13049|12
219
使用BBB的IO口 [复制链接]
从Terminal直接控制IO口的方法如下:
  1. root@beaglebone:~# cd /sys/class/gpio
  2. root@beaglebone:/sys/class/gpio# ls -l
  3. total 0
  4. --w------- 1 root root 4096 Jan  1 00:00 export
  5. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip0 -> ../../devices/virtual/gpio/gpiochip0
  6. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip32 -> ../../devices/virtual/gpio/gpiochip32
  7. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip64 -> ../../devices/virtual/gpio/gpiochip64
  8. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip96 -> ../../devices/virtual/gpio/gpiochip96
  9. --w------- 1 root root 4096 Jan  1 00:00 unexport
  10. root@beaglebone:/sys/class/gpio# echo 44 > export
  11. root@beaglebone:/sys/class/gpio# ls -l
  12. total 0
  13. --w------- 1 root root 4096 Jan  1 00:03 export
  14. lrwxrwxrwx 1 root root    0 Jan  1 00:03 gpio44 -> ../../devices/virtual/gpio/gpio44
  15. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip0 -> ../../devices/virtual/gpio/gpiochip0
  16. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip32 -> ../../devices/virtual/gpio/gpiochip32
  17. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip64 -> ../../devices/virtual/gpio/gpiochip64
  18. lrwxrwxrwx 1 root root    0 Jan  1 00:00 gpiochip96 -> ../../devices/virtual/gpio/gpiochip96
  19. --w------- 1 root root 4096 Jan  1 00:00 unexport
  20. root@beaglebone:/sys/class/gpio# cd gpio44
  21. root@beaglebone:/sys/class/gpio/gpio44# ls -l
  22. total 0
  23. -rw-r--r-- 1 root root 4096 Jan  1 00:03 active_low
  24. -rw-r--r-- 1 root root 4096 Jan  1 00:03 direction
  25. -rw-r--r-- 1 root root 4096 Jan  1 00:03 edge
  26. drwxr-xr-x 2 root root    0 Jan  1 00:03 power
  27. lrwxrwxrwx 1 root root    0 Jan  1 00:03 subsystem -> ../../../../class/gpio
  28. -rw-r--r-- 1 root root 4096 Jan  1 00:03 uevent
  29. -rw-r--r-- 1 root root 4096 Jan  1 00:03 value
  30. root@beaglebone:/sys/class/gpio/gpio44# cat direction
  31. in
  32. root@beaglebone:/sys/class/gpio/gpio44# echo out > direction
  33. root@beaglebone:/sys/class/gpio/gpio44# cat direction
  34. out
  35. root@beaglebone:/sys/class/gpio/gpio44# cat value
  36. 0
  37. root@beaglebone:/sys/class/gpio/gpio44# echo 1 > value
  38. root@beaglebone:/sys/class/gpio/gpio44# cat value
  39. 1
复制代码
解释一下,首先要把某个(本例中是第44个,即P8_12)gpio export一下,变成用户可用的状态,然后目录里就会多出来一个gpio44目录,进入它对相应文件进行读写就可以操作io口了。输入输出是一样的道理。读的话Linux会自动实时更新value文件里的数据,但更新速度有多快暂时还不清楚,高速io操作的话用这种方法感觉不靠谱。不过速度不敏感的话是没问题的。用c程序控制io口,我们当然可以完全照搬上面对文件操作的过程,只不过写成c语言的形式。具体如下:
  1. #include <stdlib.h>
  2. #include <stdio.h>
  3. #include <string.h>
  4. #include <fcntl.h> //define O_WRONLY and O_RDONLY
  5. #define SYSFS_GPIO_DIR "/sys/class/gpio"
  6. #define MAX_BUF 64
  7.
  8. void main()
  9. {
  10.     int fd, len;
  11.     char buf[MAX_BUF];
  12.     char ch;
  13.     int i;
  14.
  15.     //export gpio44
  16.     fd = open(SYSFS_GPIO_DIR "/export", O_WRONLY);
  17.     len = snprintf(buf,sizeof(buf),"44");
  18.     write(fd,buf,len);
  19.     close(fd);
  20.
  21.     //set direction
  22.     snprintf(buf,sizeof(buf),SYSFS_GPIO_DIR"/gpio44/direction");
  23.     fd = open(buf, O_WRONLY);
  24.     write(fd, "in", 3);
  25.     close(fd);
  26.
  27.     //read and print value 10 times
  28.     for(i=0;i<10;i++)
  29.     {
  30.         snprintf(buf,sizeof(buf),SYSFS_GPIO_DIR"/gpio44/value");
  31.         fd = open(buf, O_RDONLY);
  32.         read(fd,&ch,1);
  33.         printf("%c\n",ch);
  34.         close(fd);
  35.         usleep(1000000);
  36.     }
  37. }
复制代码
这个例子实现了把gpio44引脚设置为输入引脚,然后每秒检测一次输入电平,并将电平(0或1)打印在终端上。
(转自我自己的博客http://blog.csdn.net/wyt2013
个人签名更多BBB经验分享,请访问我的博客http://blog.csdn.net/wyt2013
6943
哈哈 学习一下。
1369
楼主的引脚是怎么对应的啊?是不是44对应的是P1_12呢?
44对应p8_12  详情 回复 发表于 2014-5-16 14:28
219
44对应p8_12
哦!楼主说的是P8 的第十二个引脚,我说的是引脚GPIO1是一个哎!  详情 回复 发表于 2014-5-16 15:39
1369
哦!楼主说的是P8 的第十二个引脚,我说的是引脚GPIO1_12是一个哎!
啊哈~巧了!  详情 回复 发表于 2014-5-16 16:24
219
啊哈~巧了!
请问一下大神,你是在什么编译器下写代码的?vim 还是这个开发板提供的cloud9ide?
vim  详情 回复 发表于 2014-12-16 09:14
219
vim
我使用 echo 44>export  什么都没发生啊 0 0
1050
请问一下,当我配置成输出时可以正常输出,当配置成输入时不论引脚电平如何变化value里一直是0,这是为什么?
T T 从第三部就不对了  直接显示 export gpiochip0
= =  是我看错了
相关帖子
