4799|6
6482
管理员
OPA2320:精密 CMOS 运算放大器datasheet&应用手册 [复制链接]
器件介绍:
The OPA320 (single) and OPA2320 (dual) are a new generation of precision, low-voltage CMOS operational amplifiers optimized for very low noise and wide bandwidth while operating on a low quiescent current of only 1.45mA.
The OPA320 series is ideal for low-power, single-supply applications. Low-noise (7nV/√Hz) and high-speed operation also make them well-suited for driving sampling analog-to-digital converters (ADCs). Other applications include signal conditioning and sensor amplification.
The OPA320 features a linear input stage with zero-crossover distortion that delivers excellent common-mode rejection ratio (CMRR) of typically 114dB over the full input range. The input common-mode range extends 100mV beyond the negative and positive supply rails.
DataSheet:
OPA2320.pdf (818.79 KB, 下载次数: 176)
应用手册:
所选封装材料的热学和电学性质.pdf (645.09 KB, 下载次数: 12)
运算放大器的单电源操作.pdf (2.12 MB, 下载次数: 20)
高速数据转换.pdf (1.92 MB, 下载次数: 12)
Shelf-Life Evaluation of Lead-Free Component Finishes.pdf (1.28 MB, 下载次数: 9)
Op Amp Performance Analysis.pdf (76.56 KB, 下载次数: 10)
Tuning in Amplifiers.pdf (44.08 KB, 下载次数: 6)
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
太需要了  详情 回复 发表于 2011-11-14 23:10
个人签名微信搜索公众号“EEWORLDBBS”快去添加关注吧!
89
真给力这次活动.OPA芯片这个用上去,应该效果很好的.谢谢
真给力这次活动.OPA芯片这真给力这次活动.adc芯片这个用上去,应该效果很好的.谢谢
41
不错哦
很强大
63
OPA 很好!
太需要了
