社区导航
搜索
查看: 1691|回复: 0
[资料分享] UCOS移植到MSP430过程与心得体会《1》
3364
TA的帖子
420
Rank: 8Rank: 8
荣誉会员勋章
发表于 2013-11-29 19:25 | 显示全部楼层 |阅读模式
以下是OS_CFG.H头文件内容包括UCOS_II操作系统的九大主要核心.用信号量或消息量及其他的任何量时将相应的允许位设置为1 ,删除与其他根据应用来定.
                                       /* ---------------------- MISCELLANEOUS ----------------------- */
#define OS_ARG_CHK_EN             0    /* Enable (1) or Disable (0) argument checking                  */
#define OS_CPU_HOOKS_EN           1    /* uC/OS-II hooks are found in the processor port files         */
#define OS_DEBUG_EN               1    /* Enable(1) debug variables                                    */
#define OS_EVENT_NAME_SIZE        0    /* Determine the size of the name of a Sem, Mutex, Mbox or Q    */
#define OS_LOWEST_PRIO           10    /* Defines the lowest priority that can be assigned ...         */
                                       /* ... MUST NEVER be higher than 63!                            */
#define OS_MAX_EVENTS             5    /* Max. number of event control blocks in your application      */
#define OS_MAX_FLAGS              3    /* Max. number of Event Flag Groups    in your application      */
#define OS_MAX_MEM_PART           2    /* Max. number of memory partitions                             */
#define OS_MAX_QS                 2    /* Max. number of queue control blocks in your application      */
#define OS_MAX_TASKS              8    /* Max. number of tasks in your application, MUST be >= 2       */
#define OS_SCHED_LOCK_EN          0    /*     Include code for OSSchedLock() and OSSchedUnlock()       */
#define OS_TASK_IDLE_STK_SIZE    80    /* Idle task stack size (# of OS_STK wide entries)              */
#define OS_TASK_STAT_EN           0    /* Enable (1) or Disable(0) the statistics task                 */
#define OS_TASK_STAT_STK_SIZE   80    /* Statistics task stack size (# of OS_STK wide entries)        */
#define OS_TASK_STAT_STK_CHK_EN   1    /* Check task stacks from statistic task                        */
#define OS_TICK_STEP_EN           1    /* Enable tick stepping feature for uC/OS-View                  */
#define OS_TICKS_PER_SEC         64    /* Set the number of ticks in one second                        */
                                       /* ----------------------- EVENT FLAGS ------------------------ */
#define OS_FLAG_EN                1    /* Enable (1) or Disable (0) code generation for EVENT FLAGS    */
#define OS_FLAG_WAIT_CLR_EN       0    /* Include code for Wait on Clear EVENT FLAGS                   */
#define OS_FLAG_ACCEPT_EN         1    /*     Include code for OSFlagAccept()                          */
#define OS_FLAG_DEL_EN            0    /*     Include code for OSFlagDel()                             */
#define OS_FLAG_NAME_SIZE         0    /*     Determine the size of the name of an event flag group    */
#define OS_FLAG_QUERY_EN          0    /*     Include code for OSFlagQuery()                         */
                                       /* -------------------- MESSAGE MAILBOXES --------------------- */
#define OS_MBOX_EN                0    /* Enable (1) or Disable (0) code generation for MAILBOXES      */
#define OS_MBOX_ACCEPT_EN         1    /*     Include code for OSMboxAccept()                          */
#define OS_MBOX_DEL_EN            0    /*     Include code for OSMboxDel()                             */
#define OS_MBOX_POST_EN           1    /*     Include code for OSMboxPost()                            */
#define OS_MBOX_POST_OPT_EN       1    /*     Include code for OSMboxPostOpt()                         */
#define OS_MBOX_QUERY_EN          0    /*     Include code for OSMboxQuery()                          */
                                       /* --------------------- MEMORY MANAGEMENT -------------------- */
#define OS_MEM_EN                 0    /* Enable (1) or Disable (0) code generation for MEMORY MANAGER */
#define OS_MEM_QUERY_EN           1   /*     Include code for OSMemQuery()                            */
