2872|0
ise上做的分频程序创建约束时出现your design has no clocks !!! [复制链接]
仿真正确,程序如下  求大神解答
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date:    18:29:23 12/18/2013
// Design Name:
// Module Name:    fdiv
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module fdiv(f_1khz,f_2hz,clk,rset);
        input clk;                //时钟源频率50MHZ
        input rset;
        output f_1khz,f_2hz;
        reg f_1khz,f_2hz;
        reg [13:0]CNT1;
        reg [9:0]CNT2;
        always@(posedge clk or posedge rset)                //50MHZ分频得到1KHZ
        begin
        if(rset) begin CNT1<=0;end
        else
                //if(CNT1<49)
                if(CNT1<49999)
                begin
                        CNT1<=CNT1+1;
                        f_1khz<=1'b0;
                end
                else begin
                                CNT1<=0;
                                f_1khz<=1'b1;
                                end
        end
        always@(posedge f_1khz)                //1KHZ分频得到50HZ
        begin
                if(rset) begin CNT2<=0;end
                if(CNT2<49)
                //if(CNT2<4)
                begin
                        CNT2<=CNT2+1;
                        f_2hz<=1'b0;
                end
                else begin
                                CNT2<=0;
                                f_2hz<=1'b1;
                                end
        end
endmodule
此帖出自FPGA/CPLD论坛
