社区导航
搜索
查看: 1173|回复: 0
[资料分享] UCOS移植到MSP430过程与心得体会《3》
3364
TA的帖子
421
Rank: 8Rank: 8
荣誉会员勋章
发表于 2013-11-29 19:31 | 显示全部楼层 |阅读模式
static void OS_InitRdyList (void)
     INT16U    i;
     INT8U    *prdytbl;
     OSRdyGrp       = 0x00;
ready list                     */
     prdytbl        = &OSRdyTbl[0];
     for (i = 0; i < OS_RDY_TBL_SIZE; i++) {
         *prdytbl++ = 0x00;
     OSPrioCur      = 0;
     OSPrioHighRdy = 0;
     OSTCBHighRdy = (OS_TCB *)0;
     OSTCBCur       = (OS_TCB *)0;
static void OS_InitTCBList (void)
     INT8U     i;
     OS_TCB *ptcb1;
     OS_TCB *ptcb2;
     OSTCBList      = (OS_TCB *)0;               /* TCB Initialization      */
     for (i = 0; i < (OS_LOWEST_PRIO + 1); i++){       /*Clear the priority table
         OSTCBPrioTbl = (OS_TCB *)0;
     ptcb1 = &OSTCBTbl[0];
     ptcb2 = &OSTCBTbl[1];
     for (i = 0; i < (OS_MAX_TASKS + OS_N_SYS_TASKS - 1); i++) { /* Init. list of free TCBs                   */
         ptcb1->OSTCBNext = ptcb2;
         ptcb1++;
         ptcb2++;
     ptcb1->OSTCBNext = (OS_TCB *)0;                               /* Last OS_TCB                               */
     OSTCBFreeList     = &OSTCBTbl[0];
static void OS_InitEventList (void)
#if (OS_EVENT_EN > 0) && (OS_MAX_EVENTS > 0)
#if (OS_MAX_EVENTS > 1)
     INT16U      i;
     OS_EVENT *pevent1;
     OS_EVENT *pevent2;
     pevent1 = &OSEventTbl[0];
     pevent2 = &OSEventTbl[1];
     for (i = 0; i < (OS_MAX_EVENTS - 1); i++) {                   /* Init. list of free EVENT control blocks */
         pevent1->OSEventType = OS_EVENT_TYPE_UNUSED;
         pevent1->OSEventPtr = pevent2;
         pevent1++;
         pevent2++;
     pevent1->OSEventPtr = (OS_EVENT *)0;
     OSEventFreeList       = &OSEventTbl[0];
#else
     OSEventFreeList               = &OSEventTbl[0];                /* Only have ONE event control block         */
     OSEventFreeList->OSEventType = OS_EVENT_TYPE_UNUSED;
     OSEventFreeList->OSEventPtr = (OS_EVENT *)0;
#endif
#endif
//调用任务选出最优先级最高的任务.
void OSStart (void)
     INT8U y;
     INT8U x;
     if (OSRunning == FALSE) {
         y              = OSUnMapTbl[OSRdyGrp];         /* Find highest priority's task priority number    */
         x              = OSUnMapTbl[OSRdyTbl[y]];
         OSPrioHighRdy = (INT8U)((y << 3) + x);
         OSPrioCur      = OSPrioHighRdy;
         OSTCBHighRdy = OSTCBPrioTbl[OSPrioHighRdy]; /* Point to highest priority task ready to run     */
         OSTCBCur       = OSTCBHighRdy;
         OSStartHighRdy();                            /* Execute target specific code to start task      */
<调用OSStartHighRdy()对选出来将优先级最高的任务的堆栈出栈>
OSStartHighRdy
             call      #OSTaskSwHook
             mov.b     #1, &OSRunning          ; kernel running
             mov.w     SP, &OSISRStkPtr        ; save interrupt stack
             mov.w     &OSTCBHighRdy, R13      ; load highest ready task stack
             mov.w     @R13, SP
             POPALL                           ; pop all registers
             reti
//task的优先级为5 ,进入运行.
void task(void *pdata)
WDTCTL=WDT_MDLY_8;
IE1|=0X01;
P4DIR=0xFF;
while(1)
     if(FlagLED==false)
     //P4OUT=0x80;
     FlagLED=true;
    if(FlagLED==true)
      LED=(LED==0x80)?(0x01):(LED<<1);
      P4OUT=LED;
      FlagLED=false;
OSTimeDly(10);
在上面断要考虑以下几个怀况:
WDTCTL=WDT_MDLY_8;
IE1|=0X01;
OSTimeDly(10); 三个同时工作对任务的作用:
表面意思来看.WDTCTL=WDT_MDLY_8; IE1|=0x01;    是看门狗廷时8ms 主详细看下面执行过程.
void OSTimeDly (INT16U ticks)
#if OS_CRITICAL_METHOD == 3                       /* Allocate storage for CPU status register            */
     OS_CPU_SR cpu_sr;
#endif
     if (ticks > 0) {                                                       /* 0 means no delay!          */
         OS_ENTER_CRITICAL();
         if ((OSRdyTbl[OSTCBCur->OSTCBY] &= ~OSTCBCur->OSTCBBitX) == 0) { /* Delay current task         */
             OSRdyGrp &= ~OSTCBCur->OSTCBBitY;
         OSTCBCur->OSTCBDly = ticks;                                        /* Load ticks in TCB          */
         OS_EXIT_CRITICAL();
         OS_Sched();                                                        /* Find next task to run!     */
< OS_ENTER_CRITICAL();>里的内容.----何存内容.
OSCPUSaveSR          /
             MOV.W     SR,R12
             DINT
             RET
< OS_EXIT_CRITICAL();>    //返回
OSCPURestoreSR
             MOV.W     R12,SR
             RET
//以下说明在整个执行过程中, OSTimeDly()调用了OS_Sched()
//及OS_TASK_SW();对任务进行切换.
void OS_Sched (void)
     OS_CPU_SR cpu_sr;
#endif
     INT8U       y;
     if ((OSIntNesting == 0) && (OSLockNesting == 0)) { /* Sched. only if all ISRs done & not locked     */
         y              = OSUnMapTbl[OSRdyGrp];           /* Get pointer to HPT ready to run               */
         OSPrioHighRdy = (INT8U)((y << 3) + OSUnMapTbl[OSRdyTbl[y]]);
         if (OSPrioHighRdy != OSPrioCur) {               /* No Ctx Sw if current task is highest rdy      */
             OSCtxSwCtr++;                               /* Increment context switch counter              */
             OS_TASK_SW();                               /* Perform a context switch                      */
     OS_EXIT_CRITICAL();
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-5-26 05:45 , Processed in 0.078723 second(s), 17 queries , Gzip On, MemCache On.
