/* Arrays to store SD16 conversion results */
/* NOTE: arrays need to be global to */
/* prevent removal by compiler */
//static unsigned int results[Num_of_Results];
static unsigned int results;
int main(void)
volatile unsigned int i; // Use volatile to prevent removal
// by compiler optimization
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
FLL_CTL0 |= XCAP14PF; // Configure load caps
for (i = 0; i < 10000; i++); // Delay for 32 kHz crystal to
// stabilize
LCD_Init();
// for (i = 0; i < 0x3600; i++); // Delay for 1.2V ref startup
P1DIR|=BIT4+BIT7;
P1OUT&=~(BIT4);
// P1OUT|=(BIT4);
P1OUT|=BIT7;
LED_Init;
BEEP(0);
LED_R(0);
LED_G(1);
LED_B(0);
SD16CTL = SD16REFON+SD16SSEL0; // 1.2V ref, SMCLK
SD16INCTL0 |= SD16INCH_0 + SD16INTDLY0; // Interrupt on 3rd sample
SD16CCTL0 |= SD16IE ; // Enable interrupt
_EINT(); // Enable general interrupts
SD16CCTL0 |= SD16SC; // Set bit to start conversion
_BIS_SR(LPM0_bits); // Enter LPM0
#pragma vector=SD16_VECTOR
__interrupt void SD16ISR(void)
static unsigned int index = 0;
switch (SD16IV)
case 2: // SD16MEM Overflow
break;
case 4: // SD16MEM0 IFG
results= SD16MEM0; // Save CH0 results (clears IFG),set break point here
break;
case 6: // SD16MEM1 IFG
break;
case 8: // SD16MEM2 IFG
