社区导航
搜索
查看: 1277|回复: 0
[资料分享] UCOS移植到MSP430过程与心得体会《2》
3364
TA的帖子
421
Rank: 8Rank: 8
荣誉会员勋章
发表于 2013-11-29 19:28 | 显示全部楼层 |阅读模式
以下是includes.h文件的内容.
#include    <stdio.h>
#include    <string.h>
#include    <ctype.h>
#include    <stdlib.h>
#include    <in430.h>
#include    "stdbool.h"
#include    <msp430x16x.h>
#include    "OS_CPU.h"
#include    "os_cfg.h"
#include    "..\uCOS2\uCOS_II.h"//"..\uCOS2\uCOS_II.h"
以下是UCOS_II.C的内容
#defineOS_GLOBALS                           /* Declare GLOBAL variables                              */
#include "..\Ports\includes.h"
#defineOS_MASTER_FILE                       /* Prevent the following files from including includes.h */
#include "OS_CORE.C"
#include "OS_FLAG.C"
#include "OS_MBOX.C"
#include "OS_MEM.C"
#include "OS_MUTEX.C"
#include "OS_Q.C"
#include "OS_SEM.C"
#include "OS_TASK.C"
#include "OS_TIME.C"
Includes.h与UCOS_II.C位于同一文件夹内.要注意#include "..\Ports\includes.h"路径方式.
//#include "lcd.c"
bool FlagLED;
unsigned char LED=0x01;
#define TASK_STK_SIZE 80
OS_STK TaskSTK2[TASK_STK_SIZE];
OS_STK TaskSTK3[TASK_STK_SIZE];
*模块名称:MSP430F2274应用任务-->定时闪烁 P1.0 LED
*/|\|              XIN|-
*   --|RST          XOUT|-
*     |              P4 |-->LED
void task(void *pdata)
//pdata= pdata;                       //如果编译器报警,则重新加入此行代码
    WDTCTL = WDT_MDLY_8;           //设置时钟节拍间隔为32ms
    IE1   |= 0x01;                      //开看门狗定时器中断
    //P4SEL &= BIT0;
    P4DIR |=0xff;
    //P4OUT=0xff;
while (1)
{     if(FlagLED==true)
          LED=(LED==0x80)?(0x01):(LED<<1);
          P4OUT=LED;
          FlagLED=false;
        if(FlagLED==false)
         //P4OUT=0x80;
         FlagLED=true;
       //P4OUT ^= (BIT0+BIT1+BIT2+BIT3+BIT4+BIT5+BIT6+BIT7);
        OSTimeDly(100);                 //定时函数括号内的内容为延时的时间,//1S=100ms
void task1(void *pdata)
WDTCTL=WDT_MDLY_8;        //如果
IE1|=0X01;
P4DIR=0xFF;
while(1)
    if(FlagLED==false)
    //P4OUT=0x80;
    FlagLED=true;
   if(FlagLED==true)
     P4OUT=LED;
     FlagLED=false;
void Init_System_Clock()
BCSCTL1=0X00;
do
    IFG1&=~OFIFG;
    for(unsigned char i=0;i<0xff;i++) ;
while(IFG1&OFIFG);
BCSCTL2|=SELM_2+SELS;
void main(void)
    WDTCTL = WDTPW + WDTHOLD;       //关闭看门狗定时器
   // Init_System_Clock();        //8MHZ     //加此语句后,看不清屏幕显烁.
    OSInit();
    OSTaskCreate(task,(void *)0,&TaskSTK2[TASK_STK_SIZE-1],5);
    //OSTaskCreate(task1,(void *)0,&TaskSTK3[TASK_STK_SIZE-1],6);
    OSStart();
以上是MAIN.C的内容.在UCOS_II里关键就是对MAIN.C的部分分配任务.然后就是在OSStart()后进行任务调度.并按#define OS_TICKS_PER_SEC         64    /* Set the number of ticks in one second*/设定时中断时间任务切换..
根据上面的资料现在对UCOS执行的过程进行说明<单步执行>.
//根据OS_CFG.H的设定按顺序先对任务初始值,任务控制列表,事件列表..初始化.再对UCOS
操作系统的事件标志,内存标志,消息标志,任务标志量的初始化..
//消息邮箱是main主程序里建立.
//时间是在任务建立后OSTimeDly(100);时让当前任务挂起100的时间量.OSCtxSw()切换
voidOSInit (void)          //系统初始化
#if OS_VERSION >= 204
    OSInitHookBegin();                                           /* Call port specific initialization code   */
#endif
    OS_InitMisc();                                               /* Initialize miscellaneous variables       */
    OS_InitRdyList();                                            /* Initialize the Ready List                */
    OS_InitTCBList();                                            /* Initialize the free list of OS_TCBs      */
    OS_InitEventList();                                          /* Initialize the free list of OS_EVENTs    */
#if (OS_VERSION >= 251) && (OS_FLAG_EN > 0) && (OS_MAX_FLAGS > 0)
    OS_FlagInit();                                               /* Initialize the event flag structures     */
#endif
#if (OS_MEM_EN > 0) && (OS_MAX_MEM_PART > 0)
    OS_MemInit();                                                /* Initialize the memory manager            */
#endif
#if (OS_Q_EN > 0) && (OS_MAX_QS > 0)
    OS_QInit();                                                  /* Initialize the message queue structures*/
#endif
    OS_InitTaskIdle();                                           /* Create the Idle Task                     */
#if OS_TASK_STAT_EN > 0
    OS_InitTaskStat();                                           /* Create the Statistic Task                */
#endif
    OSInitHookEnd();
specific init. code            */
#endif
//时间,任务,切换,挂起的各量都为0
staticvoidOS_InitMisc (void)
#if OS_TIME_GET_SET_EN > 0
    OSTime        = 0L;                                          /* Clear the 32-bit system clock            */
#endif
    OSIntNesting= 0;                                           /* Clear the interrupt nesting counter      */
    OSLockNesting = 0;                                           /* Clear the scheduling lock counter        */
    OSTaskCtr     = 0;                                           /* Clear the number of tasks                */
    OSRunning     = FALSE;                                       /* Indicate that multitasking not started   */
    OSCtxSwCtr    = 0;                                           /* Clear the context switch counter         */
    OSIdleCtr     = 0L;                                          /* Clear the 32-bit idle counter            */
#if (OS_TASK_STAT_EN > 0) && (OS_TASK_CREATE_EXT_EN > 0)
    OSIdleCtrRun= 0L;
    OSIdleCtrMax= 0L;
    OSStatRdy     = FALSE;                                       /* Statistic task is not ready              */
#endif
staticvoidOS_InitRdyList (void)
    INT16U   i;
    INT8U   *prdytbl;
    OSRdyGrp      = 0x00;
使用道具 举报
本版积分规则
站长推荐上一条 /1 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-5-20 03:39 , Processed in 0.071700 second(s), 17 queries , Gzip On, MemCache On.
