社区导航
搜索
查看: 1889|回复: 1
[求助] 写了老长时间,相位差程序就是没用,以至于功率因素也搞不出来,大神们求帮忙看下程序
TA的帖子
Rank: 1
发表于 2015-8-6 09:37 | 显示全部楼层 |阅读模式
5芯积分
#include
//#include "cry1602.c"
//#include "cry1602.h"
#include "cryfucns.h"
#include "displaydata.h"
#include
#include "BoardConfig.h"
char buf[];
float start;
float end;
int overflow;
//float pwm;
//float pwm_cha;
//int pwm_start1,pwm_end1,pwm_wide1;
//int pwm_start2,pwm_end2,pwm_wide2;
const unsigned char inaddr=0x84; //LCD第1行,输入数据地址
void int_clk()
    unsigned char i;
    BCSCTL1&=~XT2OFF;  //打开XT振荡器
    do
        IFG1 &= ~OFIFG;                 //清除振荡错误标志
        for(i = 0; i < 100; i++)
          _NOP();                        //延时等待
    while ((IFG1 & OFIFG) != 0);        //如果标志为1继续循环等待
    BCSCTL2|=SELM1+SELS;//MCLK 8M and SMCLK 8M
    IFG1&=~OFIFG;
/* void mainttt()
    WDTCTL = WDTPW + WDTHOLD;     //关闭看门狗
    BoardConfig(0xb2);            //关闭数码管和流水灯,4245
    int_clk();   //初始化时钟,MCLK 8M and SMCLK 8M
    Ini_Lcd();   //初始化LCD
    Send(0,0x01);            //清屏
    Disp_SZ2(0x80, 5,0.5);
    //Disp_HZ(0x80,line1,2);  //显示3行汉字
    //Disp_HZ(0x90,line2,4);
   // Disp_HZ(0x88,line3,4);
    //Disp_HZ(0x98,line4,2);
     _EINT(); //开全局中断
    while(1);
void main(void)
       Ini_Lcd();   //初始化LCD
        //P2SEL|=BIT2;
        //P2SEL|=BIT3;
        P1SEL |= BIT2;                             //设置P1.2端口为功能模块使用
        TACTL |=TACLR;
        TACTL = TASSEL_2+TAIE+MC1;          //定时器A时钟信号选择SMCLK 8M,清计数寄存器,使能中断,同时设置定时器A计数模式为连续增计模式
        CCTL1 =CM0+SCS+CAP+CCIE;                //输入上升沿捕获,同步,capture模式 CCI0A为捕获信号源,中断使能
        //TACCTL1 &=~CCIFG; //清CCR2 的标志位
        //中断允许
        /*TACTL |=TACLR;
        CCTL1 =CM0+SCS+CAP+CCIE;*/
        //CCTL1 = CCIE;                             // CCR0 interrupt enabled
        //CCR1 = 20000;
        //TACTL = TASSEL_2 + MC_2;                  // SMCLK, upmode
// _EINT();
        //TACCTL1 = CAP+CM_3+CCIS_0+SCS+CCIE;
        //TACCTL2 = CAP+CM_3+CCIS_0+SCS+CCIE;
        //TACTL = TASSEL_2+MC_2;
        _EINT();
        LPM0;
        _NOP();
           // while(1)
                if(pwm_end1>=pwm_start1)
                        pwm_wide1=(pwm_end1-pwm_start1)*2;
                else if(pwm_end1                 {
                        pwm_wide1=(pwm_start1-pwm_end1)*2;
                pwm_cha=pwm_start1-pwm_start2;
                pwm=pwm_cha/pwm_wide1*360;*/
               // WDTCTL=WDT_ADLY_1000;
                Send(0,0x01);            //清屏
                //Disp_SZ2(inaddr, (int)pwm,pwm-(int)pwm);
                Disp_SZ2(inaddr, (int)start,start-(int)start);
                Disp_HZ(0x80,line1,3);  //显示3行汉字
                while(1);
                //P6DIR|=BIT2:P6OUT|=BIT2;
                //LcdReset();
                //sprintf(buf,"%f",pwm);
                //DispNChar(3,0,4,buf);
/*#pragma vector=TIMERA1_VECTOR
__interrupt void Timer_A(void)
        switch(TAIV)
{case 2:
        if(TACCTL1 & CCI)
          pwm_start1=CCR1;
        else
          pwm_end1=CCR1;
        break;
case 4:
        if(TACCTL2 & CCI)
          pwm_start2=CCR2;
        else
          pwm_end2=CCR2;
        break;
case10:
        break;
LPM0_EXIT;
return;
#pragma vector=TIMERA1_VECTOR              //定时器A中断处理
__interrupt void timer_a(void)
switch(TAIV)                              //向量查询
  { case 2:                                //捕获中断
       if(CCTL1&CM0)                      //上升沿
           CCTL1=(CCTL1&(~CM0))|CM1;       //更变设置为下降沿触发
           start=TACCR1;                      //记录初始时间
           overflow=0;                     //溢出计数变量复位
       else if(CCTL1&CM1)                 //下降沿
         CCTL1=(CCTL1&(~CM1))|CM0;       //更变设置为上升沿触发
         end=TACCR1;                        //用start,end,overflow计算脉冲宽度
         TACTL &=~TAIE;                    //不使能中断
         CCTL1 &=~CCIE;
         P1SEL &=~BIT2;
         _DINT();
         LPM0_EXIT;
       break;
    case 10:                               //定时器溢出中断
       overflow++;
       break;                              //溢出计数加1
    default:break;
使用道具 举报
39
TA的帖子
Rank: 2
发表于 2015-8-8 15:59 | 显示全部楼层
如果不要求频率,你可以用delay试试……去年我学姐就是这样移相的
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-5-30 04:18 , Processed in 0.109562 second(s), 19 queries , Gzip On, MemCache On.
