3753|1
DZ60 的Flash擦写问题 [复制链接]
程序如下,为什么FCCF位一直是1??这样写对么???求教!!!
#include <hidef.h> /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
#define UINT8 unsigned char
#define UINT16 unsigned int
/****************总线时钟设置 busfre=8MHz*******************/
void PLL_Init (void) //FEI-->FBE--> PBE-->PEE   busfre=8MHz
   SOPT1=0x00;
   MCGC2=0x36;//00110110
              //BDIV=00    总线频率=?/1
              //RANGE=1    选择高频范围
              //HGO=1     高增益模式
              //LP=0    旁路模式激活PLL、FLL
              //EREFS=1       选择振荡器
              //ERCLKEN=1    外部时钟使能
              //EREFSTEN=0   停止状态时禁用
  while(!MCGSC_OSCINIT);    //循环检测 EREFS选择的晶体初始化完成
  MCGC1=0xB8;    //10111000                            ///////////////FEI-->FBE ///////////////////
                 //CLKS=10   选择外部参考时钟
                 //RDIV=111   4MHz/128=31.25KHz
                 //IREFS=0    选择外部参考时钟
  while(MCGSC_IREFST);       //循环检测 外部参考是否是当前时钟参考
  while((MCGSC_CLKST)^(0x02));   //循环检测
  MCGC2_LP=1;
  MCGC1=0x90;     //10010000                           ////////////////FBE-->BLPE//////////////////
                  //CLKS=10
                  //RDIV=010   4MHz/4=1MHz
                  //IREFS=0
  MCGC3=0x44;     //01000100
                  //PLLS=1
                  //VDIV=0100    1MHz*16=16MHz
 MCGC2_LP=0;                                         //////////////BLPE-->PBE////////////////////////
 while(!MCGSC_PLLST);
 while(!MCGSC_LOCK);   //循环检测
 MCGC1=0x10;    //00010000                               ///////////////PBE-->PEE//////////////////
                //CLKS=00   选择PLL输出为系统时钟源
 while((MCGSC_CLKST)^(0x03));   //  循环检测
                                // MCGOUT=1MHz*16/1=16MHz    busfre=MCGOUT/2=8MHz
void FCLK_Init()
    FCDIV=39;        //PRDIV8=0,DIV=39  fFCLK=200kHz
UINT8  Page_Erase(UINT8 Adress)
    if(FSTAT&0x10)     //check  to see if FACCERR is set
        FSTAT=FSTAT|0x10;           //write 1 to FACCERR to clear
    (*((volatile UINT8*)(Adress)))=0xaa;          //write to somewhere in flash
    FCMD=0x40;                      //  set command type     sector erase
    FSTAT=FSTAT|0x80;               //put FCBEF at 1
    _asm NOP;
    _asm NOP;
    _asm NOP;
    _asm NOP;                       //wait four cycles
    if(FSTAT&0x30)                   //check to see if FACCERR or FPVIOL are set
        return 0x00;                 //if so ,Error
   while (!(FSTAT&0x40));             //wait for command to complete
   return 0x01;
UINT8  Program_Byte(UINT16 Adress,UINT8 data)
    (*((volatile UINT16*)(Adress)))=data;          //write data to somewhere in flash
    FCMD=0x20;                      //  set command type     byte program
    _asm NOP;
    _asm NOP;
    _asm NOP;
   return 0x01;
void main(void)
    UINT8  temp1,temp2;
    PLL_Init();
    FCLK_Init();
    DisableInterrupts;
    temp1=Page_Erase(0xFF00);
    temp2=Program_Byte(0xFF00,0x00);
    for(;;);
此帖出自NXP MCU论坛
此帖出自NXP MCU论坛
