
41
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 12:09 | 显示全部楼层
这是主函数:
int main(void)
        RCC_configuration();
        //RCC_GetClocksFreq(&clock);
        gyro_Config();
  while (1)
          //L3GD20_Read(l3gd20_id,L3GD20_ID,1);//¶ÁÈ¡ÍÓÂÝÒǵÄID
                //L3GD20_Read(tmp,L3GD20_CTRL_REG4_ADDR,1);
                //L3GD20_Read(tmpbuffer,L3GD20_OUT_X_L_ADDR,6);
    Gyro_ReadAngRate(GyroBuffer);
使用道具 举报
41
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 12:26 | 显示全部楼层
我不知道是不是我没说清楚,为什么没人理我,这问题已经困扰我两天了,读出的数据是对的,但是全速运行时数据不会变。
使用道具 举报
41
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 17:22 | 显示全部楼层
已解决忘了打勾了
使用道具 举报
41
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 17:23 | 显示全部楼层
使用道具 举报
TA的帖子
Rank: 1
发表于 2015-8-7 17:25 | 显示全部楼层
怎么解决的??
在调试的时候,在view中将periodic windows update打勾,我忘打了,还以为时序有问题。  详情 回复 发表于 2015-8-7 18:22
使用道具 举报
41
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 18:21 | 显示全部楼层
使用道具 举报
41
TA的帖子
Rank: 2
 楼主| 发表于 2015-8-7 18:22 | 显示全部楼层
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-6-1 23:03 , Processed in 0.326634 second(s), 31 queries , Gzip On, MemCache On.
