4977|8
90
RealViewMDK3.20版最新发布!简体中文帮助 [复制链接]
RealView MDK最新版本,帮助为简体中文版,下载请前往http://www.realview.com.cn/down-list.asp?id=326
3.20版更新如下:
[Device Support]
    Added: RTX support for TMS470 in folder ..ARMBoardsTITMS470R1B1MRTX_Blinky.
    Added: example projects for NXP LPC2919 in folder ..ARMBoardsKeilMCB2900.
    Added: support for STMicroelectronics STA2051.
    Added: support for AustriaMicroSystems AS3525  in folder ..ARMBoardsAMSAS3525.
    Added: support for NXP (Sharp) LH79524 in folder ..ARMBoardsNXPLH79524.
    Added: support for Winbond W90P710 in folder ..ARMBoardsWinbondW90P710.
    Added: RTX Traffic example for STR9 devices and corrected a problem with the interrupt controlled UART simulation of STR9.
    Corrected: for Altera Cortex-M1 driver the option Use Reset at Startup was not stored.
    Corrected: RT-Agent configuration AT91SAM7X with interrupts in folder ..ARMRT AgentRTXAT91SAM7X-EKBlinky.
    Corrected: Timer3 and Timer4 of LPC2101/2/3 devices was incorrectly simulated.
[RTX - Problems Solved]
    Corrected: core problems for Cortex-M devices. Handling of isr_xxx function calls was incorrect and could cause task locks. Wrong handling of task switches and __svc functions could cause sporadic application crashes if additional user interrupts were enabled.
相关链接:http://www.realview.com.cn/product/271.htm
此帖出自stm32/stm8论坛
                                     详情 回复 发表于 2008-2-26 14:44
67
升级很频繁啊
                                 不过对于STM32,现在的3.15b版本我觉得还不错,暂时不打算升级了。
此帖出自stm32/stm8论坛
帮助是中文的,这对很多用户应该很有用啊
此帖出自stm32/stm8论坛
会要求update LINK-me吗?
3.15B 会要求升级LINK-ME.
3.20会吗?
此帖出自stm32/stm8论坛
56
等待Crack!!!
此帖出自stm32/stm8论坛
5楼帅气~~~
此帖出自stm32/stm8论坛
65
支持升级!
                                 同样等..........呵呵!
此帖出自stm32/stm8论坛
90
看来需要的人还是不少啊……
此帖出自stm32/stm8论坛
中文帮助还是老的吧..............
此帖出自stm32/stm8论坛
