知道了,因为我家板子是MSP430F5529A,寄存器的名字变了,需要回去看.h文件,找找就是了。只是不知道对应IFG1的是什么。IFG1是看门狗模块里的一个“SFR中断标志寄存器”,但是.h文件中的看门狗貌似找不到对应的寄存器,这个求指点。
* WATCHDOG TIMER A
#define __MSP430_HAS_WDT_A__ /* Definition to show that Module is available */
#define WDTCTL_ (0x015C) /* Watchdog Timer Control */
DEFCW( WDTCTL , WDTCTL_)
/* The bit names have been prefixed with "WDT" */
/* WDTCTL Control Bits */
#define WDTIS0 (0x0001) /* WDT - Timer Interval Select 0 */
#define WDTIS1 (0x0002) /* WDT - Timer Interval Select 1 */
#define WDTIS2 (0x0004) /* WDT - Timer Interval Select 2 */
#define WDTCNTCL (0x0008) /* WDT - Timer Clear */
#define WDTTMSEL (0x0010) /* WDT - Timer Mode Select */
#define WDTSSEL0 (0x0020) /* WDT - Timer Clock Source Select 0 */
#define WDTSSEL1 (0x0040) /* WDT - Timer Clock Source Select 1 */
#define WDTHOLD (0x0080) /* WDT - Timer hold */
#define WDTIS0_L (0x0001) /* WDT - Timer Interval Select 0 */
#define WDTIS1_L (0x0002) /* WDT - Timer Interval Select 1 */
#define WDTIS2_L (0x0004) /* WDT - Timer Interval Select 2 */
#define WDTCNTCL_L (0x0008) /* WDT - Timer Clear */
#define WDTTMSEL_L (0x0010) /* WDT - Timer Mode Select */
#define WDTSSEL0_L (0x0020) /* WDT - Timer Clock Source Select 0 */
#define WDTSSEL1_L (0x0040) /* WDT - Timer Clock Source Select 1 */
#define WDTHOLD_L (0x0080) /* WDT - Timer hold */
#define WDTPW (0x5A00)
#define WDTIS_0 (0*0x0001u) /* WDT - Timer Interval Select: /2G */
#define WDTIS_1 (1*0x0001u) /* WDT - Timer Interval Select: /128M */
#define WDTIS_2 (2*0x0001u) /* WDT - Timer Interval Select: /8192k */
#define WDTIS_3 (3*0x0001u) /* WDT - Timer Interval Select: /512k */
#define WDTIS_4 (4*0x0001u) /* WDT - Timer Interval Select: /32k */
#define WDTIS_5 (5*0x0001u) /* WDT - Timer Interval Select: /8192 */
#define WDTIS_6 (6*0x0001u) /* WDT - Timer Interval Select: /512 */
#define WDTIS_7 (7*0x0001u) /* WDT - Timer Interval Select: /64 */
#define WDTIS__2G (0*0x0001u) /* WDT - Timer Interval Select: /2G */
#define WDTIS__128M (1*0x0001u) /* WDT - Timer Interval Select: /128M */
#define WDTIS__8192K (2*0x0001u) /* WDT - Timer Interval Select: /8192k */
#define WDTIS__512K (3*0x0001u) /* WDT - Timer Interval Select: /512k */
#define WDTIS__32K (4*0x0001u) /* WDT - Timer Interval Select: /32k */
#define WDTIS__8192 (5*0x0001u) /* WDT - Timer Interval Select: /8192 */
#define WDTIS__512 (6*0x0001u) /* WDT - Timer Interval Select: /512 */
#define WDTIS__64 (7*0x0001u) /* WDT - Timer Interval Select: /64 */
#define WDTSSEL_0 (0*0x0020u) /* WDT - Timer Clock Source Select: SMCLK */
#define WDTSSEL_1 (1*0x0020u) /* WDT - Timer Clock Source Select: ACLK */
#define WDTSSEL_2 (2*0x0020u) /* WDT - Timer Clock Source Select: VLO_CLK */
#define WDTSSEL_3 (3*0x0020u) /* WDT - Timer Clock Source Select: reserved */
#define WDTSSEL__SMLCK (0*0x0020u) /* WDT - Timer Clock Source Select: SMCLK */
#define WDTSSEL__ACLK (1*0x0020u) /* WDT - Timer Clock Source Select: ACLK */
#define WDTSSEL__VLO (2*0x0020u) /* WDT - Timer Clock Source Select: VLO_CLK */
/* WDT-interval times [1ms] coded with Bits 0-2 */
/* WDT is clocked by fSMCLK (assumed 1MHz) */
#define WDT_MDLY_32 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2) /* 32ms interval (default) */
#define WDT_MDLY_8 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2+WDTIS0) /* 8ms " */
#define WDT_MDLY_0_5 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2+WDTIS1) /* 0.5ms " */
#define WDT_MDLY_0_064 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2+WDTIS1+WDTIS0) /* 0.064ms " */
/* WDT is clocked by fACLK (assumed 32KHz) */
#define WDT_ADLY_1000 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2+WDTSSEL0) /* 1000ms " */
#define WDT_ADLY_250 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2+WDTSSEL0+WDTIS0) /* 250ms " */
#define WDT_ADLY_16 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2+WDTSSEL0+WDTIS1) /* 16ms " */
#define WDT_ADLY_1_9 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS2+WDTSSEL0+WDTIS1+WDTIS0) /* 1.9ms " */
/* Watchdog mode -> reset after expired time */
#define WDT_MRST_32 (WDTPW+WDTCNTCL+WDTIS2) /* 32ms interval (default) */
#define WDT_MRST_8 (WDTPW+WDTCNTCL+WDTIS2+WDTIS0) /* 8ms " */
#define WDT_MRST_0_5 (WDTPW+WDTCNTCL+WDTIS2+WDTIS1) /* 0.5ms " */
#define WDT_MRST_0_064 (WDTPW+WDTCNTCL+WDTIS2+WDTIS1+WDTIS0) /* 0.064ms " */
#define WDT_ARST_1000 (WDTPW+WDTCNTCL+WDTSSEL0+WDTIS2) /* 1000ms " */
#define WDT_ARST_250 (WDTPW+WDTCNTCL+WDTSSEL0+WDTIS2+WDTIS0) /* 250ms " */
#define WDT_ARST_16 (WDTPW+WDTCNTCL+WDTSSEL0+WDTIS2+WDTIS1) /* 16ms " */
#define WDT_ARST_1_9 (WDTPW+WDTCNTCL+WDTSSEL0+WDTIS2+WDTIS1+WDTIS0) /* 1.9ms " */
* Interrupt Vectors (offset from 0xFF80)
