3278|4
求帮忙看下为什么这个程序一开始流水灯从左到右循环后,别的按键都不起作用了 [复制链接]
#include
#include
#define GPI0_LED P0
#define GPI0_KEY P1
void Delay10ms(unsigned int c);
unsigned char Key_Scan();
void LED1();
void LED2();
void LED3();
void LED4();
void LED5();
void LED6();
void LED7();
void LED8();
void main(void)
    unsigned char keyNum;
        while(1)
        {   keyNum=Key_Scan();
                switch (keyNum)
                    case(0xEF):
                               LED1();
                               break;
                        case(0xDF):
                               LED2();
                               break;
                        case(0xBF):
                               LED3();
                               break;
                        case(0x7F):
                               LED4();
                               break;
                        case(0xFE):
                               LED5();
                                   break;
                        case(0xFD):
                               LED6();
                                   break;
                        case(0xFB):
                               LED7();
                                   break;
                        case(0xF7):
                               LED8();
                                   break;
                        dafault:
                        break;
{     unsigned char keyValue=0,i;
        if (GPI0_KEY != 0xFF)
                            Delay10ms(1);
                                      keyValue=GPI0_KEY;
                                          i=0;
                                          while((i<50)&&(GPI0_KEY != 0xFF))
                                            Delay10ms(1);
                                                i++;
                   return keyValue;
{unsigned char a,b;
    for (;c>0;c--)
              for (b=38;b>0;b--)
                          for (a=130;a>0;a--);
void LED1()
   GPI0_LED=0x00;
   Delay10ms(50);
   GPI0_LED=0xFF;
   Delay10ms(50);
void LED2()
GPI0_LED=0xCC;
Delay10ms(5);
GPI0_LED=0x33;
Delay10ms(5);
GPI0_LED=0xCC;
Delay10ms(5);
GPI0_LED=0x33;
Delay10ms(5);
void LED3()
GPI0_LED=0x99;
Delay10ms(5);
GPI0_LED=0x66;
Delay10ms(5);
GPI0_LED=0x99;
Delay10ms(5);
GPI0_LED=0x66;
Delay10ms(5);
void LED4()
GPI0_LED=0xAA;
Delay10ms(5);
GPI0_LED=0x55;
Delay10ms(5);
GPI0_LED=0xAA;
Delay10ms(5);
GPI0_LED=0x55;
Delay10ms(5);
void LED5()
LED1();
LED2();
LED3();
LED4();
void LED6()
{GPI0_LED=0xFE;
   while(1)
   { Delay10ms(50);
     GPI0_LED=_crol_(P0,1);
void LED7()
{GPI0_LED=0x7F;
   while(1)
   { Delay10ms(50);
     GPI0_LED=_cror_(P0,1);
void LED8()
GPI0_LED=0x00;
此帖出自51单片机论坛
void LED6() {GPI0_LED=0xFE;    while(1)    { Delay10ms(50);      GPI0_LED=_crol_(P0,1);    } } void LED7() {GPI0_LED=0x7F;    while(1)    { Delay10ms(50);      GPI0_LED=_cror_(P0,1);    } } 你这两个里面都有死循环。。。  详情 回复 发表于 2015-2-6 09:45
24
进入循环后,LED显示是延时方式,按键扫描的机会就很少。除非你一直按着不动才行。如果用中断判断就没有这个问题。如果LED状态用定时器也没有这样问题。
此帖出自51单片机论坛
同意。也觉得是流水灯的程序占用太多时间,用中断的方式处理比较好。  详情 回复 发表于 2015-2-5 21:44
1559
24
此帖出自51单片机论坛
个人签名这孩子,成熟的象征,理智的典范。
谢谢楼上帮助,等会去就改改看
此帖出自51单片机论坛
1412
void LED6()
{GPI0_LED=0xFE;
   while(1)
   { Delay10ms(50);
void LED7()
{GPI0_LED=0x7F;
   while(1)
   { Delay10ms(50);
你这两个里面都有死循环。。。
此帖出自51单片机论坛
个人签名https://bbs.eeworld.com.cn/thread-471646-1-1.html
欢迎加入我的团队
Vicor 有奖下载 | 在48V架构中使用高密度功率转换器构建更好的机器人
活动时间:即日起-4月28日
活动奖励:螺丝刀套装、充电套装、电风扇
