2518|0
63
C2000串行驱动 LCD12864出现了问题,很急很迫切。芯片是F28027 [复制链接]
1芯积分
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
char table0[]="电气工程学院";
char table1[]="测控0901";
char table2[]="李永超";
char table3[]="200948770102";
//******************delay*************************//
void delay(int count)
                while(count--);
//******************GPIO configure****************//
void Gpio_Init(void)
                        EALLOW;
                        GpioCtrlRegs.GPAMUX1.all = 0x00000000;  // All GPIO//MUX寄存器是多路复用寄存器,低电平代表不复用,使用的时候要进行保护
                        GpioCtrlRegs.GPAMUX2.all = 0x00000000;  // All GPIO
                        GpioCtrlRegs.GPBMUX1.all = 0x00000000;  // All GPIO
                        GpioCtrlRegs.GPADIR.all = 0xFFFFFFFF;   // All outputs
                        GpioCtrlRegs.GPBDIR.all = 0x0000000F;   // All outputs
                        EDIS;
//******************Datas sending function*************//
void Sendbyte(unsigned char data1)
                unsigned int i;
                for(i=0;i<8;i++)
                                GpioDataRegs.GPADAT.bit.GPIO7=0;                //GPIO0 is CLK
                                if(data1&0x80)
                                GpioDataRegs.GPADAT.bit.GPIO6=1;                //GPIO1 is data output pin
                                else
                                GpioDataRegs.GPADAT.bit.GPIO6=0;
                                GpioDataRegs.GPADAT.bit.GPIO7=1;
                                data1=data1<<1;
                                delay(0xff);
//******************Command sending function*************//
void write_com(unsigned char com)
                GpioDataRegs.GPADAT.bit.GPIO5=1;
                Sendbyte(0xf8);
                Sendbyte(com&0xf0);
                Sendbyte((com&0x0f)<<4);
                GpioDataRegs.GPADAT.bit.GPIO5=0;
                delay(0xff);
//******************Display data sending function*************//
void write_data(unsigned char data)
                Sendbyte(0xfa);                                                        //That is to say
                Sendbyte(data&0xf0);
                Sendbyte((data&0x0f)<<4);
                delay(0xff);
void LCD_Init()
                write_com(0x01);
                write_com(0x30);
                write_com(0x0c);
                write_com(0x06);
                write_com(0x02);
void main(void)
                unsigned int n;
           InitSysCtrl();
           Gpio_Init();
           DINT;                                        //屏蔽中断
           InitPieCtrl();                        //初始化中断控制寄存器
           IER = 0x0000;                                        //中断使能寄存器,某一位是1表示使能中断
           IFR = 0x0000;                                        //中断标志寄存器,某一位是1表示产生中断标志
           InitPieVectTable();//初始化中断向量表,把向量表复制到指定RAM段,防止非法中断的产生
           LCD_Init();
        //************************The first line**********************//
                           write_com(0x80);
                           write_data(0x0b);
                           write_data(0x0b);
                           for(n=0;n<12;n++)
                                           write_data(table0[n]);
                                           delay(0xff);
                           write_data(0x0b);
                           write_data(0x0b);
        //************************The second line**********************//
                           write_com(0x90);
                           for(n=0;n<8;n++)
                                                           write_data(table1[n]);
                                                           delay(0xff);
        //************************The third line**********************//
                           write_com(0x88);
                           write_data(0x03);
                           write_data(0x03);
                           for(n=0;n<6;n++)
                                                   write_data(table2[n]);
                                                   delay(0xff);
                           write_data(0x03);
                           write_data(0x03);
        //************************The fourth line**********************//
                           write_com(0x98);
                           for(n=0;n<12;n++)
                                           write_data(table3[n]);
                                           delay(0xff);
           while(1);
// No more.
[ 本帖最后由 woshilee 于 2013-7-16 10:09 编辑 ]
