3435|1
45
LPCXpresso1549开发环境搭建 [复制链接]
一、调试环境搭建
1.安装驱动lpc18xx_43xx_winusb_drivers_v1.00_0.zip
2.更新固件LPC_Link2_Config_tool_v1_11_1.zip
Instructions: Connect jumper ‘LINK DFU’ perthe image. Connect the board via USB to the system running this program. Pressthe ‘Program’ button to program this image into the board. Once programming iscomplete, remove the jumper and power cycle the board.
This image allows the DFU link connectionon the board to operate as a CMSIS-DAP debugger that works with tool chainsthat support the CMSIS-DAP protocol such as IAR EWARM, Keil uVision,LPCXpresso, or Rowley.
更新固件的时候要按住RESET键,如果三个条都显示绿色就表示更新成功。
MDK相关设置如下:
4. 发现需要version4.70 or above of Seggers J-Link drivers 安装完此驱动后设备被识别。下面为jlink-472a的下载连接。
二、开发板介绍
BoardOverview
Since theintroduction of the first variant in 2009, the original LPCXpresso board hasreenergised the whole MCU evaluation board market. NXP is now proud tointroduce the new generation of LPCXpresso V2 boards which build upon theoriginal design, providing many new and exciting features.
The standardLPCXpresso V2 board design offers the following features:
  • Built in LPC-Link2 based     debug probe, based on NXP LPC43xx MCU.
    • Compatible with      LPCXpresso IDE out-of-the-box, and with other toolchains via optional ARM      CMSIS-DAP and Segger J-Link firmware.
  • Debug connector to allow     debug of target MCU via an external probe.
  • Can be configured to act     as a standalone probe to allowing debugging of an external board.
  • Tri-color LED, ISP and     WAKE buttons
  • Target Reset button
  • Connector for target     MCU’s USB device peripheral
  • Expansion
    • MCU pins available on      ‘standard LPCXpresso/mbed’ expansion connector (board bottom side)
    • Arduino connectors      compatible with the ”Arduino UNO” platform (board top side)
  • Powered from multiple     sources
    • Link2 USB
    • Target USB
    • LPCXpresso/mbed header
  • P3 allows measurement of     current of all target side circuitry
此帖出自NXP MCU论坛
又是英文,这是要为难我的啊  详情 回复 发表于 2014-9-9 14:17
29
又是英文,这是要为难我的啊
此帖出自NXP MCU论坛
