3041|3
172
求助,,,大家帮我看看我的28027 i2c模块程序哪里出错了 [复制链接]
程序的功能是给24c02   第0x00个字节写入0x20,然后再读回到变量b中
#include "DSP28x_Project.h"
#define I2C_SLAVE_ADDR        0x50
#define I2C_NUMBYTES   15
#define I2C_EEPROM_HIGH_ADDR  0x00
#define I2C_EEPROM_LOW_ADDR   0x00
void  I2CA_SendData(void);
void  I2CA_ReceiveData(void);
void main(void)
        InitSysCtrl();
        InitI2CGpio();
        DINT;
        InitPieCtrl();
        IER = 0xffff;
        IFR = 0x0000;
        InitPieVectTable();
        InitI2C();
        I2CA_SendData();
        I2CA_ReceiveData();
        while(1);
        Uint16 i;
    I2caRegs.I2CSAR = I2C_SLAVE_ADDR;                         //Set slave address
    I2caRegs.I2CCNT = 1 + 1;                         //Set count to 5 characters plus 2 address bytes
    I2caRegs.I2CDXR = 0x02;//Send eeprom high address
    I2caRegs.I2CMDR.bit.TRX = 1;                                 //Set to Transmit mode
    I2caRegs.I2CMDR.bit.MST = 1;                                 //Set to Master mode
    I2caRegs.I2CMDR.bit.FREE = 1;                                //Run in FREE mode
    I2caRegs.I2CMDR.bit.STP = 1;                                 //Stop when internal counter becomes 0
    I2caRegs.I2CMDR.bit.STT = 1;                                 //Send the start bit, transmission will follow
    while(I2caRegs.I2CSTR.bit.XRDY == 0);                 //Do nothing till data is shifted out
    I2caRegs.I2CDXR = 0x20;                          //Send eeprom low address
        Uint16 i;
        char b[20];
        b[0]=0;
    I2caRegs.I2CCNT = 1;                                                 //Set count to 2 address bytes
    I2caRegs.I2CDXR = 0x00;                        //Send eeprom high address
    I2caRegs.I2CMDR.bit.STP = 0;                                 //Dont release the bus after Tx
    I2caRegs.I2CCNT = 1;                                //read 5 bytes from eeprom
    I2caRegs.I2CMDR.bit.TRX = 0;                                 //Set to Recieve mode
    I2caRegs.I2CMDR.bit.STT = 1; //Repeated start, Reception will follow
    b[0] = I2caRegs.I2CDRR;
    while(1);
void InitI2C(void)
    // Initialize I2C-A:
        I2caRegs.I2CSAR = 0x0050;        // Slave address - EEPROM control code
        I2caRegs.I2CPSC.all = 6;       // Prescaler - need 7-12 Mhz on module clk
        I2caRegs.I2CCLKL = 10;           // NOTE: must be non zero
        I2caRegs.I2CCLKH = 5;            // NOTE: must be non zero
         I2caRegs.I2CIER.bit.ARDY = 0;
         I2caRegs.I2CIER.bit.XRDY = 0;
        I2caRegs.I2CFFTX.all = 0x0000;   // Disable FIFO mode and TXFIFO
        I2caRegs.I2CFFRX.all = 0x0000;   // Disable RXFIFO, clear RXFFINT,
          I2caRegs.I2CMDR.all = 0x0020;    // Take I2C out of reset
                                            // Stop I2C when suspended
恭喜啊。有收获就好。            详情 回复 发表于 2014-7-8 22:11
2856
260
其实,我那篇文章已经写得很清楚了。哪怕是单纯的把你的程序和我的比较,你也能发现些不同的地方。同时建议你看程序的同时,看看TI关于I2C的手册.
终于检查出来了,谢谢版主  详情 回复 发表于 2014-7-8 22:04
172
ltbytyn 发表于 2014-7-8 19:16
其实,我那篇文章已经写得很清楚了。哪怕是单纯的把你的程序和我的比较,你也能发现些不同的地方。同时建议 ...
终于检查出来了,谢谢版主
2856
260
jetlin1992 发表于 2014-7-8 22:04
终于检查出来了,谢谢版主
恭喜啊。有收获就好。
