6304|1
谁能帮我解读下这个程序ads1118的a/d程序 [复制链接]
#include "msp430x54xA.h"
#define CS_0   P1OUT &=~ 0x02;
#define CS_1   P1OUT |=  0x02;
void GPIO_Init(void);
void SPI_Init(void);
void ADS_Config(void);
int ADS_Read(void);
signed int WriteSPI(unsigned int Config, unsigned char mode);
//V=ADC_Result /65536*VREF
void main(void)
        volatile int ADC_Result,T;
        WDTCTL = WDTPW+WDTHOLD;                 // Stop watchdog timer
        GPIO_Init();
        SPI_Init();
        ADS_Config();
        while(1)
                ADC_Result = 2*ADS_Read();                        // Read data from ADS1118
                T= ADC_Result;
        P1OUT |= 0x02;                         // Set P1.1 for CS
        P1DIR |= 0x02;                          // Set P1.1 to output direction
        P3SEL |= 0x80;                          // P3.7 option select
        P5SEL |= 0x30;                                // P5.4,5 option select
        P5DIR |= BIT0;                          // P5.0 Output
        P5OUT |= BIT0;                          // P5.0 Output High
void SPI_Init(void)
        UCB1CTL1 |= UCSWRST;                    // **Put state machine in reset**
        UCB1CTL0 |= UCMST+UCSYNC+UCMSB;  //+UCCKPH 3-pin, 8-bit SPI master
                                                // Clock polarity high, MSB
        UCB1CTL1 |= UCSSEL_2;                   // SMCLK
        UCB1BR0 = 200;                         // /2
        UCB1BR1 = 1;                            //
        UCB1CTL1 &= ~UCSWRST;                   // **Initialize USCI state machine**
        __delay_cycles(100);                    // Wait for slave to initialize
0x058B  A1/A2    +/-2.048   0x038B  A1/A2    +/-4.096
0x458B  A1/GND   +/-2.048   0x438B  A1/GND   +/-4.096
0x558B  A2/GND   +/-2.048   0x538B  A2/GND   +/-4.096
0x658B  A3/GND   +/-2.048   0x638B  A3/GND   +/-4.096
0x758B  A4/GND   +/-2.048   0x738B  A4/GND   +/-4.096
        signed int Config_Value;
        Config_Value = 0x558B;                                        // Initial Config Register
        // ADS1118 configuration AIN0/AIN1, FS=+/-2.048, DR=128sps, PULLUP on DOUT
        CS_0;                                                        // Set CS low
        WriteSPI(Config_Value,0);                                // Write configuration to ADS1118
        CS_1;        // Set CS high
int ADS_Read(void)
        unsigned int Data, Config_Value;
        CS_0;                                                        // Set CS low
        Data = WriteSPI(Config_Value,1);                // Read data from ADS1118
        return Data;
* Mode 0: Only write config register to ADS1118
* Mode 1: Write config register to ADS1118 as well as read data from ADS1118
signed int WriteSPI(unsigned int config, unsigned char mode)
        signed int msb;
        unsigned int temp;
        volatile signed int dummy;
        temp = config;
        if (mode==1) temp = config | 0x8000;
        while(!(UCB1IFG&UCTXIFG));
        UCB1TXBUF = (temp >> 8 );                                // Write MSB of Config
        while(!(UCB1IFG&UCRXIFG));
        msb = UCB1RXBUF;                                                // Read MSB of Data
        UCB1TXBUF = (temp & 0xff);                                // Write LSB of Config
        msb = (msb << 8) | UCB1RXBUF;                        // Read LSB of Data
        dummy = UCB1RXBUF;                                                // Read MSB of Config
        UCB1TXBUF= (temp & 0xff);                                // Write LSB of Config
        dummy = (dummy <<8) | UCB1RXBUF;                // Read LSB of Config
        return msb;
亲,你这个程序可以实现功能么   详情 回复 发表于 2014-7-31 18:01
点赞 关注(1)
亲,你这个程序可以实现功能么
