6511|8
92
ucosII在什么时候会发生任务调度?
请教大虾们,ucosII在什么时候会发生任务调度?
576
任务自己放弃cpu或者被更高优先级的任务所抢占,建议使用raw-os.
谢谢!  详情 回复 发表于 2015-4-7 10:32
92
谢谢!
stick  prio sechel     都可以触发调度
os里5个链表,你搞明白UCOS就差不多理解了
29
建议参考uCOS的user manual,里面有详细的说明所有的scheduling points
A task signals or sends a message to another task;
A task calls OSTimeDly() or OSTimeDlyHMSM();
A task waits for an event to occur and the event has not yet occurred;
If a task aborts a pend;
If a task is created;
If a task is deleted;
If a kernel object is deleted;
A task changes the priority of itself or another task;
A task suspends itself by calling OSTaskSuspend();
A task resumes another task that was suspended by OSTaskSuspend();
At the end of all nested ISRs;
The scheduler is unlocked by calling OSSchedUnlock();
A task gives up its time quanta by calling OSSchedRoundRobinYield();
The user calls OSSched();
32
长知识了
92
A task signals or sends a messag ...
只要是在函数中调用到了Sched ()函数都会发生任务的调度,但是在本函数中,也有判断是否存在任务优先级高于调用本任务的优先级,如果有更高的优先级,那么进行调度,如果没有,返回原函数。当然IntNesting宏判断是否存在中断运行也是必要的  总的来说   只要有Sched ()就会存在调度的可能性  具体的从实际中出发会好理解
