17008|1
24
keil编译时出现uncalled segment ignored for overlay process
程序如下,在鼠标头文件驱动里面,大家帮忙看下哪出问题了
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?_MOUSE_SEND_DATA?MAIN
**********************主函数**************************
#include
#include"mouse.h"
#include"LCD1602_4.h"
sbit beep=P3^7;
void main()
        LCM1602_Init();//初始化液晶1602
        Init_mouse();
        mouse_send_data(0xf4);//向鼠标发送0xF4命令发其开始工作
        EX1=0;//关掉外部中断以避开鼠标发回的应答
        delayms(100);
        EX1=1;//重开外部中断
        while(1)
                CLEARSCREEN;//清屏
                LCM1602_write_string(0,0,"x:");
                num(0,2,move_x);//x坐标值
                LCM1602_write_string(0,8,"y:");
                num(0,10,move_y);//y坐标值
                if(mouse_data[0]&0x01)//如果点下左键
                        beep=0;
                        LCM1602_write_string(1,0,"left");
                else if(mouse_data[0]&0x02)//如果点下右键
                        beep=0;
                        LCM1602_write_string(1,0,"right");
                else if(mouse_data[0]&0x04)//如果点下中键
                        beep=0;
                        LCM1602_write_string(1,0,"middle");
                else
                        beep=1;
                        LCM1602_write_string(1,0,"nothing");
                delayms(50);
**********************鼠标驱动头文件**************************
#include"delay52.h"
#ifndef MOUSE_H
#define MOUSE_H
sbit mouse_SDA=P3^4;//数据线P3_5
sbit mouse_CLK=P3^3;//时钟线P3_3
sbit led1=P1^3;
unsigned char bdata mouse_byte; //接收字节
sbit mouse_byte_bit0=mouse_byte^0;//mouse_byte第0位
sbit mouse_byte_bit1=mouse_byte^1;//mouse_byte第1位
sbit mouse_byte_bit2=mouse_byte^2;//mouse_byte第2位
sbit mouse_byte_bit3=mouse_byte^3;//mouse_byte第3位
sbit mouse_byte_bit4=mouse_byte^4;//mouse_byte第4位
sbit mouse_byte_bit5=mouse_byte^5;//mouse_byte第5位
sbit mouse_byte_bit6=mouse_byte^6;//mouse_byte第6位
sbit mouse_byte_bit7=mouse_byte^7;//mouse_byte第7位
unsigned char bdata mouse_fuction;//功能信息字节
unsigned char mouse_buffer[11];//接收位数据缓冲区
unsigned char mouse_buffer_bit=0;//mouse_buffer[mouse_buffer_bit]
unsigned char mouse_data[3];//接收鼠标数据缓冲区,分别存放:功能信息字节,x位移量,y位移量
unsigned char mouse_data_bit=0;//mouse_data[mouse_data_bit]
unsigned int move_x=10000;//存放横坐标
unsigned int move_y=10000;//存放纵坐标
void Init_mouse(void)
     TCON=0x00;
     EA=1;
     EX1=1;//允许外部中断1
     ET0=0x01;//允许全局中断,允许定时器/计数器0溢出中断
     PX1=1;//设置中断优先级
                发送数据
void mouse_send_data(unsigned char dat)
        unsigned char i;
        EX1=0;                              /*关闭外部中断1*/
        ACC=dat;                            /*将要发送的数据放入A寄存器*/
        mouse_CLK=0;                       /*拉低时钟线*/
        delay10us(200);                      /*延时100us以上*/
        mouse_SDA=0;                        /*拉低数据线*/
        delay10us(40);
        mouse_CLK=1;                       /*释放时钟线*/
        for(i=0;i<=7;i++)             /*低位在前,一次发送8个数据位*/
                while(mouse_CLK==1);           /*等待设备拉低时钟线*/
                mouse_SDA=(dat>>i)&0x01;      /*发送数据位*/
                while(mouse_CLK==0);           /*等待设备释放时钟线*/
        mouse_SDA=~P;                       /*发送校验位,奇校验*/
        mouse_SDA=1;                        /*发送停止位*/
        while(mouse_CLK==1);                                /*应答位*/
        EX1=1;                              /*打开外部中断1*/
                         奇校检
unsigned char Checkout(void)
        ACC=mouse_byte;
        if(~P==mouse_buffer[9])
                return 1;
        else
                return 0;
                   数据分析及处理
void data_analyse(void)
        //将收到的11位信号中截取8位数据放进mouse_byte
        mouse_byte_bit0=mouse_buffer[1];
        mouse_byte_bit1=mouse_buffer[2];
        mouse_byte_bit2=mouse_buffer[3];
        mouse_byte_bit3=mouse_buffer[4];
        mouse_byte_bit4=mouse_buffer[5];
        mouse_byte_bit5=mouse_buffer[6];
        mouse_byte_bit6=mouse_buffer[7];
        mouse_byte_bit7=mouse_buffer[8];
        if(Checkout())//如果校验正确
                if(mouse_data_bit<3)
                        mouse_data[mouse_data_bit++]=mouse_byte;
