TC:
The TC consists of a counter, a prescaler, compare/capture channels and control logic. The counter can be set to count events, or it can be configured to count clock pulses. The counter, together with the compare/capture channels, can be configured to timestamp input events, allowing capture of frequency and pulse width. It can also perform waveform generation, such as frequency generation and pulse-width modulation (PWM) .
TCC:
The Timer/Counter for Control applications (TCC) consists of a counter, a prescaler, compare/capture channels and control logic. The counter can be set to count events or clock pulses. The counter together with the compare/capture channels can be configured to time stamp input events, allowing capture of frequency and pulse-width. It can also perform waveform generation such as frequency generation and pulse-width modulation.
感觉内部主要模块大同小异,应该前端功能基本相同
不过TCC输出级有不少驱动模块呢
比如
The swap (SWAP) unit can be used to swap the LS and HS pin outputs, and can be used for fast decay motor control.
可用来驱动 fast decay motor,快速减速电机吗?
两者区别主要在驱动能力上吧
详情回复
发表于 2014-12-22 13:59
不过TCC输出级有不少驱动模块呢
比如
两者区别主要在驱动能力上吧
