社区导航
搜索
查看: 8289|回复: 13
[求助] DSP28335 eCAN跟usbcan通讯问题
TA的帖子
Rank: 1
发表于 2014-5-27 17:17 | 显示全部楼层 |阅读模式
硬件:DSP28335的eCAN-B与vp230连接,USBcan采用的是周立功的usbcan-i与上位机连接。
出现的问题是上位机上的监控软件没法接受到DSP的eCAN模块发过来的数据。
下面是代码:
void main(void)
   struct ECAN_REGS ECanbShadow;
   InitSysCtrl();//开启系统时钟和外设时钟
   InitECanGpio();//这里用到的是ecan-b的GPIO12和GPIO13
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
    MessageReceivedCount = 0;
    EALLOW;
    ECanbShadow.CANTIOC.all = ECanbRegs.CANTIOC.all;
    ECanbShadow.CANTIOC.bit.TXFUNC = 1;
    ECanbRegs.CANTIOC.all = ECanbShadow.CANTIOC.all;
    ECanbShadow.CANRIOC.all = ECanbRegs.CANRIOC.all;
    ECanbShadow.CANRIOC.bit.RXFUNC = 1;
    ECanbRegs.CANRIOC.all = ECanbShadow.CANRIOC.all;
    EDIS;
    ECanbRegs.CANME.all = 0;
    ECanbMboxes.MBOX0.MSGID.all = 0x01C40000;//发送 标准帧
    ECanbMboxes.MBOX1.MSGID.all = 0x18040000;//接受
    ECanbRegs.CANMD.all=0x00000002;//1->RX 0->tx
    ECanbRegs.CANME.all = 0x00000003;
    ECanbMboxes.MBOX0.MSGCTRL.bit.DLC = 8;
    ECanbMboxes.MBOX1.MSGCTRL.bit.DLC = 8;
    ECanbMboxes.MBOX0.MSGCTRL.bit.RTR = 0;
    ECanbMboxes.MBOX1.MSGCTRL.bit.RTR = 0;
    ECanbMboxes.MBOX0.MDL.all = 0x9555AAA0;
    ECanbMboxes.MBOX0.MDH.all = 0x89ABCDEF;
    EALLOW;
    ECanbRegs.CANMIM.all = 0xFFFFFFFF;
    ECanbRegs.CANMIL.all = 0;
    ECanbShadow.CANMC.all = ECanbRegs.CANMC.all;
    ECanbShadow.CANMC.bit.CCR = 1;
    ECanbRegs.CANMC.all = ECanbShadow.CANMC.all;
    EDIS;
    // Wait for CCE bit to be set..
    do
      ECanbShadow.CANES.all = ECanbRegs.CANES.all;
    } while(ECanbShadow.CANES.bit.CCE != 1 );
    // Configure the eCAN timing
    EALLOW;
    ECanbShadow.CANBTC.all = ECanbRegs.CANBTC.all;
    ECanbShadow.CANBTC.bit.BRPREG = 9;    // (BRPREG + 1) = 1
    ECanbShadow.CANBTC.bit.TSEG2REG = 1 ; // to the CAN module
    ECanbShadow.CANBTC.bit.TSEG1REG = 6;  // Bit time = 2us,则为500kbps
    ECanbShadow.CANBTC.bit.SAM = 1;
    ECanbRegs.CANBTC.all = ECanbShadow.CANBTC.all;
    ECanbShadow.CANMC.bit.CCR = 0;
    EDIS;
    do
    } while(ECanbShadow.CANES.bit.CCE != 0 );
    // Configure the eCAN for self test mode
    // Enable the enhanced features of the eCAN.