                if(mouse_data_bit==3)
                        mouse_data_bit=0;
                        if(mouse_data[0]&0x10)//如果"X sign bit"为1,表示鼠标向左移
                                move_x-=(256-mouse_data[1]);//x坐标减
                        else
                                move_x+=mouse_data[1];//x坐标加
                        if(mouse_data[0]&0x20)
                                move_y-=(256-mouse_data[2]);//y坐标减
                        else
                                move_y+=mouse_data[2];//y坐标加
                                   外部中断1
void ReceiveData(void)  interrupt 2
        if(mouse_buffer_bit<=10)
                while(mouse_CLK==0);//等待设备拉高时钟线
                mouse_buffer[mouse_buffer_bit++]=mouse_SDA;//接收数据
        if(mouse_buffer_bit==10)
                data_analyse();//数据分析及处理
                mouse_buffer_bit=0;
#endif
**********************延时函数**************************
//晶振11.0592M
#ifndef DELAY52_H
#define DELAY52_H
#define uchar unsigned char
#define uint unsigned int
#include
//起始值delayus(1)=27us,间隔9.9us
void delay10us(unsigned int t)
        while(t--);
void delayms(unsigned int t)
        unsigned int i;
        unsigned char j;
        for(i=0;i                 for(j=0;j<125;j++);
#endif
**********************液晶1602驱动**************************
#ifndef        LCD1602_4_H
#define LCD1602_4_H
#include
#define  LCM1602_DATA P0
#define CLEARSCREEN LCM1602_write_cmd(0x01)
sbit LCD1602_RS=P1^0;
sbit LCD1602_RW=P1^1;
sbit LCD1602_EN=P1^2;
void LCM1602_Init(void);        //液晶初始化
void LCM1602_write_cmd(unsigned char command);        //写命令
void LCM1602_write_data(unsigned char temp);        //写数据
void LCM1602_set_xy(unsigned char x, unsigned char y);                                                //设置坐标
void LCM1602_write_char(unsigned x,unsigned char y,unsigned char dat);                //写一个字符到第x行y列
void LCM1602_write_string(unsigned char x,unsigned char y,unsigned char *s);//写字符串到第x行y列
void LCM1602_Read_BF(void);        //读忙信号
void num(unsigned char x,unsigned char y,unsigned int n);                                        //在第x行,第y列显示整型数字n
        LCM1602_write_cmd(0x28);
        LCM1602_write_cmd(0x28);//设置4位数据传输模式
        LCM1602_write_cmd(0x0C);
        LCM1602_write_cmd(0x80);
    CLEARSCREEN;
        LCD1602_RW=1;                //RW 1
        LCD1602_RS=0;                        //RS 0
        LCD1602_EN=1;                //EN 1        Read BF
        LCM1602_DATA=LCM1602_DATA&0x0F|0xf0;
        while(LCM1602_DATA&0x80);
        LCD1602_EN=0;
void LCD_en_write(void)        //EN端产生一个高电平脉冲,写LCD
    LCD1602_EN=1;
        _nop_();
    LCD1602_EN=0;
        LCM1602_Read_BF();
        LCD1602_RW=0;                //RW 0
        LCM1602_DATA&=0x0F;
        LCM1602_DATA=command&0xf0 | LCM1602_DATA&0x0f;
        LCD_en_write();
        command=command<<4;
        LCM1602_DATA&=0x0F;
        LCD_en_write();
void LCM1602_write_data(unsigned char dat)
        LCM1602_Read_BF();
        LCD1602_RS=1;         //RS 1
        LCM1602_DATA &=0x0F;
        LCM1602_DATA=dat&0xf0 | LCM1602_DATA&0x0f;
        LCD_en_write();
        dat=dat<<4;
        LCD_en_write();
void LCM1602_set_xy(unsigned char x,unsigned char y)
        unsigned char address;
        y&=0x0f;
        if(!x)
                address=0x80+y;
        else
                address=0xc0+y;
        LCM1602_write_cmd(address);
        LCM1602_set_xy(x,y);
        LCM1602_write_data(dat);
void LCM1602_write_string(unsigned char x,unsigned char y,const unsigned char *s)
        while(*s)
                LCM1602_write_data(*s);
                s++;
        unsigned char i,length,a[6]={0,0,0,0,0,0};
        unsigned int nx=n;
        if(n==0){LCM1602_write_char(x,y,'0');return;}
        for(i=0;i<6;i++)
                if(nx>=1)length++;
                nx/=10;
        nx=n;
        for(;length>0;length--)
                a[length-1]=nx%10+48;
                nx/=10;
        LCM1602_write_string(x,y,a);
#endif
此帖出自51单片机论坛
24
自己操作错误,现在好了
