1226|1
22
仿真求助
​初学FPGA,做了个简单的testbench试验。用quartus直接调用modelsim,做仿真,modelsim出现问题如下,停止仿真。求解决方法。
# ** Error: $MODEL_TECH/../vhdl_src/std/textio.vhd(18): Unknown identifier 'read_mode'.
# ** Error: $MODEL_TECH/../vhdl_src/std/textio.vhd(18): (vcom-1112) FILE declaration using 1076-1993 syntax. Recompile using the -93 option.
# ** Error: $MODEL_TECH/../vhdl_src/std/textio.vhd(18): VHDL Compiler exiting
# ** Error: C:/Modeltech_6.0/win32/vcom failed.
# Error in macro ./add_vhdl_run_msim_rtl_vhdl.do line 9
# C:/Modeltech_6.0/win32/vcom failed.
源:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity add_vhdl is
  port(
        A:in std_logic;
        B:in std_logic;
        Cin:in std_logic;
        Sum:out std_logic;
        Cout:out std_logic
end entity;
architecture BEHAVIOR of add_vhdl is
    function Majority (A,B,C:std_logic)
    return std_logic is
      begin
        return ((A and B) or (A and C) or (B and C));
    end Majority;
    begin
    Sum<=A xor B xor Cin;
    Cout<=Majority(A,B,Cin);
end BEHAVIOR;
testbench:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY add_vhdl_vhd_tst IS
END add_vhdl_vhd_tst;
ARCHITECTURE add_vhdl_arch OF add_vhdl_vhd_tst IS
-- constants
-- signals
SIGNAL A : STD_LOGIC;
SIGNAL B : STD_LOGIC;
SIGNAL Cin : STD_LOGIC;
SIGNAL Cout : STD_LOGIC;
SIGNAL Sum : STD_LOGIC;
COMPONENT add_vhdl
    PORT (
    A : IN STD_LOGIC;
    B : IN STD_LOGIC;
    Cin : IN STD_LOGIC;
    Cout : OUT STD_LOGIC;
    Sum : OUT STD_LOGIC
END COMPONENT;
BEGIN
    i1 : add_vhdl
    PORT MAP (
    A => A,
    B => B,
    Cin => Cin,
    Cout => Cout,
    Sum => Sum
always : PROCESS
BEGIN
      wait for 1ns;
        A='0';B='0';Cin='0';--000     00
     wait for 1ns;
        A='0';B='0';Cin='1';--001     10
     wait for 1ns;
        A='0';B='1';Cin='1';--011     01
     wait for 1ns;
        A='0';B='1';Cin='0';--010     10
     wait for 1ns;
        A='1';B='1';Cin='0';--110     01
     wait for 1ns;
        A='1';B='1';Cin='1';--111     11
     wait for 1ns;
        A='1';B='0';Cin='1';--101     01
     wait for 1ns;
        A='1';B='0';Cin='0';--100     10
     wait for 1ns;
      WAIT;
END PROCESS always;
END add_vhdl_arch;
此帖出自FPGA/CPLD论坛
78
讲的超级棒 ,非常厉害,看来非常有收获
