3531|6
2804
【我给XILINX资源中心做贡献】 FPGA控制DS18B20代码 [复制链接]
FPGA控制DS18B20代码
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ds1820 is
port(clk : in std_logic;
               dq  : inout std_logic;
    temp_h : out std_logic_vector(7 downto 0);
    temp_l : out std_logic_vector(7 downto 0));
end ds1820;
architecture Behavioral of ds1820 is
TYPE STATE_TYPE is (RESET,CMD_CC,WRITE_BYTE,WRITE_LOW,WRITE_HIGH,READ_BIT,CMD_44,WAIT800MS,CMD_BE,GET_TMP,WAIT4MS);
signal STATE: STATE_TYPE:=RESET;
signal clk_temp : std_logic:='0';
signal clk1m : std_logic;
signal write_temp : std_logic_vector(7 downto 0):="00000000";
signal TMP : std_logic_vector(11 downto 0);
signal tmp_bit : std_logic;
signal WRITE_BYTE_CNT : integer range 0 to 8:=0;
signal WRITE_LOW_CNT : integer range 0 to 2:=0;
signal WRITE_HIGH_CNT : integer range 0 to 2:=0;
signal READ_BIT_CNT : integer range 0 to 3:=0;
signal GET_TMP_CNT : integer range 0 to 12:=0;
signal cnt : integer range 0 to 100001:=0;
signal count : integer range 0 to 25:=0;
signal WRITE_BYTE_FLAG : integer range 0 to 4:=0;
begin
ClkDivider:process (clk)
begin
if rising_edge(clk) then
   if (count = 24) then
      count <= 0;
      clk_temp<= not clk_temp;
   else
      count <= count +1;
   end if;
end if;
   clk1m<=clk_temp;
end Process;
STATE_TRANSITION:process(STATE,clk1m)
begin
   if rising_edge(clk1m) then
      case STATE is
         when RESET=>
            if (cnt>=0 and cnt<500) then
               dq<='0';
    cnt<=cnt+1;
    STATE<=RESET;
           elsif (cnt>=500 and cnt<1000) then
    dq<='Z';
    cnt<=cnt+1;
    STATE<=RESET;
elsif (cnt>=1000) then
    cnt<=0;
    STATE<=CMD_CC;
end if;
        when CMD_CC=>
write_temp<="11001100";
STATE<=WRITE_BYTE;
        when WRITE_BYTE=>
case WRITE_BYTE_CNT is
when 0 to 7=>
   if (write_temp(WRITE_BYTE_CNT)='0') then
      STATE<=WRITE_LOW;
   else
      STATE<=WRITE_HIGH;
   end if;
      WRITE_BYTE_CNT<=WRITE_BYTE_CNT+1;
when 8=>
   if (WRITE_BYTE_FLAG=0) then -- 第一次写0XCC完毕
      STATE<=CMD_44;
      WRITE_BYTE_FLAG<=1;
   elsif (WRITE_BYTE_FLAG=1) then --写0X44完毕
      STATE<=RESET;
      WRITE_BYTE_FLAG<=2;
   elsif (WRITE_BYTE_FLAG=2) then --第二次写0XCC完毕
      STATE<=CMD_BE;
      WRITE_BYTE_FLAG<=3;
   elsif (WRITE_BYTE_FLAG=3) then --写0XBE完毕
      STATE<=GET_TMP;
      WRITE_BYTE_FLAG<=0;
   end if;
   WRITE_BYTE_CNT<=0;
end case;
        when WRITE_LOW=>
case WRITE_LOW_CNT is
   when 0=>
      dq<='0';
      if (cnt=78) then
         cnt<=0;
         WRITE_LOW_CNT<=1;
      else
         cnt<=cnt+1;
      end if;
   when 1=>
      dq<='Z';
      if (cnt=2) then
         cnt<=0;
         WRITE_LOW_CNT<=2;
      else
         cnt<=cnt+1;
      end if;
   when 2=>
      STATE<=WRITE_BYTE;
      WRITE_LOW_CNT<=0;
   when others=>WRITE_LOW_CNT<=0;
end case;
        when WRITE_HIGH=>
 case WRITE_HIGH_CNT is
    when 0=>
       dq<='0';
       if (cnt=8) then
          cnt<=0;
          WRITE_HIGH_CNT<=1;
       else
          cnt<=cnt+1;
       end if;
    when 1=>
       dq<='Z';
       if (cnt=72) then
          cnt<=0;
          WRITE_HIGH_CNT<=2;
       else
          cnt<=cnt+1;
       end if;
    when 2=>
       STATE<=WRITE_BYTE;
       WRITE_HIGH_CNT<=0;
    when others=>WRITE_HIGH_CNT<=0;
 end case;
         when READ_BIT=>
 case READ_BIT_CNT is
    when 0=>
       dq<='0';
       if (cnt=4) then
READ_BIT_CNT<=1;
cnt<=0;
       else
          cnt<=cnt+1;
       end if;
    when 1=>
       dq<='Z';
       if (cnt=4) then
          READ_BIT_CNT<=2;
          cnt<=0;
       else
          cnt<=cnt+1;
       end if;
    when 2=>
       TMP_BIT<=dq;
       if (cnt=1) then
          READ_BIT_CNT<=3;
          cnt<=0;
       else
          cnt<=cnt+1;
       end if;
    when 3=>
       if (cnt=45) then
          cnt<=0;
          READ_BIT_CNT<=0;
          STATE<=GET_TMP;
       else
          cnt<=cnt+1;
       end if;
    when others=>READ_BIT_CNT<=0;
 end case;
         when CMD_44=>
 write_temp<="01000100";
 STATE<=WRITE_BYTE;
         when WAIT800MS=>
 if (cnt>=100000) then
    STATE<=RESET;
    cnt<=0;
 else
    cnt<=cnt+1;
    STATE<=WAIT800MS;
 end if;
         when CMD_BE=>
 write_temp<="10111110";
 STATE<=WRITE_BYTE;
         when GET_TMP=>
 case GET_TMP_CNT is
    when 0 to 11=>
       STATE<=READ_BIT;
       TMP(GET_TMP_CNT)<=TMP_BIT;
       GET_TMP_CNT<=GET_TMP_CNT+1;
    when 12=>
       GET_TMP_CNT<=0;
       STATE<=WAIT4MS;
 end case;
         when WAIT4MS=>
 if (cnt>=4000) then
    STATE<=RESET;
    cnt<=0;
 else
    cnt<=cnt+1;
    STATE<=WAIT4MS;
 end if;
         when others=>STATE<=RESET;
      end case;
   end if;
end process;
temp_h<='0'&TMP(11 downto 5);
temp_l<="0000"&TMP(4 downto 1);
end Behavioral;
在XILINX SPARTAN3 STARTER KIT 上测试能正常显示温度
此帖出自FPGA/CPLD论坛
5楼,急用啊,能分享下你的代码吗  详情 回复 发表于 2012-5-22 13:49
个人签名QQ:1625345502
6892
强顶
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
66
楼主V5
此帖出自FPGA/CPLD论坛
155
这么多呀 都看不过来!
此帖出自FPGA/CPLD论坛
我用Verilog写的,工作也非常正常,还在8位LED上显示了数据。
此帖出自FPGA/CPLD论坛
6892
5楼也把你的代码分享一下啊,最好能给些比较详细的说明最好的!
此帖出自FPGA/CPLD论坛
欢迎光临网上店铺!
回复 5楼 mgjacky 的帖子
5楼,急用啊,能分享下你的代码吗
此帖出自FPGA/CPLD论坛
