1835|1
求帮忙,我想让它从0050开始累加 [复制链接]
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity jifei is
port(kmout:in std_logic;
     enable:in std_logic;
     reset:in std_logic;
     count1,count2,count3,count4:out std_logic_vector(3 downto 0));
end jifei;
architecture one of jifei is
begin
process(kmout,reset)
variable q1,q2,q3,q4:std_logic_vector(3 downto 0);
constant a:std_logic_vector(3 downto 0):="0101";
begin
q2:=a;
if kmout'event and kmout='1'  then
if reset='1' then
count1<="0000";count2<="0101";count3<="0000";count4<="0000";
elsif enable='0' then
elsif enable='1'  then
  if q1<"0100" then
  q1:=q1+6;
  if q2<"1001" then
q2:=q2+1;
else q2:=q2-9;
   if q3<"1001" then
q3:=q3+1;
else q3:="0000";
   if q4<"1001" then
q4:=q4+1;
else q4:="0000";
end if;
end if;
end if;
else q1:=q1-4;
if q2<"1000" then
q2:=q2+2;
else q2:=q2-8;
if q3<"1001" then
q3:=q3+1;
else q3:="0000";
  if q4<"1001" then
q4:=q4+1;
else q4:="0000";
end if;
end if;
end if;
end if;
count1<=q1;
count2<=q2;
count3<=q3;
count4<=q4;
end if;
end if;
end process;
end one;
程序如上
仿真如下
count4到count1代表千百十个位,现在是从0000开始16的累加,我想让它从0050开始16累加,请问该怎么改?
file:///C:\Users\Administrator\AppData\Roaming\Tencent\Users\815223478\QQ\WinTemp\RichOle\HWGW`VJ5]]5)5`71@(~0}FW.png
此帖出自FPGA/CPLD论坛
你为啥要定义q1~q4这四个变量啊?直接用counter1~counter4计数不就可以了吗?  详情 回复 发表于 2015-5-21 23:05
375
此帖出自FPGA/CPLD论坛
