3119|3
各位高手帮个忙~ [复制链接]
下面这段PCF8563读写程序不知道哪里出问题了,在proteus仿真时出现错误 Internal Exception:access violation in module 'PCF8563.DLL'   ,请问是我程序问题还是软件问题
proteus可以仿真其他电路。谢谢了~
附程序:#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit LCD_RS = P2^5; /*LCD1602指令,数据控制端口*/
sbit LCD_RW = P2^6;/*LCD1602读、写控制端口*/
sbit LCD_EN = P2^7;/*LCD1602使能*/
sbit pcf8563_scl=P2^2;
sbit pcf8563_sda=P2^3;
bit flag=1,hour=0,min=0;
bit year=0,month=0,day=0,week=0;
bit busy=0;
uchar  timecount=0,count=0;
uchar code  mytab[8] = {0x01,0x1b,0x1d,0x19,0x1d,0x1b,0x01,0x00};/*小喇叭形状定义*/
uchar init [] ={0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar init2[] ={0x00,0x00,0x12,0x01,0x06,0x01,0x00};
               /*秒,分, 时, 日, 月,星期,年,默认时间设置*/
void  Set_place(uchar row,uchar col);
void  Play_nowtime();
void  start_pcf8563();
void  stop_pcf8563();
void read();
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
void delay1(int ms)/*延时*/
 unsigned char y;
  while(ms--)
  for(y = 0; y<250; y++)
   _nop_();
   _nop_();
   _nop_();
   _nop_();
/*检查LCD忙状态,lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据*/
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
/*写指令数据到LCD,RS=L,RW=L,E=高脉冲,D0-D7=指令码*/
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*写显示数据到LCD,RS=H,RW=L,E=高脉冲,D0-D7=数据*/
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*  LCD初始化设定 */
void init_lcd()
    delay1(15);
    lcd_wcmd(0x01);      /*清除LCD的显示内容*/
    lcd_wcmd(0x38);      /*设置16×2显示,5×7点阵,8位数据接口*/
    delay1(5);
    lcd_wcmd(0x38);
    delay1(5);
    lcd_wcmd(0x38);
    delay1(5);
    lcd_wcmd(0x0c);      /*显示开,关光标*/
    delay1(5);
    lcd_wcmd(0x06);      /*移动光标*/
    delay1(5);
    delay1(5);
/*  设定显示位置*/
void write_position(uchar row,uchar col)
   uchar place;
   if(row==1)
     place=0x80+col-1;
     lcd_wcmd(place);
   else
     place=0xc0+col-1;
     lcd_wcmd(place);
/*自定义字符写入CGRAM*/
void  writetab()
    unsigned char i;
    lcd_wcmd(0x40);            /*写CGRAM*/
    for (i = 0; i< 8; i++)
    lcd_wdat(mytab);
void Send_pcf8563_byte(uchar bb) /*向PCF8563发送一个字节*/
uchar aa;
pcf8563_scl=0;
for(aa=0;aa<8;aa++)
if((bb&0x80)==0x80)
pcf8563_sda=1;
else
pcf8563_sda=0;
pcf8563_scl=1;
pcf8563_scl=0;
bb=bb<<1;
_nop_();
_nop_();
pcf8563_sda=1;
pcf8563_scl=1;
busy=0;
if(pcf8563_sda)
busy=1;
else
_nop_();
_nop_();
pcf8563_scl=0;
busy=0;
receive_pcf8563_byte() /*从PCF8563接受一个字节*/
uchar CC;
uchar k;
k=0;
pcf8563_sda=1;
for(CC=0;CC<8;CC++)
k=(k<<1)|pcf8563_sda;
pcf8563_scl=0;
pcf8563_scl=1;
_nop_();
_nop_();
pcf8563_scl=0;
_nop_();
_nop_();
return k;
void write_pcf8563(uchar subadd,uchar dat)/* 向PCF8563对应地址写数据*/
start_pcf8563();
Send_pcf8563_byte(0xa2);
if(!busy)
Send_pcf8563_byte(subadd);
if(!busy)
