社区导航
搜索
查看: 3540|回复: 4
[讨论] DSP 28335 SCI输出延迟一个值?
TA的帖子
Rank: 1
发表于 2015-8-3 17:07 | 显示全部楼层 |阅读模式
DSP 28335 SCI输出延迟一个值,新人求助,望大神们指点一二!
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
// Prototype statements for functions found within this file.
void scib_echoback_init(void);
void scib_fifo_init(void);
void scib_xmit(Uint16 a);
void scib_msg(char *msg);
// Global counts used in this example
Uint16 LoopCount;
Uint16 ErrorCount;
void main(void)
    Uint16 ReceivedChar;
        Uint16 i;
    char *msg;
   InitSysCtrl();
   InitScibGpio();
   DINT;
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
    LoopCount = 0;
    ErrorCount = 0;
    scib_fifo_init();           // Initialize the SCI FIFO
    scib_echoback_init();  // Initalize SCI for echoback
    ScibRegs.SCIFFRX.bit.RXFFOVRCLR=1;
        for(;;)
//      while(ScibRegs.SCIFFRX.bit.RXFFST !=1) { } // wait for XRDY =1 for empty state
//      ReceivedChar = ScibRegs.SCIRXBUF.all;
       // Echo character back
           for(i=1;i<255;i++)
               scib_xmit(i);
                DELAY_US(1);
       LoopCount++;
// Test 1,SCIA  DLB, 8-bit word, baud rate 0x000F, default, 1 STOP bit, no parity
void scib_echoback_init()
    // Note: Clocks were turned on to the Scib peripheral
    // in the InitSysCtrl() function
        ScibRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
        ScibRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
        ScibRegs.SCICTL2.all =0x0003;
        ScibRegs.SCICTL2.bit.TXINTENA =1;
        ScibRegs.SCICTL2.bit.RXBKINTENA =1;
        #if (CPU_FRQ_150MHZ)
              ScibRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 37.5MHz.
              ScibRegs.SCILBAUD    =0x00E7;
        #endif
        #if (CPU_FRQ_100MHZ)
      ScibRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 20MHz.
      ScibRegs.SCILBAUD    =0x0044;
        #endif
        ScibRegs.SCICTL1.all =0x0023;  // Relinquish SCI from Reset
// Transmit a character from the SCI
//    ScibRegs.SCITXBUF=a;
    while (ScibRegs.SCIFFTX.bit.TXFFST != 0) {}
void scib_msg(char * msg)
    int i;
    i = 0;
    while(msg[i] != '\0')
        scib_xmit(msg[i]);
        i++;
// Initalize the SCI FIFO
void scib_fifo_init()
//    ScibRegs.SCIFFTX.all=0xE040;
        ScibRegs.SCIFFTX.all=0xE04f;
    ScibRegs.SCIFFRX.all=0x204f;
    ScibRegs.SCIFFCT.all=0x0;
使用道具 举报
700
TA的帖子
Rank: 6Rank: 6
发表于 2015-8-7 20:28 | 显示全部楼层
什么意思?
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2015-8-11 20:39 | 显示全部楼层
感谢你得回答!就是发送延迟输出一个单元,问题已经解决了
最好和大家分享一下。  详情 回复 发表于 2015-8-12 12:26
使用道具 举报
700
TA的帖子
Rank: 6Rank: 6
发表于 2015-8-12 12:26 | 显示全部楼层
最好和大家分享一下。
使用道具 举报
TA的帖子
Rank: 1
发表于 2017-7-23 15:35 | 显示全部楼层
求楼主分享下解决方法,遇到同样问题
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-5-26 14:38 , Processed in 0.218973 second(s), 25 queries , Gzip On, MemCache On.
