2603|0
keil MDK通过ulink2烧写LPC2138后LPC2138 GPIO输出不对? [复制链接]
程序编译,flash设置都没错误,烧写erase和program都没错,但从新上电后ARM的IO输出完全不是我设置的。
#include "LPC21xx.H"                        /* LPC21xx definitions */
typedef unsigned char    uint8;      // ???8?????
typedef signed   char    int8;       // ???8?????
typedef unsigned short   uint16;     // ???16?????
typedef signed   short   int16;      // ???16?????
typedef unsigned int     uint32;     // ???32?????
typedef signed   int     int32;      // ???32?????
typedef float            fp32;       // ??????(32???)
typedef double           fp64;       // ??????(64???)
int main(void)
    PINSEL0 = 0x00000000;
    PINSEL1 = 0x00000000;
//PINSEL0 = (PINSEL0 & 0x0f0030ff);  //p0.4 0.5 0.7 0.8 0.9 0.10 0.11 0.14 0.15
//PINSEL1 =( PINSEL1 & 0xC00300fc);  //p0.16 0.20 0.21 0.22 0.23 0.25 0.26 0.27 0.28 0.29 0.30
//IO0DIR = IO0DIR|0x7ef1cfb0;        //all output
IO0DIR = 0xFFFFFFFF;          //all output
IO0CLR = 0xFFFFFFFF;        //all low
//IO0SET = 0x00800800;               //p0.11 and p0.23 are default high
IO0SET = 0xffffffff;               //all high
return 0;
此帖出自NXP MCU论坛
【直播时间】5月28日(周三)上午10:00