Send_pcf8563_byte(dat);
stop_pcf8563();
void set_pcf8563(uchar addr,uchar *p,uchar n) /*写入n个数据*/
   for(;n>=0;n--)
   write_pcf8563(addr,*p);
   p++;
   addr=addr+1;
void read_pcf8563(void) /*读当时的时间,日期,月,星期,年*/
uchar i;
start_pcf8563();
if(!busy)
Send_pcf8563_byte(0x02);
if(!busy)
 for(i=0;i<8;i++)
    start_pcf8563();
    Send_pcf8563_byte(0xa3);
    init=receive_pcf8563_byte();
stop_pcf8563();
void start_pcf8563() /*开启PCF8563IIC*/
pcf8563_sda=1;
pcf8563_scl=1;
pcf8563_sda=0;/*SCL为低,SDA执行一个上跳*/
pcf8563_scl=0;/*SCL为低,嵌住数据线*/
void stop_pcf8563() /*关闭PCF8563IIC */
pcf8563_sda=0;
pcf8563_scl=1;
pcf8563_sda=1;/*SCL为高,SDA执行一个上跳 */
/* 主函数*/
void main()
   P1=0xff;
   TMOD=0x01;   /*定时器工作方式1,16位定时*/
   TH0=0x4c;          /*50ms定时*/
   TL0=0x00;
   EA=1;
   ET0=1;   /*允许定时器0中断*/
   TR0=1;
   init_lcd();                 /*初始化LCD*/
   writetab();               /*自定义字符写入CGRAM*/
   set_pcf8563(0x02,init2,7); /*自动设置初始时间,日期,年月*/
   read();
   Play_nowtime();
/*Time0中断函数*/
void Time0(void) interrupt 1 using 0
  TL0=0x00;
  timecount++;
  if(timecount>9)
    timecount=0;
    flag=~flag;
/* 显示当前时间*/
void  Play_nowtime()
  write_position(2,1);
  lcd_wdat(((init[2]&0xf0)>>4)+0x30);
  write_position(2,2);
  lcd_wdat('0'+(init[2]&0x0f)); /*读小时*/
    write_position(2,4);
    lcd_wdat('0'+((init[1]&0xf0)>>4));
    write_position(2,5);
    lcd_wdat('0'+(init[1]&0x0f)); /*读分钟*/
    write_position(2,7);
    lcd_wdat('0'+((init[0]&0xf0)>>4));
    write_position(2,8);
lcd_wdat('0'+(init[0]&0x0f)); /*读秒*/
    write_position(1,3);
    lcd_wdat('0'+((init[6]&0xf0)>>4));
    write_position(1,4);
    lcd_wdat('0'+(init[6]&0x0f)); /*读年*/
    write_position(1,1); /*写入年的第一位*/
lcd_wdat('2');
write_position(1,2); /*写入年的第二位*/
lcd_wdat('0');
    write_position(1,6);
    lcd_wdat('0'+((init[5]&0xf0)>>4));
    write_position(1,7);
    lcd_wdat('0'+(init[5]&0x0f)); /*读月*/
    write_position(1,9);
    lcd_wdat('0'+((init[3]&0xf0)>>4));
    write_position(1,10);
    lcd_wdat('0'+(init[3]&0x0f)); /*读日*/
write_position(1,16);
    lcd_wdat('0'+(init[4]&0x07)); /*读星期*/
write_position(1,5);
lcd_wdat('/');
write_position(1,8);   /*在年月之间加上符号"/" */
lcd_wdat('/');
write_position(1,11);   /*在年月之间加上符号"/" */
lcd_wdat('/');
write_position(1,12);   /*在年月之间加上符号"/" */
lcd_wdat('W');
write_position(1,13);   /*在年月之间加上符号"/" */
lcd_wdat('e');
write_position(1,14);   /*在年月之间加上符号"/" */
lcd_wdat('e');
write_position(1,15);   /*在年月之间加上符号"/" */
lcd_wdat('k');
    write_position(2,3);
lcd_wdat(':');
write_position(2,6);   /*在时,分,秒之间加上符号":"*/
lcd_wdat(':');
这样贴出代码估计是没几个人有耐心看完的。你不如多描述下你的现象。  详情 回复 发表于 2012-4-18 08:49
4008
这个程序用Proteus仿真出现   Internal Exception:access violation in module 'PCF8563.DLL',不知道是哪里错了。
