2864|3
854
S5PV210平台在WinCE6下使用512MmDDR(256mx2) [复制链接]
主要有以下几个地方需要注意:
1. Image_Cfg.h
[cpp] view plaincopy
  • // DRAM1 Base Address
  • #define DRAM_BASE_PA_START                  (0x40000000)
  • #define DRAM_BASE_CA_START                  (0x80000000)
  • #define DRAM_BASE_UA_START                  (0xA0000000)
  • #define DRAM_BASE_PA_LAST                   (0x48000000)
  • #define DRAM_BASE_CA_LAST                   (0x88000000)
  • #define DRAM_BASE_UA_LAST                   (0xA8000000)
  • // Extra DRAM1 Base Address for V210
  • #define DRAM_EXTRA_BASE_PA_START                (0x48000000)
  • #define DRAM_EXTRA_BASE_CA_START                (0x99600000)
  • #define DRAM_EXTRA_BASE_UA_START                (0xB9600000)
  • #define DRAM_EXTRA_SIZE                                 (0x06A00000)
  • #define DRAM_EXTRA_BASE_UA_LAST             (DRAM_EXTRA_BASE_UA_START + DRAM_EXTRA_SIZE)
  • // DRAM0 Base Address
  • #define DRAM0_BASE_PA_START                 (0x20000000)
  • #define DRAM0_BASE_CA_START                 (0x88000000)
  • #define DRAM0_BASE_UA_START                 (0xA8000000)
  • #define DRAM0_BASE_PA_LAST                  (0x28000000)
  • #define DRAM0_BASE_CA_LAST                  (0x90000000)
  • #define DRAM0_BASE_UA_LAST                  (0xB0000000)
2. oemaddrtab_cfg.inc
  • DCD DRAM_BASE_CA_START,             DRAM_BASE_PA_START,      128 ; 128 MB DRAM
  • DCD DRAM0_BASE_CA_START,            DRAM0_BASE_PA_START,         128 ; 128 MB DRAM on DMC0
  • DCD BASE_REG_CA_CHIPID,             BASE_REG_PA_CHIPID,          43  ; 43 MB SFR,       0x9000_0000 - 0x92AF_FFFF
3. image_cfg.inc
  • ; SDRAM
  • DRAM0_BASE_PA_START        EQU    (0x20000000)
  • DRAM0_BASE_CA_START        EQU    (0x88000000)
  • DRAM0_BASE_UA_START        EQU    (0xA8000000)
  • DRAM0_SIZE                 EQU    (0x08000000)  ;128M
  • ; SDRAM
  • DRAM_BASE_PA_START        EQU    (0x40000000)
  • DRAM_BASE_CA_START        EQU    (0x80000000)
  • DRAM_BASE_UA_START        EQU    (0xA0000000)
  • DRAM_SIZE                 EQU    (0x08000000)   ;128M
  • ; Extra DRAM for V210
  • DRAM_EXTRA_BASE_PA_START  EQU    (0x48000000)
  • DRAM_EXTRA_BASE_CA_START  EQU    (0x99600000)
  • DRAM_EXTRA_BASE_UA_START  EQU    (0xB9600000)
  • DRAM_EXTRA_SIZE           EQU    (0x06A00000)   ;106M
4. init.c
  • static DWORD OEMEnumExtensionDRAM(
  •   PMEMORY_SECTION pMemSections,
  •   DWORD cMemSections)
  •     DWORD cSections = 0;
  •     if (cSections < cMemSections)
  •         // DRAM0 Area
  •         pMemSections[cSections].dwFlags = 0;
  •         pMemSections[cSections].dwStart = DRAM0_BASE_CA_START;  //0x88000000
  •         pMemSections[cSections].dwLen =  ONEDRAM_EXTSIZE_FOR_AP;
  •         cSections++;
  •         // Extra DRAM1 Area 0x48000000, 106MB
  •         pMemSections[cSections].dwStart = DRAM_EXTRA_BASE_CA_START;  //0x99600000
  •         pMemSections[cSections].dwLen =  DRAM_EXTRA_SIZE;
  •         cSections++;
  •     return cSections;
image_cfg.inc貌似不改也没问题。
其余的关于内存的一些配置,在System_Init.c中,可以对照内存的Spec以及210手册中Memory配置部分即可。
这是个好东西,拿走了  详情 回复 发表于 2013-5-25 10:48
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
854
我自己也改过,转载的文章没有问题。
这是个好东西,拿走了