#define OS_MEM_NAME_SIZE          0    /*     Determine the size of a memory partition name            */
                                       /* ---------------- MUTUAL EXCLUSION SEMAPHORES --------------- */
#define OS_MUTEX_EN               0    /* Enable (1) or Disable (0) code generation for MUTEX          */
#define OS_MUTEX_ACCEPT_EN        1    /*     Include code for OSMutexAccept()                         */
#define OS_MUTEX_DEL_EN           0    /*     Include code for OSMutexDel()                            */
#define OS_MUTEX_QUERY_EN         0    /*     Include code for OSMutexQuery()                          */
                                       /* ---------------------- MESSAGE QUEUES ---------------------- */
#define OS_Q_EN                   1    /* Enable (1) or Disable (0) code generation for QUEUES         */
#define OS_Q_ACCEPT_EN            1    /*     Include code for OSQAccept()                             */
#define OS_Q_DEL_EN               0    /*     Include code for OSQDel()                                */
#define OS_Q_FLUSH_EN             1    /*     Include code for OSQFlush()                              */
#define OS_Q_POST_EN              1    /*     Include code for OSQPost()                               */
#define OS_Q_POST_FRONT_EN        1    /*     Include code for OSQPostFront()                          */
#define OS_Q_POST_OPT_EN          1    /*     Include code for OSQPostOpt()                            */
#define OS_Q_QUERY_EN             0    /*     Include code for OSQQuery()                              */
                                       /* ------------------------ SEMAPHORES ------------------------ */
#define OS_SEM_EN                 1    /* Enable (1) or Disable (0) code generation for SEMAPHORES     */
#define OS_SEM_ACCEPT_EN          1    /*    Include code for OSSemAccept()                            */
#define OS_SEM_DEL_EN             0    /*    Include code for OSSemDel()                               */
#define OS_SEM_QUERY_EN           0    /*    Include code for OSSemQuery()                             */
                                       /* --------------------- TASK MANAGEMENT ---------------------- */
#define OS_TASK_CHANGE_PRIO_EN    1    /*     Include code for OSTaskChangePrio()                      */
#define OS_TASK_CREATE_EN         1    /*     Include code for OSTaskCreate()                          */
#define OS_TASK_CREATE_EXT_EN     1    /*     Include code for OSTaskCreateExt()                       */
#define OS_TASK_DEL_EN            0    /*     Include code for OSTaskDel()                             */
#define OS_TASK_NAME_SIZE         0    /*     Determine the size of a task name                        */
#define OS_TASK_PROFILE_EN        1    /*     Include variables in OS_TCB for profiling                */
#define OS_TASK_QUERY_EN          0    /*     Include code for OSTaskQuery()                           */
#define OS_TASK_SUSPEND_EN      0    /*     Include code for OSTaskSuspend() and OSTaskResume()      */
#define OS_TASK_SW_HOOK_EN        1    /*     Include code for OSTaskSwHook()                          */
                                       /* --------------------- TIME MANAGEMENT ---------------------- */
#define OS_TIME_DLY_HMSM_EN       1    /*     Include code for OSTimeDlyHMSM()                         */
#define OS_TIME_DLY_RESUME_EN     1    /*     Include code for OSTimeDlyResume()                       */
#define OS_TIME_GET_SET_EN        0    /*     Include code for OSTimeGet() and OSTimeSet()             */
#define OS_TIME_TICK_HOOK_EN      1    /*     Include code for OSTimeTickHook()                        */
typedef INT16U             OS_FLAGS;   /* Date type for event flag bits (8, 16 or 32 bits)             */
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-6-19 22:41 , Processed in 0.084323 second(s), 17 queries , Gzip On, MemCache On.