    EALLOW;
    ECanbShadow.CANMC.bit.ABO = 1;
    ECanbShadow.CANMC.bit.STM = 0;    // Configure CAN for self-test mode
    ECanbShadow.CANMC.bit.SCB = 1;    // eCAN mode (reqd to access 32 mailboxes)
    EDIS;
    // Begin transmitting
    for(;;)
       ECanbRegs.CANTRS.all = 0x00000001;  // Set TRS for all transmit mailboxes,MX0开始发送
       while(ECanbRegs.CANTA.all != 0x00000001 ) {}  // Wait for all TAn bits to be set..发送完成后对应的位被置1
       ECanbRegs.CANTA.all = 0x0000FFFF;   // Clear all TAn
       MessageReceivedCount++;
       //Read from Receive mailboxes and begin checking for data */
我的想法是邮箱0设为发送邮箱,邮箱1设为接受。系统频率为100Mhz,can波特率为500k.程序运行后一直等待在while(ECanbRegs.CANTA.all != 0x00000001 ) {}这一步,也就是说没有发送完成等待置位
来源:EEWorld DSP 与 ARM 处理器板块,转载请附上链接
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2014-5-27 19:50 | 显示全部楼层
没人吗
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2014-5-27 19:51 | 显示全部楼层
怎么没人看啊
使用道具 举报
443
TA的帖子
43
Rank: 3Rank: 3
发表于 2014-5-28 09:14 | 显示全部楼层
正常发送时,程序死在这个while循环,很可能是硬件造成的,如果程序曾正常工作过,当没有节点响应接收时,就会死在这个while里。这可能是CAN高低接反,收发器使用错误,CAN线上无终端电阻导致CAN电平错误等。一般程序要避免死在这个while里,一定要能退出这个while。
你这自发自收,还是参考下TI的例子吧,百度里也有
我用的是DSP开发板,我检查了下厂商提供的电路,应该是没问题。我测试了自发自收,是可行的。 但是向外发送和接受就不行了  详情 回复 发表于 2014-5-28 15:27
一心一意,精益求精
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2014-5-28 15:27 | 显示全部楼层
Laspide 发表于 2014-5-28 09:14
正常发送时,程序死在这个while循环,很可能是硬件造成的,如果程序曾正常工作过,当没有节点响应接收时, ...
但是向外发送和接受就不行了
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2014-5-28 15:29 | 显示全部楼层
STM=0 是正常模式,不是在自发自收,注释没改过来
使用道具 举报
443
TA的帖子
43
Rank: 3Rank: 3
发表于 2014-5-29 08:49 | 显示全部楼层
500k波特率的话,150M频率,我用的的值是9,2,10;100M的话,这几个值好像不对,
TSEG2REG最小也是2,
这种配置最好还是用官方的好,毕竟人家做的芯片,最熟不过了
其他的对照例程检查下
The following bit timing rules must be fulfilled when determining the bit segment values: · TSEG1(min)>=TSEG2 · IPT  详情 回复 发表于 2014-5-29 10:41
一心一意,精益求精
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2014-5-29 10:41 | 显示全部楼层
    ECanbShadow.CANBTC.bit.TSEG2REG = 1 ; ...
· TSEG1(min)>=TSEG2
· IPT <= TSEG1 <=16 TQ
· IPT <= TSEG2 <=8 TQ
· IPT = 3/BRP (the resulting IPT has to be rounded up to the next integer value)
· 1 TQ <= SJW min[4 TQ, TSEG2] (SJW = Synchronization jump width)
· To utilize three-time sampling mode, BRP >= 5 has to be selected
TSEG2 是可以选1的,100M对应的就是500Kbps.这个我用示波器测过的
使用道具 举报
TA的帖子
Rank: 1
发表于 2015-1-28 22:35 | 显示全部楼层
你好,你的问题解决了吗?还有个问题请教你,你是怎么用示波器测的波特率,不是发送不成功,怎么还能测试到信号?
你好,我也碰到了这个问题,能交流一下吗?在线等  详情 回复 发表于 2015-1-29 11:07
使用道具 举报
TA的帖子
Rank: 1
发表于 2015-1-29 11:07 | 显示全部楼层
使用道具 举报
TA的帖子
Rank: 1
发表于 2015-1-29 11:08 | 显示全部楼层
楼主你好,我也碰到了这个问题,能指导一下吗?在线等你
使用道具 举报
TA的帖子
Rank: 2
发表于 2016-4-26 10:23 | 显示全部楼层
您好楼主,我也一直遇到这个问题,能否分享一下解决方法,非常感谢
使用道具 举报
2095
TA的帖子
Rank: 6Rank: 6
发表于 2016-5-3 22:41 | 显示全部楼层
波特率可以看示波器的时间,HS-CAN,500kbps, 1bit 2 us.
有些示波器还支持简单消息分析。
MicroPython中文社区 http://www.micro-python.com/forum.php
使用道具 举报
TA的帖子
Rank: 1
发表于 2019-7-15 15:41 | 显示全部楼层
关于您在“DSP28335 eCAN跟usbcan通讯问题”的帖子 楼主,您好,我也遇到了同样的问题,您能否分享给我解决办法?拜托了。
使用道具 举报
站长推荐上一条 /3 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-8-20 22:49 , Processed in 0.363970 second(s), 18 queries , Gzip On, MemCache On.
