适合arm的通用的printf,只要提供putc函数就可..
void CommPrintf( void (*fputc)(CPU_INT08S),const CPU_INT08S *format, ...) { static const CPU_INT08S hex[] = "0123456789ABCDEF"; static const CPU_INT32U pulDiv[3][12] = { { 01,010,0100,01000,010000,0100000,01000000,010000000, 0100000000,01000000000,010000000000,010000000000, }, { 1,10,100,1000,10000,100000,1000000, 10000000,100000000,1000000000,1000000000, }, { 0x1,0x10,0x100,0x1000,0x10000, 0x100000,0x1000000,0x10000000, }, }; CPU_INT08S c; CPU_INT08U i,type,wide=0; CPU_INT08S t; CPU_INT32U ulDivValue; CPU_INT32S lParValue; CPU_INT08S *ptr; va_list ap; //DispLock(); va_start (ap, format); for (;;) /* Until full format string read */ { while ((c = *format++) != '%') /* Until '%' or '\0' */ { if (!c) { va_end (ap); //DispUnlock(); return ; } fputc(c); } switch (c = *format++) { default: break; case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': wide = c-'1'; wide %= 9;//×î¶àÖ»ÓÐ8λ c = *format++; switch(c) { case 'o': type = 0; goto CONVERSION_LOOP; case 'd': case 'u': type = 1; goto CONVERSION_LOOP; case 'x': type = 2; goto CONVERSION_LOOP; default: break; } break; case '%': fputc('%'); break; case 'c': c = va_arg(ap, int); fputc(c); break; case 's': ptr = va_arg(ap,CPU_INT08S *); while ((c = *ptr++)!=0) { fputc(c); } break; case 'o': type = 0; goto CONVERSION_LOOP; case 'd': case 'u': type = 1; goto CONVERSION_LOOP; case 'x': type = 2; CONVERSION_LOOP: lParValue = va_arg(ap,int); if (c == 'd' || c=='u') { if ((lParValue) < 0) { lParValue = - lParValue; if(c!='u') { fputc('-'); } } } for(t=-1;;) { if(lParValue<=pulDiv[type][++t]) { if(t) { t--; } break; } } if(t>=wide) //´ËʱºöÂÔwide { i=t; } else { i=wide; } do { ulDivValue = pulDiv[type]; t=lParValue/ulDivValue; lParValue -= t*ulDivValue; fputc(hex[t]); }while(i--); wide=0;//ΪÏÂÒ»×÷×¼±¸ } } }
注意:此时要调用此函数实现可变要用如下方法,还是举个例子吧 void LcdPrintf(const CPU_INT08S *format, ...) { va_list ap; CPU_INT32U p1,p2,p3; DispLock(); va_start (ap, format); p1 = va_arg(ap,CPU_INT32U);// p2 = va_arg(ap,CPU_INT32U);// p3 = va_arg(ap,CPU_INT32U);// CommPrintf(_LcdPutChar,format,p1,p2,p3); va_end(ap); DispUnlock(); } 必须要传递p1,p2,p3,否则堆栈会出错
修改后也可以适合其他的编译器和CPU
